1 - 14 of 14 Posts
I have an older 505 with the quad lnb, all of a sudden it won't tune in sd channels only the HD ones. I'm stuck on acquiring sat signal, any thoughts?
are you getting CTV HD? what about French SD channels or NFL-N? If you answered no to the first question and yes to the second, then I suspect you have a bad output in your LNB. I had similar problem as you a few months ago, and I had to swap to an unused output on my multiswitch.
Discussion Starter #3
No Ctv HD, french works. I switched to a different output on the lnb, but same thing. I don't have a multi switch, just one coax from the receiver to the lnb.
Have a look at your LNB. If it's an old one, maybe the white plastic cover has cracked & come off letting rain into the LNB.
I've seen several like this.
i strongly suspect that at this point you have a bad cable and/or connector so the tone is not getting from your receiver to the LNB. the tone is what signals the LNB to switch satellites. When I had similar problem in the past, I took my receiver and a small tv outside and hooked a short rg6 from the dish to the receiver. this way i confirmed that there were no flaws in my dish or receiver. I replaced the bad cable run, and everything worked properly.
Christpuncher, where are you located? Even 92% seems a bit low for channel 700. You should be getting your strongest signal with this channel. What is your Ecb/No. for this channel? I would say your dish is out of alignment.
So I would gather then your dish needs alignment. I'm not to far from you and get like 98% and Ecb/No of 10.6. So your dish is not seeing F1 properly if your getting no signal on 299.
I just has the same problem after replacing my dish. I could get HD channels and channel 700, but had no signal on 299. Shaw had to change what I think was a "V" code, and we knew it was changed when the network data status (line F of system status) changed, it now reads 500-4326. I think before it read something like 500-5352....
1 - 14 of 14 Posts
