SA3250 Remote - 6 pin connector - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Rogers Communications > Rogers Cable TV
Old 2008-12-01, 12:27 AM   #1
MapMaker
Question SA3250 Remote - 6 pin connector
Just replaced the batteries in my SA3250's (5 button) remote and noticed a 6 pin connector above the batteries. It is labeled "JP 1.3" on the circuitboard.
Idle curiosity prompts me to ask what this is for. Does anyone know:
1) what this is for?
2) where to find the answer to this?
I checked the manual -- nothing.
I did a search here -- I never seem to find anything I search for here maybe my terms are wrong?
MapMaker is offline
Old 2008-12-01, 08:39 AM   #2
gnunn
It is a JP1 connector, it allows for detailed customization of the remote from a PC providing you get or make the right cable. Many moons ago I spent quite a bit of time programming a JP1 radio shack remote. It was fun but quite a bit more work then just buying a Harmony.
See here for more detailed info on JP1:
http://www.hifi-remote.com/jp1
gnunn is offline
Old 2008-12-01, 10:10 AM   #3
I did a search for the term "JP1*" and found several threads. Here's an example:
http://www.digitalhome.ca/forum/show...ghlight=JP1%2A
Here's a thread that contains search tips and other useful info:
57 is offline
Old 2008-12-01, 11:10 PM   #4
MapMaker
Thanks for the suggestions 57. The trouble in searching is that you need to know what you are looking for...
In this particular case I searched for various combinations of the words "Remote, Attachment, Plug, SA3250" and got "Sorry - no matches. Please try some different terms." each time.
I really didn't think the term "JP 1.3" (with a space between P and 1 as I quoted in the OP) was relevant to my question but I just tried it now, and got the same "Sorry - no..."
There is no way that I would have thought to look for "JP1*" or even for "jp1.3" without the space that's on the circuit board. These are the only searches that give me any hits at all.
Now I am going to read a bit and try to figure out what a JP1 remote is.
MapMaker is offline
Old 2008-12-02, 12:06 AM   #5
1. Make sure you don't have the commas in your searches.
2. When searching try to put asterisks at the start and end of terms that can vary. For example *3250* will find SA3250, SA3250HD, 3250HD, etc. For attachment used attach*, etc.
57 is offline
Old 2008-12-02, 01:14 PM   #6
MapMaker
No, I didn't put commas I just used those words in different combinations.
I think you may have put your finger on it though...Are you saying that if I only search for "attach" without the asterisk, I will NOT find "attachment"?
MapMaker is offline
Old 2008-12-02, 01:35 PM   #7
Please take the time to read the search tips I already provided in my previous link (the second link of post 3 has search tips, as does the following:
http://www.digitalhome.ca/forum/showthread.php?t=82710
I think you can answer the question about "attach" for yourself.
57 is offline
