I've looked at the drawings for the 2 and 4 square Chireix antennas, both found in Holl_ands album: http://imageevent.com/holl_ands/chireix/chireixrefl
I printed the drawings, hoping to use them for construction detail. However, the text and the drawings are not in complete agreement. The 2 square Chireix has 9.75 inch sides at 45 degree angles and the overall length from tip to tip is 26 inches. The four square Chireix has 9.75 inch sides and appears to be at 45 degree angles. Overall length from tip to tip is approximately 27 inches. This doesn't add up, the 4 sq should be 2x longer than the 2 sq if they use the same angles and side lengths. It appears that 4 sqaure uses 6.66 inch sides rather than 9.75 inch sides. What is the correct length of sides on the 4 sq? Is there a gain advantage by using longer sides (9.75 inches) and a taller reflector (60 inches)? thank you!
