1 - 3 of 3 Posts
My 52D64U all of a sudden wont power on. No issues prior and today it doesn't power on.
When power is applied you here the clikc and then the power and opc blink twice together and then the opc once and the pattern repeats.
Any suggestions/thoughts on what it could be or how to possibly reset it?
Try unplugging the TV overnight to see if it'll reset. Unplug everything from the TV. The flashes are a code and you could call a service depot to see if they'll tell you what the code means. Often TVs also have a "reset all" in the user menu somewhere, but that only helps if you can power on.
http://www.digitalhome.ca/forum/showthread.php?t=19694 Things to check.
1 - 3 of 3 Posts
