Creating a "Favourites" list - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw Cable HD tuner and HD PVR Discussion
Old 2009-01-10, 10:20 AM   #1
punman
Default Creating a "Favourites" list
I created a favourites list one channel at a time - took forever.
Is there a short-cut way where you can select all channels at once and then delete some?
punman is offline
Old 2009-01-10, 11:02 AM   #2
Dr.Dave
The fastest way to create a Favourites List is to press "Settings" twice, go to "setup", then "Favourite Lists Setup". If you go through and click on the heart icon, you can add or delete a channel with a single click.
One thing that may not be immediately obvious is that that the default sequence is by name and you can change it to number by pressing the <right> button.
Dr.Dave is offline
Old 2009-01-10, 11:10 AM   #3
punman
Can the default be changed to channel number?
punman is offline
Old 2009-01-10, 11:55 AM   #4
Dr.Dave
I'm talking about the channel list when you do the favourites setup so presumably this won't be done too often. The favourites in the guide are in numerical order.
Dr.Dave is offline
Forum Sponsor
