Hi,
I have just had a Bell 9242 HD PVR installed by Bell. I am running two Standard TV's. Everything is great except the second TV the tech could not get working. It is an old Toshiba that was working fine with a Bell stand alone receiver. This TV only goes up to channel 66 then skips to 94. I have a newer small TV that I took out of our RV that works fine so the receiver is working with two Standard TV's. Any suggestions for how I can get the older Toshiba to work properly? Thanks, |
Have you tried different channels ?
By default, I believe the 2nd tuner is set to output at channel 73, but you can try different channels by changing them in the menu. |
There is a setting for air / cable and channel choices. I have tried a variety of combinations, but so far no luck.....
I have an older TV like this and I could only get it to work by hooking up a VCR. I tuned the VCR to 73 and output on channel 3 or 4 to TV.
I dragged our VCR in and hooked it up....but it also only goes up to ch 69. BUT I switched the signal to air and was able to get some signal. At times the colours are messed up (technical term) and it is not crystal clear, but was able to watch shows... now I guess I have to get a VCR with a tuner....
Have you tried the composite (RCA yellow/white/red) output for TV2 maybe?
We had a similar problem with a newer Samsung TV, since the channels between 70 and 80 are different - they show up as 70-01, 70-02,...80-01
The way we got it to work was to set signal to Air and changed the setting on the receiver for channel 60. Took us a while to figure out that channel 60 would work but it's working great now. |
#8 | |
Malulator Step up meru 6-1-5 satellites two feed each inpuit1 and two input2 both different channelHD PVR PLUS 9242 two tube or one hdtv one rca off input1 one tv remontr e either air or digital channel your choose tv different channel5-1ooo MHz DS2DGH10 120 EMI ISOLATION TWO WAY SPLITTER TWO TV SPEATER TV TWO CABLE CHANNEL OR I have 3 way splitter mult tv Hans |
#9 |
Hans, what are you trying to say.?
#10 |
+1 ^^^^ my oh my!
#11 |
#12 |
That is a very good point.
#13 |
I think someone is sending an encrypted messages to a friend in jail or they work for NASA.
#14 |
Dormant terrorist cell you think?
