1 - 10 of 10 Posts
I am vastly less enthusiastic after seeing T-Mobile's demo of how mmWave signals are blocked by a glass door: https://arstechnica.com/information-technology/2019/04/millimeter-wave-5g-will-never-scale-beyond-dense-urban-areas-t-mobile-says/
5g over the standard frequencies is better than 4g on the same frequencies, but not vastly so. The miraculous stuff is over mmWave, which has abysmal range, doesn't penetrate much of anything, and even requires phone antennas more complicated and power hungry to work properly. You'll never see it in most of Canada because it's prohibitively expensive to deploy outside of the densest areas.
The reality will not live up to the hype, mostly because the hype train has gotten well out of control.
If/when this comes to Canada it show be awesome
Actually, it's already here. Rogers had a pilot project in the Rogers Centre, in Toronto and they're also rolling it out in the Toronto area and elsewhere. However, as mentioned above, performance depends on the bands used. There is one new band at 600 MHz, another around 5 - 6 GHZ and one around 30 - 40 GHz, which is the band that provides greatest perforamance. Range on that band isn't that great, so a lot of sites would be needed. In the same bandwidth, 5G provides about 20 - 25% improvement over LTE.
5G
The 5GHz band will be short range with some building penetration, a little like 5GHz wifi but better due to the higher power available. It will be useful near densely populated areas with buildings. 30GHz and higher bands will be strictly line of site but will have much higher throughput. It will be useful for places like arenas where antennas can be located within site of a large number of devices.
Also, the band that Rogers is planning on using initially is around 2.5 GHz, which won't be much different than some of the other spectrum they use. Also, 600 MHz will have performance similar to 700 MHz.
The 2.5GHz band won't provide a lot of bandwidth for densely packed areas such as the Rogers Centre. A lot of users, such as in a stadium, would provide very little throughput per device. 24GHz+ bands will provide much more bandwidth and potential speed than lower frequency bands. In addition, the short range and penetration of 24GHz+ bands will allow for more compartmentalization which multiplies the available total bandwidth significantly.
"5G access is included with Rogers Infinite plans at no extra charge until March 2021 ($15/month value)."
From the Rogers FAQ.
If that charge actually survives to 2021 is an open question as more networks start launching, but I suspect a lot of people will balk at $15/month extra if they try and keep it.
Also, there's the question of what service they get. The 600 MHz 5G won't be much different from 700 MHz LTE. On the other hand, there's not a lot of millimetre wave (30 - 40 GHz) coverage yet, but that's where the major performance improvements will be.
1 - 10 of 10 Posts
