1 - 6 of 6 Posts
Hi.
I currently am in the midst of a renovation in my house which has left my 9241 with only one input as the temporary room has only one cable available.
I am able to see all channels off the 82 and 91 satellites but when setting timers they are using tuner 2 (indicated by the '2' against the timer in the listings) instead of tuner 1. Thus when the timers fire off, I get nothing recorded.
So a couple of questions:
1. Is there a way to change the default tuner to '1' instead of the current '2' when setting timers on a 9241
2. When putting the cable into tuner 2, I get no picture/signal for any channel. On a 9241 with a single input can you only use Tuner 1 to receive your programming?
I appreciate any feedback. I spent at least 1/2 hour in the old posts with respect to the default tuner question but while mentioned it was never explicitly listed on how to do this. :)
Thanks in advance.
I've never seen the option to change the default recording timer.
You could try setting up a "dummy" event (autotune or recording) on Tuner 2 to coincide with the show you want to record. Then set the timer for the show that you actually want. One would assume it would go to Tuner 1 but you never know with Bell. It may see "no signal" for your dummy event and just totally hiccup.
Kevin
1 - 6 of 6 Posts
