1 - 6 of 6 Posts
Hey guys,
I recently purchased a Trendnet wireless G router and I already have a Linksys router -b. My question is, can I use the one router to dispense the signal where the ever leaves dead spots? If so, does anyone know how I can go about in doing this? Thanks!
Only if your Linksys router supports DD-WRT. But since you said it was a wifi-B router, I don't think it can be used to be a signal extender. Google DD-WRT.
It won't act as an access point but you can create two wireless networks. Turn off DHCP on the second router though.
From the above responses I'm guessing you want to bridge them wirelessly.
If you can hard-wire them together I think it would work. You would have to turn dhcp off on one of them though. It may not be seemless though when switching from 1 router to the other.
I have two wireless routers connected. (there is a thread around here explaining how I did it) The second one serves the basement of our house. I put it in because signal strength was weak in some parts of the basement.
Same as hugh. I set my second router with dd-wrt third party firmware running wifi-g to use it as a wireless bridge due to weakness of signal from basement to highest floor.
1 - 6 of 6 Posts
