Hi there, I live in Vaughan which is above Toronto. I have rogers and will be getting their HD box soon. I see on their site they have about 3 different models. does anyone know which one i'd get? or do i get to choose?
Location: Toronto, Rogers, SA8300HD + 640GB external drive. Samsung LCD LN40A750 1080p 120Hz. Blu-Ray BD-P1500
Your only choice will be whether you want just an HD box, or an HD box including a PVR so you can record shows. The latter obviously costs more.
then why do they show you 3 options on this site?
http://www.rogershelp.com/DigitalCab...ry.php?id=YV-G |
velocci Thanks for the link, but it contains some pretty old STBs.
I'd suggest that you request either an SA4250HD (STB - which is not included in your link) or an SA8300HD (PVR) since they're the latest models - and yes you can usually request, or pick up from a Rogers outlet.
what's an OP?
Original poster, but I edited my post
#7 | |
That is one to avoid - but you need to be specific when renting, and look at the box. If you just ask for a hidef PVR, they may give you whatever they have the most of in stock at that moment. I failed to actually read the box I was given, and didn't find out that I had the 8000 until I got home and opened the box. |
Before you pick up HD box, call up Rogers & tell them you recently purchased a new TV
They will ask you for a coupon number (just bs a bit trying to "find" it on your receipt) They dont really care as its only tracking to comp the store you bought tv from; they will give you a free HD box (12 months promo) or HD PVR (6 months) and the normal HD TV pack (12 months) |
