PCM Output for DCT 6412 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw Cable HD tuner and HD PVR Discussion
Old 2008-12-08, 05:37 PM   #1
wpope
Default PCM Output for DCT 6412
I recently purchased an outboard DAC that can only process PCM audio signals. I have tried to set up my box for PCM output through an optical cable to the DAC, but have had no luck so far. Any suggestions? Thanks.
wpope is offline
Old 2008-12-08, 06:00 PM   #2
magnet
Are you able to try the orange RCA_style coaxial digital audio out jack on the rear of the DCT?
When it comes to humility, I am the greatest!
magnet is offline
Old 2008-12-09, 12:07 PM   #3
Shaw Guru
Location: BC. Shaw Cable, 42" Samsung DLP, 6416 w/expander & DCX3400
If you hook up an HDMI cable I believe the option comes up for additional HDMI settings in the user Setting screen (power + menu) and there is an LPCM option.
Designated Shaw Employee representative for Cable & Digital Cable for Digital Home Forums.
Shaw Guru is offline
Old 2008-12-09, 12:23 PM   #4
wpope
Red face What I've Tried...
Thanks for the suggestions. I've tried both optical and coaxial connections to no avail, and have set the menu to L-PCM, but still no signal that works with my DAC.
wpope is offline
Old 2008-12-09, 04:53 PM   #5
JesseJ
Location: Calgary, Shaw Digital HD Plus, 3416 & Expander
I'm pretty sure the boxes only output Dolby. The PCM will be via HDMI only, not the coax or optical connections.
SHAW 2012 HD Count: +8 (51 Total not counting SC or SNETWorld)
JesseJ is offline
Forum Sponsor
