Hello,
I have these light fixture in dining room (I think it is called chandelier) with about 8 x 40 watt incandescent bulbs on a dimmable switch. Is it okay to replace some of these incandescent bulbs with CFL lamps? What will happen if I dim the chandelier, will it still dim the remaining incandescent bulbs, what will happen on the CFL lamps? Thank yoiu, Jun |
You have to use special CFL's called "dimmable CFL"s
However they don't work like traditional bulbs - they'll dim in stages rather than a gradual dimming. |
Do not, and I repeat do not try regular CFLs with a dimmer. My father-in-law did, and they blew very quickly.
If you search for "CFL* dimmer" (or similar), you'll find several previous threads on this topic.
http://www.digitalhome.ca/forum/show...=cfl%2A+dimmer
a lot of people do not know the concequences of using CFLs with dimmers. they start to buzz when you dim them and can burn out or cause a fire i heard
