I'm getting ready to buy my first HDTV, and I'm still uncertain whether to go plasma or LCD. One of the reasons I'm leaning towards LCD is that I don't like stretching 4:3 signal...it makes things look weird. However, is this something you get used to over time? I'd hate to buy an LCD and find I stretch the programming anyways!
I'd appreciate any comments. |
Stretching or not the 4:3 signal has nothing do with whether you get an LCD or Plasma. It is a choice you make - not tied to the technology. You can scratch that decision point off your checklist.
I totally disagree.
Plasmas have superior picture quality but you should be prepared to change some viewing habits that are bad for plasmas. You can watch anything you want but it has to be sensible and some sort of moderation should be observed. For the OP, you probably will get used to the various stretch modes (search them on this site!); you can also quickly get used to a little less quality in LCDs as well. Afterall, they aren't that bad, just different, it is 'bad' if you have an LCD and plasma side by side
LG55LW5000/Denon3313/MirageOMD5+Nanosat+MM8/ClearStream2/CM7778+3414 SSGPN50A550/OptomaHD33/Onkyo717/KEF3005/Velo15" |
#4 | |
Panasonic TH-42PE7U plasma, Toshiba HD-D3, PS3, Shaw DCX3400, Yamaha HTR-6160, Polk 6.1, Belkin PF30, Harmony 700 |
Going LCD is a no brainier.
No worries of burn in. LCD's have less power consumption. The matte finish on the LCD screen has no reflections, plasmas have glass screen. Plasmas also run hot so you'll likely notice the temperature of the room increase (which could be a good thing) Only advantage Plasmas have is that they will have a better black, but most LCD's sold today are very close to the quality of Plasma black reproduction. With either LCD or Plasma you decide to buy, make sure you stay with a 1080p TV. Most LCD's are 1080p but Plasmas are 720p or 1080p. |
That's what I mean...be sensible, like what you're doing is probably ok.
I always stretch 4:3 to fullscreen, I got used to in watching 2 years of analog cable (16:9 full screen) on an old 27" Viewsonic LCD without any fancy stretch modes way so my expectation is low. I actually really like the Horizon stretch mode on my LG plasma but my newer Samsung doesn't have it. OTOH, the Sammy has a wide-stretch for 4:3 contents from 720p/1080i DTV so I like to use it. I can't stand watching 2.35:1 movies vertically stretched to fill the screen so I watch with black bars on top and bottom...But I switch my desktop icons and I autohide my taskbar and use a grey homogeneous desktop background with my HTPCs connected to plasmas. I am a little more anal about it because the my LG is terrible in image retention, so I go all out and even bend over sometimes to avoid IR - which is essentially the same drills for avoiding burn-in.
#7 | |
It goes away wthin 15-30 minutes but I want to point out it is not immune.
#8 | |
dscott01, your entire post is full of errors and misconceptions, but the one that stood out...
#9 |
Size for size LCD is more expensive than Plasma. I never liked the image on an LCD. Plasma are much more pleasing to the eye. Image retention is no longer a real issue as they have techniques to address this and with more and more HD content it is really becoming a non-issue.
Decide what you want but don't worry about 4:3 and stretching. Look at other factors like cost, power consumption, picture quality, light in the room etc. |
#10 | |
Plasmas have superior black levels. LCDs produce pretty bad blacks that look grey in dark rooms. This is due to that dreaded backlight that is always on. Plasmas are excellent for gaming. I pay 3-6 hours straight on my 50" Samsung plasma after a 200 hour break-in period and I have SLIGHT image retention that usually goes away within 20 minutes. Plasmas have a fast response rate and almost no image blur. My LCD is horrible for watching sports and for fast paced motion. That is why I bought a plasma. Plasmas display SD (Standard Def) a lot better than LCD's. LCD's suck at upscaling content. SD looks a lot better on my 50" plasma than it does on my 32" LCD. Plasmas don't produce as much heat as LCDs. My plasma runs at 32C, my LCD runs at 77C... a HUGE difference! I can touch my plasma with my hand and its fine. I cannot touch my LCD after being on for more than 45 mins. I bet if I cracked an egg over my LCD, we wouldn't need a frying pan! So.. GET A PLASMA! You'll be glad you did. As long as you do proper break-in period. You will NEVER get burn in, and you will get minor IR (Image retention). I used to be a LCD fan till I realized how much better Plasams are. I belive I am not biased as I have experienced both technologies and I strongly prefer one over the other. Hope this helps. |
#11 | |
Ohmagic, you should unplug your LCD immediately and have it looked at. If its reaching 77C there is something wrong with your LCD. 77C is a fire hazard. BrianJR do some research and you'll find all the information you need to make a choice on what type of display will work best for you. |
#12 |
Most plasmas do get hotter than LCD's. I know because I repair them for a living. The newer plasmas also have anti-glare screens on some of their models. My professional opinion is that both LCD and Plasma are very close in picture quality. It all comes down to which TV you think looks better, or which one has a better remote, or which brand you like etc.
#13 |
Never stretch!! I hate distortion. Shouldn't be allowed.
ohmagic, as you are trying to clear up mis-information, you're passing on more. LCD's have come a long way on black level. Ecery manufaturer worth mentioning has some sort of dynamic back lite so no, its not always on. They all have different qutesy names for thier systems but the effects are the same, backlight is severly reduced with low level.
#14 |
We do not stretch. We watch everything in its native aspect ratio. We bought a 56" screen set so that the "native" mode will always look big.
#15 |
I use stretch to watch women facing sideways.
