1 - 3 of 3 Posts
Had the 3 tubes replaced on my set and when i go in service menu,right arrow,the horizontal raster lines are very bright.They all seem to have different brightness.My warrenty has expired and wonder should i turn the screen pots down to make them all the same or does this means nothing in regards to proper greyscale.
Those lines should be very pale almost invisible and definetly hard to see.
I dont know what effect that has on grey scale. There is a post over a TheSpot that I read on this subject one time you could check there.
Adjusting the pots will have a great affect on greyscale,conrtrast,brightness so think long before touching them..just a touch can have a great affect on all of the parameters I mentioned above...
1 - 3 of 3 Posts
