1 - 5 of 5 Posts
Should I add a 1 prefix for all my contacts in my iphone? It would save hearing the annoying "this is a long distance..." message when speed dialing.
i.e. instead of (519)555-1212, put it in as 1 (519)555-1212
I just am hoping that I won't be charged long distance if it turns out that the number is 'local' to my present calling area.....
I use less than 100 of my 200 included local minutes per month.
P
i have my BB setup to automatically add the 1 prefix and have never been billed long distance for local calls. so yes, I would recommend doing it for your contacts.
After all, you will never here "This is a local call, please hang up and dial again without using the prefix 1"
You will here "The number you are calling is not a local number, please hang up and dial 1 then the number you wish to call"
Cheers
1 - 5 of 5 Posts
