Samsung BD P1500 firmware update - Page 5 - Canadian TV, Computing and Home Theatre Forums
Old 2009-10-08, 10:55 AM   #61
Sucubus
Default Firmware installed
via USB and so far no problems. I figured I should do it as the unit is still under warranty.
H550, H890, H1, SA8300, SA8300HD, SA940, PS3 SLIM 250GB, Panny TH42PX60U, Prima PS3227, Sammy BDP1500, Toshiba HDA3
Sucubus is offline
Old 2009-10-08, 12:53 PM   #62
JamesK
What audio problems are you experiencing? In my BD-P1600, I get occasional bursts of noise, when I'm using the remote. The audio is fine when actually playing the disk. This problem appears to have started when I updated the firmware a couple of months ago. The player connects via HDMI to my Sharp Aquos HDTV and from there via optical cable to my A/V receiver.
JamesK is online now
Old 2009-10-09, 12:28 AM   #63
PrinceLH
Now, if we could only get Samsung to do a firmware update on the UP5000, then I would be happy.
PrinceLH is online now
Old 2009-11-06, 08:28 PM   #64
Tom.F.1
The good news is the Update worked and Crank2 finally played, no problem. The bad news is that was the worst movie i've seen in a long time.
Samsung TV, Pio-Elite AVR, OppoBD, Wharfedale Speakers, Kicker Subs. Bell EVu, DB-4e OTA:)
Tom.F.1 is online now
Old 2009-11-25, 03:33 PM   #65
Tom
I see that firmware 2.5 is out.
Does this support divx?
Tom
Tom is offline
Old 2010-01-31, 08:57 PM   #66
Sucubus
Default Firmware version 2.6 now available
New firmware out. I updated with USB and had no problems.
Sucubus is offline
Old 2011-01-03, 12:36 PM   #67
4thought
I just tried loading the Oct/10 2.9 firmware via USB. Now nothing plays. If I load a disc, the display shows CLOSE, but the player doesn't react to the play button. Any ideas?
4thought is offline
