720p60
1902 Views 2 Replies 2 Participants Last post by  cooper83
I recently purchased a Kodak PlaySport (ZX3) partly due to its ability to record 720p @ 60fps. I use iMovie HD (iMovie '06) and it appears to only import 720p @ 30fps. Apparently this is also the case with Final Cut Express, and one must upgrade to Pro to get 60fps capability.
What I'd like to know: is there any benefit in filming at 60fps if my software converts it to 30fps?
1 - 3 of 3 Posts
It's sad that most people including movie editing tools developers and video hosting sites care less about 60fps. I gave up after finding no MP4 editing software that supports 60fps. For the 720p60 videos I shoot, I limit my video-editing to simple cutting with basic MP4 video-cutting software in order to keep 60fps.
Depending on your camcorder, you may or may not benefit from shooting 720p60 even if you convert to 720p30 in the end. My cheap Aiptek ActionHD does 720p30, 720p60, and 1080p30, with increasing bitrate respectively. If I know my clip is going to go on youtube I'll shoot in 1080p30 for its highest bitrate. And because 720p60 runs higher bitrate than 720p30, it still seems better if I shoot in 720p60 and convert it to 720p30 than to shoot 720p30.
That's good to hear. So it may just require some experimenting on my part. I realize I'm using old software, but I was surprised to see that even the latest version of Final Cut Express doesn't support 60fps.
Any other tips or info would be helpful, thanks guys.
1 - 3 of 3 Posts
