Hi all, i just installed an old 6100 Hd receiver to plug it on my HTPC (running media Center on Windows 7 ultimate with Haupage 2250).
I have a problem regarding the IR blaster that sending signal to 6100. I know the remote is a UHF/IR and it can control 6100 or IR like 3100, 2700 etc.
BUT is the receiver able to receive IR signals ? the blaster is unable to change channel. I also tried another universal remote (old) that works on my 3100 but it has no effects on the 6100.
I reset all parameters to factory default. The Remote is set to channel 1. In the info screen, i dont see anything regarding to UHF/IR.
If someone has a tips, it would be appreciated.
Tx.
Tx.
