With the recent announcement that simsub of Canadian commercials will be back for the 2020 Super Bowl, it will be good to know where you can snag the raw US feed with US commercials.
The game is being broadcasted by FOX. For those in the greater Toronto/Hamilton/Niagara area, the FOX signal can be obtained via WUTV Buffalo 29 displayed channel (physical channel 32.3).
For many on this forum, this is old hat. For others, you'll need a decent UHF antenna aimed at the transmitter in Grand Island NY, which is just north of Buffalo.
If you are lucky enough, you might be able to snag the signal inside your house depending on your distance to the transmitter.
The power of the signal has recently been increased quite a bit into Ontario so chances are better than before in locking in a signal.
I believe they are broadcasting in 4K via US cable/satellite/stream, but not OTA - only HD 720P.
Cheers!
Cheers!
