1 - 5 of 5 Posts
NOT NEW JUST SELDOM POST have been a member since 2013 as Soroco but had trouble with sign in so rejoined as Elkson Have built many of your ideas in the last 6 years with varying success Have just finished a 4 bay bow tie (M4) with a holey reflector 1x2 cut to back each 10 inch whisker the vacant space saved 1# The channels I receive 22 always 5, 17 often 2, 20, 30, occasionally 28, 39 heavy Tropo only. Thinking of putting a stealth hawk loop on top so when I sight antenna I will still receive 22 What do you think. 10 miles south of Sparta TN 38583 My tropo is black or purple from now to Sunday, I know TVFOOL says location is hopeless but the proof is in the watching.
Premium Member
You haven't posted a TVFool report yet, but a report based on an estimate (guess) of your location looks like this:
TV Fool
A report for the same estimated location from rabbitears.info looks like this:
https://www.rabbitears.info/searchmap.php?request=result&study_id=12306
RabbitEars says WWWB is off the air:
https://www.rabbitears.info/market.php?request=station_search&callsign=WWWB
Signal reports for weak signals can be very wrong. But, as you said, the tuner decides if the signal is good enough to be received at any particular time.
Discussion Starter #3
The antenna works but not as well as the Yagi a 20% loss of signal and will only pickup 22. Same location same height 30 mins to exchange. I gave you the general area for you use I have had an icon with my location on my computer for the last 6 years every time I exchange antennas I check for changes. The repack did not change anything here. Rotor has stopped working think I'll buy a 20 dollar lava style and mount my Yagi on top of it if it takes to long for me to repair it. My Yagi has a 14" folded dipole with 8 directors with boom mounted 1/16" above top and feed points 1/4" from end of boom.
Premium Member
So, the Yagi beats the 4-Bay; that's interesting.
Well, you know what a signal report for your location looks like, but I don't.
If you look at the righthand Repack Info column of the rabbitears report, you will see a lot of Repack changes.
No reflector? Did you build the Yagi or buy it? Can you show us a photo of the Yagi?
Discussion Starter #5
the reflector is 1x2" mash it is 11"hx10"w 5 above 5 below. homemade. cutting board insulators. Thinking of adding vhfhi on backside to see if I can pickup 9,12 and 13 from Chattannoga look on 285 and hickory valley rd
1 - 5 of 5 Posts
