Unusual VHF high band antenna - Canadian TV, Computing and Home Theatre Forums
Old 2008-05-20, 02:51 AM   #1
300ohm
Default Unusual VHF high band antenna
Autofils,
I know youre working on a VHF high band antenna. Have you seen this one ? It claims 14 db on channels 6 to 12 (7 to 13 Americas). Whats kind of unusual about it is that the driven element is a horizontal folded dipole and its on the other side (bottom) of the boom than the directors are on. Plus the backwards corner reflector, and that it needs additional mast support.
Features Specifications
F-Type High Performance Balun
Snap out reflectors
Stainless Steel screws on connection points
Designed and tested for digital/analogue reception
Heavy Duty construction on all components
12mm extruded aluminium heavy duty elements
Tough powder coated finish
UV stabilised plastics
Bifurcated rivets - Strongest in the industry
U-bolts & Clamps fitted VHF
Elements 18
Band 3
Channels 6-12
Forward Gain 14 dB
Front to Back Ratio >20 dB
Brand new current model
http://www.academytv.com.au/prod468.htm
300ohm is offline
OTA Forum Sponsor
