121 - 122 of 122 Posts
I wondering to fix my cable hd cisco4642 I have a problem that he is not rebooting after multiple tried to reboot it with following procedure unplug and left 15 second plug it back same issue it shows only this code in the screen 65Tr I dont know what that mean it looks it shows only this code nothing else even you unplugged and put it back this is not Pvr I am not sure is any component should be change.
is any body has the same issue. please let me know about this issues.
Do you have any other boxes in the home that are working? If so, swap the boxes and see if the problem follows the box or stays with the location in the home. Contact Rogers and have them check the signal to your box, to your home and to your neighbourhood.
Technical Support, TV Support.
