The page down key on my motorola 6412 pvr stopped working. Now when I bring up the guide, I can only page through the channels one way. Is there something I can do to fix this, like a reset? Would Shaw give me a replacement remote if I asked them?
Shaw will replace the remote for free, just take it in to your local office. Don't forget to take the batteries out as they will just throw your old remote away.
The style might be a little different but I think the current one is better than the older style. You should get used to it fairly quickly if the one you have now is not the same.
They have always replaced mine for free as long as I am a subscriber. You can also buy an extra one for $15 (at least that is what they charged me the last time I bought one, about a year ago).
If that doesn't work try:
Press CBL
Then press AND HOLD Setup til CBL blinks once red then 2 more times red.
Then press 1376
Then press CBL once
Then press Setup once to lock it in.
If that fails a swap will work too as others have mentioned.
Not only does it have the information contained in the manual, but it also contains the "Extended Function Codes" that allows you to reprogram individual buttons on your remote (in case the "30 second skip" or "swap" button stops working, for instance).
A forum community dedicated to Canadian TV, computing and home theatre owners and enthusiasts. Come join the discussion about home audio/video, displays, troubleshooting, styles, projects, DIY’s, product reviews, accessories, classifieds, and more!
