When I first hooked up my terminal,the SHAW guide would be in widescreen format when on SD or HD channels.After a firmware update the guide shows as 4:3 when tuned to HD, but stretches to fill the 16:9 screen when on SD. I presume the guide is to be 4:3 natively.Is there a way to keep it stretched to fill the screen? In the menu i have checked TV type 16:9,and resolution settings are at 1080p for YPBR.Any info?
Location: BC. Shaw Cable, 42" Samsung DLP, 6416 w/expander & DCX3400
The guide is 4:3 format and to the best of our knowledge on my TV it has never been full screen when on an HD channel. Sorry.
Designated Shaw Employee representative for Cable & Digital Cable for Digital Home Forums. |
Which box do you have?
Its the 6200 I believe.
Ya its always been 4:3 on all the others i've seen,but I did have it at 16:9 in the beginning,but I really don't know how?! Thanks |
Did you have your TV set to stretched for SD and you were looking at the guide from an SD channel?
If the YPbPr setup option allows for 480i/p, then perhaps that was the setting you were using before the last firmware update? The TV would then have stretched the HD channels if you have the TV set to a stretch mode?
It would be nice if the "screen saver" was 16:9 at least...
I have the same issue but opposite.
On HD channels the guide shows as 4:3 with black bars on the side. (I like it this way) When I switch to a SD channel it stretchs the guide to fill the screen. (I DON'T like this) Any way to fix this and keep is NON-stretched all the time? |
#9 |
I believe you would have to change your 4:3 Override in the USer Settings to 480i or 480P which could cause other issues.
