GH with NARODs for VHF-HI & UHF - Page 22 - Canadian TV, Computing and Home Theatre Forums
Old 2009-10-04, 09:44 PM   #316
300ohm
Now all I have to do is update the antenna!
Waiting for that, heh.
300ohm is offline   Quick reply to this message
Old 2009-10-05, 12:47 PM   #317
stampeder
akahooper, excellent update and welcome to this site!
stampeder is offline   Quick reply to this message
Old 2009-10-22, 10:30 PM   #318
pdentrem
Default My DBGH
Not the best symmetry in the build but it works for what I need. I posted a picture in the photo album called "Wire straighten block and DBGH by pdentrem".
Thanks to 300ohm and the others who have posted their build ideas.
Last edited by pdentrem; 2009-10-23 at 07:12 AM. Reason: Location of picture needed clarifaction
pdentrem is offline   Quick reply to this message
Old 2009-10-22, 10:44 PM   #319
300ohm
Picture of the above:
Doesnt the mast get in the way of that weather vane ?
Old 2009-10-23, 07:11 AM   #320
pdentrem
Default Weather vane
The angle of the picture is covering up the fact that the vane is mounted on a 18" standoff.
Old 2009-12-12, 05:38 AM   #321
JPark
Hello all,
I've spent the last 6 hours perusing this forum and a few other helpful forums in anticipation of working on this project tomorrow (which is now today). I keep seeing references to people's plans and occasional links to plans, but those links are always broken. Could someone point me to a beginners guide to building the SBGH w/ NARODs? Mec_Eng's link cited above no longer works. 300ohm's sig says his plans are in a sticky, but all I've found are NEC files and dimensioned drawings. Both very helpful, but not the "plans" I'm looking for. I need something a bit more step-by-step. I'm not afraid to get my hands dirty and I could throw something together based on the sketches I've seen, but the last six hours have taught me that antennae are pretty sensitive to the smallest changes, so I'm trying to do it as close to "by the book" as possible.
JPark is offline   Quick reply to this message
Old 2009-12-12, 01:31 PM   #322
balm
go here
http://content12.wuala.com/contents/...=1260642658940
balm is offline   Quick reply to this message
Old 2009-12-12, 03:49 PM   #323
JPark
Thanks.
I'll take 300ohm's comments on Mec_Eng's plans in Post #201 into account and use akahooper's walkthrough for his build to guide me through the nitty gritty.
Old 2009-12-12, 03:50 PM   #324
balm
maybe 300ohm is the best person to ask about this...
Old 2009-12-12, 08:17 PM   #325
snowman53
Very nicely done set of drawings!
snowman53 is offline   Quick reply to this message
Old 2010-01-11, 10:11 AM   #326
bytor
Though the information is pretty good, I would be wary of the print or the parasolid file (.x_t) of the driven element. The upper and lower portions are not bent at 90 degrees and the driven element gets thin in this area which means something went wrong in either the sweep used to create this. I'd recommend using a different set of dimensions for the driven element, or if you print it out then use a square to redraw that bend which will move the 135 degree bend inward and the measured cut from that bend inward also. And that measured cut appears to be a bit longer than the 5.59" measurement found on the other set of prints I've seen
bytor is offline   Quick reply to this message
Old 2010-03-29, 05:59 PM   #327
running
To fix the narods on GH10 rev2. I fellows the same patern than you used on SBGH ?
running is offline   Quick reply to this message
Old 2010-04-08, 05:24 PM   #328
gcd0865
Default Alternate NAROD length/spacing?
Hi All:
Until earlier this week, I was planning a DBGH w/NARODs with the NAROD length/spacing focused on a distant RF-8, using the following measurements from this thread:
NAROD and NAROD reflector length is 30.25 inches and the NAROD to NAROD reflector distance is 11.5 inches:
CH Raw Gain dBi SWR
07 09.04 2.81
08 11.70 2.80
09 11.50 3.32
10 11.10 2.92
11 10.70 2.48
12 10.30 2.37
13 09.99 2.66
Unfortunately, a local low-powered religious station signed onto digital RF-8 this week, ruining that plan. Since I also have a full-powered local RF-7 and distant RF-10, 11, 12 and 13, I'll focus on 10-13 now, which would call for these NAROD measurements:
NAROD and NAROD reflector length is 28 inches and the NAROD to NAROD reflector distance is 10 inches:
CH Raw Gain dBi SWR
07 06.82 12.5 (8.71 dBi at 180 degrees)
08 07.63 3.94 (7.96 dBi at 180 degrees)
09 08.74 1.77
10 11.6 1.65
11 11.8 2.35
12 11.3 2.16
13 10.8 1.89
Just in case the religious station signs off or changes channels at some point, is there anything between the two above NAROD measurements, maybe something like 29.125 inch length and 10.75 inch separation, that would be decent on RF-13 (maybe around 10.4 raw gain) but wouldn't drop so much (and reverse its sensitivity direction) on RF-8 (maybe around 9.5 raw gain in the forward direction)? Alternatively, would a top-hat NAROD version of similar type be possible?
I'd very much appreciate any assistance anyone can provide. Thanks in advance...
gcd0865 is offline   Quick reply to this message
Old 2010-04-08, 08:23 PM   #329
300ohm
That will give you on channel 8, 8.54 dBi Raw Gain with a SWR of 3.3. On channel 13, that would be 10.37 dBi RG with a SWR of 2.33. Both in the right direction.
Old 2010-04-26, 01:01 PM   #330
wontgoin
Default Sbgh - replace 3/8" for 1/2" narods ?
Hi,
Can we use 1/2" instead of 3/8" aluminum tubes for the NARODS and NAROD reflectors? I'm having an extremely hard time finding 3/8" tubes in places like Home Depot and Reno Depot here in Montreal, but 1/2" tubes are plentiful and the prices are great.
I suppose 3/8" copper is easier to find, but I thought I'd stick to aluminum and would like to know what modifications would be necessary for SBGH6 dimensions when using 1/2" tubing. The antenna would be tweaked for VHF-Hi channel 13 (28" length with 10" spacing). Thanks in advance.
wontgoin is offline   Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
OTA Forum Sponsor
