1 - 4 of 4 Posts
I have had one of these for a couple of years but had never used the record function as it was in my motorhome with a single line from the motosat auto dish. I have hooked it up in the house now and although it records, when I go to playback my tv screen just goes black. Any ideas??
Swap the cables and see if you have a good picture, that way you will know if the second feed to your receiver is good, or you can check your signal strengths in the serttings menu. Another thing you could try is to have the receiver format the hard drive.
1 - 4 of 4 Posts
