1 - 3 of 3 Posts
i need help configuring my 4 channel dvr for my camera system with my computer..... i dont know how to set an ip adress so i can see my cameras on my computer
What DVR and cameras are you using? If it is analog cameras into a network attached DVR, more than likely it is set to DHCP and you can check it's IP address through either an attached monitor or your router's lookup table. Or it possibly even came with software for detecting it on your network. Can't say without the details.
1 - 3 of 3 Posts
