#1 | |
Success !!! I got the Vhf-Hi gain going the right way with the colinear rod reflector models and with more gain to boot ! (This does not apply to the mesh models, for obvious reasons.)
Using the basic original SBGH gen1 colinear rod plans (with 10ga elements, 3/8 inch reflectors), I placed additional 28 inch, 3/8 inch reflectors 10 inches behind the 28 inch 10 ga NARODs that are 1/2 inch above the stubs. Oddly, using a larger reflector than the driven element, typical in most TV antenna designs, decreased performance, as did a smaller reflector. The effective bandwidth for Vhf-Hi is somewhat limited to about 4 channels. I tweaked for channels 10 to 13, so if channels 7 to 9 are needed, adjustments have to be made. The use of the NARODs levels out and dips the gain curve similiar to the SBGH JED Gold Standard model, so the original SBGH gen1 model is so far the best to use in this case so as to not exacerbate the dip further. VHF-HI CH Raw Gain SWR -- -------- ----- 07 5.56 dBi 62.3 (7.93 dBi at 180 degrees) 08 6.27 dBi 23.0 (8.02 dBi at 180 degrees) 09 8.07 dBi 5.67 10 9.66 dBi 2.37 11 9.81 dBi 3.7 12 9.26 dBi 3.58 13 8.66 dBi 3.16 Channel 10 pattern : 3D Picture : UHF Raw Gain Chart : UHF SWR : NEC file : Code:
CE GW 30 15 0 1.73228346 0 0 6.73228346 5 0.05094856 GW 31 15 0 1.73228346 10 0 6.73228346 5 0.05094856 GW 32 15 0 1.73228346 10 0 6.73228346 15 0.05094856 GW 34 15 0 -1.7322835 0 0 -6.7322835 5 0.05094856 GW 35 15 0 -1.7322835 10 0 -6.7322835 5 0.05094856 GW 36 15 0 -1.7322835 10 0 -6.7322835 15 0.05094856 GW 38 15 0 1.73228346 0 0 6.73228346 -5 0.05094856 GW 39 15 0 1.73228346 -10 0 6.73228346 -5 0.05094856 GW 40 15 0 1.73228346 -10 0 6.73228346 -15 0.05094856 GW 42 15 0 -1.7322835 0 0 -6.7322835 -5 0.05094856 GW 43 15 0 -1.7322835 -10 0 -6.7322835 -5 0.05094856 GW 44 15 0 -1.7322835 -10 0 -6.7322835 -15 0.05094856 GW 79 25 -4.1338583 -0.3937008 15 -4.1338583 -12.440945 15 0.1875 GW 80 25 -4.1338583 0.39370079 15 -4.1338583 12.4409449 15 0.1875 GW 81 25 -4.1338583 0.39370079 -15 -4.1338583 12.4409449 -15 0.1875 GW 82 25 -4.1338583 -0.3937008 -15 -4.1338583 -12.440945 -15 0.1875 GW 84 25 -4.1338583 0.39370079 2.5 -4.1338583 12.007874 2.5 0.1875 GW 85 25 -4.1338583 -0.3937008 2.5 -4.1338583 -12.007874 2.5 0.1875 GW 86 25 -4.1338583 0.39370079 7.5 -4.1338583 12.4409449 7.5 0.1875 GW 87 25 -4.1338583 -0.3937008 7.5 -4.1338583 -12.440945 7.5 0.1875 GW 88 25 -4.1338583 0.39370079 -2.5 -4.1338583 12.007874 -2.5 0.1875 GW 89 25 -4.1338583 -0.3937008 -2.5 -4.1338583 -12.007874 -2.5 0.1875 GW 90 25 -4.1338583 0.39370079 -7.5 -4.1338583 12.4409449 -7.5 0.1875 GW 91 25 -4.1338583 -0.3937008 -7.5 -4.1338583 -12.440945 -7.5 0.1875 GW 103 13 0 6.73228346 15 0 12.3228346 15 0.05094856 GW 104 13 0 -6.7322835 15 0 -12.322835 15 0.05094856 GW 106 13 0 6.73228346 -15 0 12.3228346 -15 0.05094856 GW 107 13 0 -6.7322835 -15 0 -12.322835 -15 0.05094856 GW 138 29 0 -14 15.5 0 0 15.5 0.0511811 GW 142 29 0 0 15.5 0 14 15.5 0.0511811 GW 139 29 0 -14 -15.5 0 0 -15.5 0.0511811 GW 143 29 0 0 -15.5 0 14 -15.5 0.0511811 GW 144 23 -10 14 15.5 -10 -14 15.5 0.1875 GW 145 23 -10 14 -15.5 -10 -14 -15.5 0.1875 GW 146 3 0 -1.7322835 0 0 1.73228346 0 0.01 GS 0 0 0.0254 ' All in in. GE 0 EK EX 0 146 2 0 1 0 GN -1 FR 0 38 0 0 473 6 RP 0 1 10 1510 90. 0. 0. 20. 0. 0.
My SBGH/DBGH Gen I & II Plans are in the sticky at the top of this forum Last edited by stampeder; 2009-01-14 at 02:02 PM. Reason: Now in its own thread |
I like it. Two reflectors. Is the 10" max? My starting points would have been 9" or 11.25".
Yeah, for channels 10 to 13. For channels 7 to 9, it would be a little more.
My SBGH/DBGH Gen I & II Plans are in the sticky at the top of this forum |
And as expected, a nice healthy increase in gain with the DBGH version. This puts it near the top of the VHF-Hi antenna gain chart for the design range of channels 10 to 13, and still at the top of the UHF range, per HDPrimer.com.
The dimensions of this DBGH are a compact 28 inches wide by 66 inches high by 10 inches deep. CH Raw Gain dBi SWR -- ------------ --- 07 06.82 12.5 (8.71 dBi at 180 degrees) 08 07.63 3.94 (7.96 dBi at 180 degrees) 09 08.74 1.77 10 11.6 1.65 11 11.8 2.35 12 11.3 2.16 13 10.8 1.89 3D picture of DBGH : UHF Raw Gain and SWR of this DBGH : And the NEC file : Code:
CE GW 30 15 0 1.73228346 0 0 6.73228346 5 0.05094856 GW 31 15 0 1.73228346 10 0 6.73228346 5 0.05094856 GW 32 15 0 1.73228346 10 0 6.73228346 15 0.05094856 GW 34 15 0 -1.7322835 0 0 -6.7322835 5 0.05094856 GW 35 15 0 -1.7322835 10 0 -6.7322835 5 0.05094856 GW 36 15 0 -1.7322835 10 0 -6.7322835 15 0.05094856 GW 38 15 0 1.73228346 0 0 6.73228346 -5 0.05094856 GW 39 15 0 1.73228346 -10 0 6.73228346 -5 0.05094856 GW 40 15 0 1.73228346 -10 0 6.73228346 -15 0.05094856 GW 42 15 0 -1.7322835 0 0 -6.7322835 -5 0.05094856 GW 43 15 0 -1.7322835 -10 0 -6.7322835 -5 0.05094856 GW 44 15 0 -1.7322835 -10 0 -6.7322835 -15 0.05094856 GW 79 25 -4.1338583 -0.3937008 15 -4.1338583 -12.440945 15 0.1875 GW 80 25 -4.1338583 0.39370079 15 -4.1338583 12.4409449 15 0.1875 GW 81 25 -4.1338583 0.39370079 -15 -4.1338583 12.4409449 -15 0.1875 GW 82 25 -4.1338583 -0.3937008 -15 -4.1338583 -12.440945 -15 0.1875 GW 84 25 -4.1338583 0.39370079 2.5 -4.1338583 12.007874 2.5 0.1875 GW 85 25 -4.1338583 -0.3937008 2.5 -4.1338583 -12.007874 2.5 0.1875 GW 86 25 -4.1338583 0.39370079 7.5 -4.1338583 12.4409449 7.5 0.1875 GW 87 25 -4.1338583 -0.3937008 7.5 -4.1338583 -12.440945 7.5 0.1875 GW 88 25 -4.1338583 0.39370079 -2.5 -4.1338583 12.007874 -2.5 0.1875 GW 89 25 -4.1338583 -0.3937008 -2.5 -4.1338583 -12.007874 -2.5 0.1875 GW 90 25 -4.1338583 0.39370079 -7.5 -4.1338583 12.4409449 -7.5 0.1875 GW 91 25 -4.1338583 -0.3937008 -7.5 -4.1338583 -12.440945 -7.5 0.1875 GW 103 13 0 6.73228346 15 0 12.3228346 15 0.05094856 GW 104 13 0 -6.7322835 15 0 -12.322835 15 0.05094856 GW 106 13 0 6.73228346 -15 0 12.3228346 -15 0.05094856 GW 107 13 0 -6.7322835 -15 0 -12.322835 -15 0.05094856 GW 138 29 0 -14 15.5 0 0 15.5 0.0511811 GW 142 29 0 0 15.5 0 14 15.5 0.0511811 GW 139 29 0 -14 -15.5 0 0 -15.5 0.0511811 GW 143 29 0 0 -15.5 0 14 -15.5 0.0511811 GW 144 23 -10 14 15.5 -10 -14 15.5 0.1875 GW 145 23 -10 14 -15.5 -10 -14 -15.5 0.1875 GW 147 15 0 1.73228346 35 0 6.73228346 40 0.05094856 GW 148 15 0 1.73228346 45 0 6.73228346 40 0.05094856 GW 149 15 0 1.73228346 45 0 6.73228346 50 0.05094856 GW 150 15 0 -1.7322835 35 0 -6.7322835 40 0.05094856 GW 151 15 0 -1.7322835 45 0 -6.7322835 40 0.05094856 GW 152 15 0 -1.7322835 45 0 -6.7322835 50 0.05094856 GW 153 15 0 1.73228346 35 0 6.73228346 30 0.05094856 GW 154 15 0 1.73228346 25 0 6.73228346 30 0.05094856 GW 155 15 0 1.73228346 25 0 6.73228346 20 0.05094856 GW 156 15 0 -1.7322835 35 0 -6.7322835 30 0.05094856 GW 157 15 0 -1.7322835 25 0 -6.7322835 30 0.05094856 GW 158 15 0 -1.7322835 25 0 -6.7322835 20 0.05094856 GW 159 25 -4.1338583 -0.3937008 50 -4.1338583 -12.440945 50 0.1875 GW 160 25 -4.1338583 0.39370079 50 -4.1338583 12.4409449 50 0.1875 GW 161 25 -4.1338583 0.39370079 20 -4.1338583 12.4409449 20 0.1875 GW 162 25 -4.1338583 -0.3937008 20 -4.1338583 -12.440945 20 0.1875 GW 163 25 -4.1338583 0.39370079 37.5 -4.1338583 12.007874 37.5 0.1875 GW 164 25 -4.1338583 -0.3937008 37.5 -4.1338583 -12.007874 37.5 0.1875 GW 165 25 -4.1338583 0.39370079 42.5 -4.1338583 12.4409449 42.5 0.1875 GW 166 25 -4.1338583 -0.3937008 42.5 -4.1338583 -12.440945 42.5 0.1875 GW 167 25 -4.1338583 0.39370079 32.5 -4.1338583 12.007874 32.5 0.1875 GW 168 25 -4.1338583 -0.3937008 32.5 -4.1338583 -12.007874 32.5 0.1875 GW 169 25 -4.1338583 0.39370079 27.5 -4.1338583 12.4409449 27.5 0.1875 GW 170 25 -4.1338583 -0.3937008 27.5 -4.1338583 -12.440945 27.5 0.1875 GW 171 13 0 6.73228346 50 0 12.3228346 50 0.05094856 GW 172 13 0 -6.7322835 50 0 -12.322835 50 0.05094856 GW 173 13 0 6.73228346 20 0 12.3228346 20 0.05094856 GW 174 13 0 -6.7322835 20 0 -12.322835 20 0.05094856 GW 175 29 0 -14 50.5 0 0 50.5 0.0511811 GW 176 29 0 0 50.5 0 14 50.5 0.0511811 GW 177 29 0 -14 19.5 0 0 19.5 0.0511811 GW 178 29 0 0 19.5 0 14 19.5 0.0511811 GW 179 23 -10 14 50.5 -10 -14 50.5 0.1875 GW 180 23 -10 14 19.5 -10 -14 19.5 0.1875 GW 181 15 1 -1 35 1 -1 17.5 0.05094856 GW 182 15 1 1 35 1 1 17.5 0.05094856 GW 183 15 1 -1 0 1 -1 17.5 0.05094856 GW 184 15 1 1 0 1 1 17.5 0.05094856 GW 185 3 1 -1 17.5 1 1 17.5 0.05094856 GW 186 1 0 1.73228346 35 1 1 35 0.05094856 GW 187 1 0 -1.7322835 35 1 -1 35 0.05094856 GW 188 1 0 -1.7322835 0 1 -1 0 0.05094856 GW 189 1 0 1.73228346 0 1 1 0 0.05094856 GS 0 0 0.0254 ' All in in. GE 0 EK EX 0 185 2 0 1 0 GN -1 FR 0 38 0 0 473 6 RP 0 1 10 1510 90. 0. 0. 20. 0. 0.
Wow, congratulations!
That's one heck of an excellent post-transition broadband TV antenna (VHF-HI channels 7-13 with UHF channels 14-51) Great work, and we all appreciate it! |
Out of curiosity, is there any hope of FM Radio gain, or does it drop off before reaching those lower frequencies?
Probably not, if you want VHF-Hi TV too. Ill see when I calculate the dimensions for the channel 7 to 9 range.
I can see building this DBGH using wulleebullee's 1st build douple pipe pvc method with some mods. I would put some painted pex tubing pieces in the middle to straighten and keep the gap on the uhf reflector rods. Then I would use my snap on pvc tees to hold the NARODs and the NAROD reflectors.
I'm now using your VHF-HI bracket rods (NAROD) with Al.-foil reflector at 15" now all I have to do is add reflector rods in between. Off to scavenge material. It is now 6:30. Up date. Do not tell my wife. I removed a slat from the venetian blinds. At 5 foot cut in half it made the bracket rod reflector. On analog Ch. 11 improved greatly (did not know there was an 11). Digital UHF had side effects(same as with bracket rods only), but what was lost was greatly made up for in VHF-hi.
#9 |
For the channel range 7 to 9, the best NAROD and NAROD reflector length is 31.5 inches, and the best NAROD to NAROD reflector distance is 12.5 inches. NAROD to stub distance is still 1/2 inch for the best compromise between gain and SWR. (FM gain is still less than rabbit ears)
Ill optimize for channel 9 next, which may be a good overall vhf-hi general compromise. DBGH (channel 7 optimized) VHF-Hi raw gain and SWR: CH Raw Gain dBi SWR -- ------------ --- 07 11.48 3.38 08 11.23 3.71 09 10.85 3.21 10 10.46 2.71 11 10.17 2.56 12 09.83 2.82 13 09.53 3.45 DBGH (channel 7 optimized) UHF gain and SWR :
#10 | ||
I have a question about your model. It seems that in order to bring the AGT value down near 1.0, you decreased the radius of the horizontal excited element from about 0.05 inches to 0.01 inches. It is unclear to me how this affects the validity of the model. I have read many times that NEC-2 cannot properly handle models where wires of dissimilar diameters are connected together. For example, the late L. B. Cebik (a widely respected antenna modeler) wrote: Quote:
limitation. Finally, I admire your dedication to this project and appreciate your willingness to help others. You are a real asset to this forum. Thanks, --John |
#11 |
The analog NM from TVFool Ch.11=0.2 pic.-good,Ch.13=-1.7 pic.-fair,Ch.24=-4.3 pic.-fair,Ch30=-8.2 pic.-poor. Ch. that I did not try before.
#12 |
Xauto, what exact dimensions, lengths diameters and spacings, are you using for the NAROD and NAROD reflector ?
#13 | |||
Ill redo the wire sizes and segmentation on the model to see if I still get the same results. Quote:
Also, what are your thoughts on the NAROD ??
#14 |
I want to compliment Xauto for doing the empirical testing side of this new design. Its one thing to see the computer model work that 300ohm has done, but to have Xauto try it out physically in almost real time is invaluable!
#15 |
The slat from the venetian blinds is 29.5"by 1" by 1/64". The concave side is to the rods. The rods(NOROD) are the telescoping rods off of rabbit ears. They are make up of 8" piece tube in tube(largest OD 3/8 to 1/16 rod). Adjusted to 29.5". The space from rod to reflector is 10". The main reflector (Al.-foil 42X30 with hour glass slit 1" center and 3.125"at the ends) space is 15" from the elements. The elements is a fractal so the NOROD's are 34.5" center to center.
| Bookmarks |
| Thread Tools | Search this Thread |
