Greetings!
I am a big big fan of the following website as an OTA resource as well as digitalhome.ca!
http://www.hdtvprimer.com/ANTENNAS/ganging.html
I enjoy DTV dx’ing as a hobby and regularly test out new antenna setups just for fun.
The most recent setup I’ve got is qty (4) Winegard PR-4400’s horizontally ganged together.
I’ve used the website above (hdtvprimer) as a how to for the balun design using twin lead, but I think I am missing something or the design is different for the PR-4400 than for the CM 4221. Reason being I’ve got some nulls and less db than with just a single 4400 - and it doesn’t make sense to me that I wouldn’t connect all of the inner lobes to one of the 300-to-75 ohm balun’s connectors – rather just to themselves and then to nothing???. Looking at the design below, the center lobes just connect to eachother (each side of the 4400 is electrically independent), but not the balun - so they are hanging there in free space? Am I not reading that correctly? If I am then perhaps my wiring is incorrect.
For a “two in series, two in parallel” connection on the winegard 4400, wouldn’t it look more like the following? That is, all of the center lobes connected to one side of the 75 ohm balun and all of the outer lobes connected to the other side of the 75 ohm balun?
Or, some other design?
Many thanks in advance,
-logray
-logray
