#31 |
Thanks, that makes sense about the paint. I was concerned about using spray paint for fear it would interact with the elements in a negative way. Ever since my first build, I always keep the elements off of any wood that I use.
#32 | |
On another note, I noticed that my local Lowes sells the electrical 1/2 inch sch 40 for $1.09 for a 10 ft piece versus $1.69 for a 10 ft piece of water grade 1/2 inch sch 40. And on the electrical sch 40 its marked " for above and below ground use" so that implies outdoor UV durability. So for those 2 reasons I would recommend using it in my SBGH plans instead of the water grade stuff (unless you plan to drink beer from your antenna, heh). It will knock off another $1.20 from my estimate to build the antenna.
#33 | ||
Remember to compress your image to 100K or less for 56K modem users. Quote:
My builds/plans (not the latest models) are located here. Last edited by 300ohm; 2008-08-05 at 02:31 AM. |
#34 |
Hi Folks,
You folks have really caught on fire since Autofils project update back on August 3, 2008 (see http://www.digitalhome.ca/forum/show...t=85987&page=8). So many post in the last two weeks. WOW! I have been over in the "Modeling" thread trying to learn a little bit about 4NEC2. Now, I might be in the first grade. Most of you are in high school. And as for Autofils, I think he is doing post graduate work. Go Autofils Go! The amount of work in first and second generation Gray-Hoverman threads are amazing. I am trying to catch up with you guys, but have a very long ways to go. I was reading one of the earlier post by 300ohm about construction materials. For outside antennas, PVC pipes to support the antenna elements seems to be the standard. For indoor/attic antennas, wood structures are common as it is unlikely to get wet inside. A long time ago before PVC pipes, I remember reading somewhere about that folks boiled white oak members in parafin. Today, I suspect sealing the dry wood supports with polyurithane is good enough??? I am thinking about purchasing 1 1/2" X 3/4" X 8' pine strips to build the supporting structure for the antenna grid. What do you think? I went over to Home Depot today looking at materials to build a Gray Hoverman antenna. Number 6 uninsulated solid copper wire used for grounding looked impressive and it is pretty stiff. I am thinking quarter inch OD copper tubing might be easier to work? What would you recommend? I also looked at nuts and bolt to hold everything together. I am thinking I can get a better electrical connection between the active elements and a 300 to 75 ohm balums by putting copper to copper and compressing the crap out of the connection with a few washers, nuts and bolts. Then I remembered somebody saying how everything metal within one or two wavelengths of the antenna becomes part of the antenna. LOL. Has anybody modeled the nuts and bolts or screws that hold everything together? Oh yes... I found a collection of nylon nuts and bolts. Do you think that would be worth considering or maybe nylon ties would do the trick? Your suggestions and comments are appreciated, DTV Student |
#35 | ||||
My builds/plans (not the latest models) are located here. Last edited by 300ohm; 2008-08-13 at 11:28 PM. |
#36 |
OK, heres my mesh reflector data. It took me a lot of trials to get the mesh version to perform at the level of Autofils 10 pair colinear rod model, his colinear pair version is that good. I tried many different mesh sizes and reflector gap spacings, making the mesh look like the outline of the SBGH GH rod model, and many more options. The best one I came up with (so far, but Im going to build this model) was the curved mesh reflector model with the orig 100mm reflector to element spacing and original 1 inch reflector gap spacing. A flat reflector of this size gave about 1db less gain. Increasing the reflector gap spacing resulted in that dip in the gain curve getting deeper in that ch 31-32 area with no increase in gain with the mesh models. The original reflector to element spacing also gave the best gain on the mesh. The elements are also bent forward 1 inch (the stub end bent forward an additional 1/2 inch)Top net gain is at (ch 35-36) 602 Mhz 16.0329 dbi (raw gain 16.13 dbi). Bottom net gain on the chart is at 692 Mhz 6.49 dbi (raw gain 8.33 dbi). So if you have channels above 45 that you want, you would be better off building a different, smaller version. Also this thing is large, the DBGH version of it will be a monster, heh.
The charts are with an AGT test of 1.0 and no segment or geometry errors. A 3D picture of the model : ![]() The Gain Curve Chart : ![]() The Standing Wave Ratio Curve Chart: ![]() The Impedence Curve Chart: ![]() And the nec file : Darn, I cant post the nec file because of the forums 17,500 character limit. The nec file is 32,300+ characters. So Ill split it into 2 posts. Heres the beginning to Tag 600 : CM SBGH Gen2 GH10 2X4 Curved Mesh Reflector CM 1 inch Bent Forward Elements, (1 1/2" for stubs) 1 inch Reflector Gap CM 100mm Reflector to Element Spacing CM 10 gauge Copper Wire, Element dimensions per GH10 plans CE GW 1 9 3.94 -1.8701575 0 3.94 1.87 0 0.03543307 GW 2 19 3.94 1.87 0 4.94 8.28732282 6.417323 0.05094856 GW 3 19 4.94 8.28732282 6.417323 3.94 1.87 12.834646 0.05094856 GW 4 19 3.94 1.87 12.834646 4.94 8.28732282 19.251969 0.05094856 GW 5 9 4.94 8.28732282 19.251969 5.44 11.9881102 19.251969 0.05094856 GW 6 19 3.94 1.87 0 4.94 8.28732282 -6.417323 0.05094856 GW 7 19 4.94 8.28732282 -6.417323 3.94 1.87 -12.834646 0.05094856 GW 8 19 3.94 1.87 -12.834646 4.94 8.28732282 -19.251969 0.05094856 GW 9 9 4.94 8.28732282 -19.251969 5.44 11.9881102 -19.251969 0.05094856 GW 10 19 3.94 -1.8701575 0 4.94 -8.2874803 6.417323 0.05094856 GW 11 19 4.94 -8.2874803 6.417323 3.94 -1.8701575 12.834646 0.05094856 GW 12 19 3.94 -1.8701575 12.834646 4.94 -8.2874803 19.251969 0.05094856 GW 13 9 4.94 -8.2874803 19.251969 5.44 -11.988267 19.251969 0.05094856 GW 14 38 3.94 -1.8701575 0 4.94 -8.2875 -6.417323 0.05094856 GW 15 38 4.94 -8.2875 -6.417323 3.94 -1.8701575 -13 0.05094856 GW 16 19 3.94 -1.8701575 -13 4.94 -8.2874803 -19.25 0.05094856 GW 17 9 4.94 -8.2874803 -19.25 5.44 -11.988267 -19.251969 0.05094856 GW 34 9 0 -6 31 0 -2 31 0.05095079 GW 36 9 0 2 31 0 6 31 0.05095079 GW 37 9 0 6 31 0.5 10 31 0.05095079 GW 38 9 0.5 10 31 1.5 14 31 0.05095079 GW 39 9 1.5 14 31 3.5 18 31 0.05095079 GW 46 9 0 -6 29 0 -2 29 0.05095079 GW 48 9 0 2 29 0 6 29 0.05095079 GW 49 9 0 6 29 0.5 10 29 0.05095079 GW 50 9 0.5 10 29 1.5 14 29 0.05095079 GW 51 9 1.5 14 29 3.5 18 29 0.05095079 GW 52 9 3.5 18 29 5.5 22 29 0.05095079 GW 58 9 0 -6 27 0 -2 27 0.05095079 GW 60 9 0 2 27 0 6 27 0.05095079 GW 61 9 0 6 27 0.5 10 27 0.05095079 GW 62 9 0.5 10 27 1.5 14 27 0.05095079 GW 63 9 1.5 14 27 3.5 18 27 0.05095079 GW 64 9 3.5 18 27 5.5 22 27 0.05095079 GW 70 9 0 -6 25 0 -2 25 0.05095079 GW 72 9 0 2 25 0 6 25 0.05095079 GW 73 9 0 6 25 0.5 10 25 0.05095079 GW 74 9 0.5 10 25 1.5 14 25 0.05095079 GW 75 9 1.5 14 25 3.5 18 25 0.05095079 GW 76 9 3.5 18 25 5.5 22 25 0.05095079 GW 82 9 0 -6 23 0 -2 23 0.05095079 GW 84 9 0 2 23 0 6 23 0.05095079 GW 85 9 0 6 23 0.5 10 23 0.05095079 GW 86 9 0.5 10 23 1.5 14 23 0.05095079 GW 87 9 1.5 14 23 3.5 18 23 0.05095079 GW 88 9 3.5 18 23 5.5 22 23 0.05095079 GW 94 9 0 -6 21 0 -2 21 0.05095079 GW 96 9 0 2 21 0 6 21 0.05095079 GW 97 9 0 6 21 0.5 10 21 0.05095079 GW 98 9 0.5 10 21 1.5 14 21 0.05095079 GW 99 9 1.5 14 21 3.5 18 21 0.05095079 GW 100 9 3.5 18 21 5.5 22 21 0.05095079 GW 106 9 0 -6 19 0 -2 19 0.05095079 GW 108 9 0 2 19 0 6 19 0.05095079 GW 109 9 0 6 19 0.5 10 19 0.05095079 GW 110 9 0.5 10 19 1.5 14 19 0.05095079 GW 111 9 1.5 14 19 3.5 18 19 0.05095079 GW 112 9 3.5 18 19 5.5 22 19 0.05095079 GW 118 9 0 -6 17 0 -2 17 0.05095079 GW 120 9 0 2 17 0 6 17 0.05095079 GW 121 9 0 6 17 0.5 10 17 0.05095079 GW 122 9 0.5 10 17 1.5 14 17 0.05095079 GW 123 9 1.5 14 17 3.5 18 17 0.05095079 GW 124 9 3.5 18 17 5.5 22 17 0.05095079 GW 130 9 0 -6 15 0 -2 15 0.05095079 GW 132 9 0 2 15 0 6 15 0.05095079 GW 133 9 0 6 15 0.5 10 15 0.05095079 GW 134 9 0.5 10 15 1.5 14 15 0.05095079 GW 135 9 1.5 14 15 3.5 18 15 0.05095079 GW 136 9 3.5 18 15 5.5 22 15 0.05095079 GW 142 9 0 -6 13 0 -2 13 0.05095079 GW 144 9 0 2 13 0 6 13 0.05095079 GW 145 9 0 6 13 0.5 10 13 0.05095079 GW 146 9 0.5 10 13 1.5 14 13 0.05095079 GW 147 9 1.5 14 13 3.5 18 13 0.05095079 GW 148 9 3.5 18 13 5.5 22 13 0.05095079 GW 150 9 5.5 -22 11 3.5 -18 11 0.05095079 GW 151 9 3.5 -18 11 1.5 -14 11 0.05095079 GW 152 9 1.5 -14 11 0.5 -10 11 0.05095079 GW 153 9 0.5 -10 11 0 -6 11 0.05095079 GW 154 9 0 -6 11 0 -2 11 0.05095079 GW 156 9 0 2 11 0 6 11 0.05095079 GW 157 9 0 6 11 0.5 10 11 0.05095079 GW 158 9 0.5 10 11 1.5 14 11 0.05095079 GW 159 9 1.5 14 11 3.5 18 11 0.05095079 GW 160 9 3.5 18 11 5.5 22 11 0.05095079 GW 162 9 5.5 -22 9 3.5 -18 9 0.05095079 GW 163 9 3.5 -18 9 1.5 -14 9 0.05095079 GW 164 9 1.5 -14 9 0.5 -10 9 0.05095079 GW 165 9 0.5 -10 9 0 -6 9 0.05095079 GW 166 9 0 -6 9 0 -2 9 0.05095079 GW 168 9 0 2 9 0 6 9 0.05095079 GW 169 9 0 6 9 0.5 10 9 0.05095079 GW 170 9 0.5 10 9 1.5 14 9 0.05095079 GW 171 9 1.5 14 9 3.5 18 9 0.05095079 GW 172 9 3.5 18 9 5.5 22 9 0.05095079 GW 174 9 5.5 -22 7 3.5 -18 7 0.05095079 GW 175 9 3.5 -18 7 1.5 -14 7 0.05095079 GW 176 9 1.5 -14 7 0.5 -10 7 0.05095079 GW 177 9 0.5 -10 7 0 -6 7 0.05095079 GW 178 9 0 -6 7 0 -2 7 0.05095079 GW 180 9 0 2 7 0 6 7 0.05095079 GW 181 9 0 6 7 0.5 10 7 0.05095079 GW 182 9 0.5 10 7 1.5 14 7 0.05095079 GW 183 9 1.5 14 7 3.5 18 7 0.05095079 GW 184 9 3.5 18 7 5.5 22 7 0.05095079 GW 186 9 5.5 -22 5 3.5 -18 5 0.05095079 GW 187 9 3.5 -18 5 1.5 -14 5 0.05095079 GW 188 9 1.5 -14 5 0.5 -10 5 0.05095079 GW 189 9 0.5 -10 5 0 -6 5 0.05095079 GW 190 9 0 -6 5 0 -2 5 0.05095079 GW 192 9 0 2 5 0 6 5 0.05095079 GW 193 9 0 6 5 0.5 10 5 0.05095079 GW 194 9 0.5 10 5 1.5 14 5 0.05095079 GW 195 9 1.5 14 5 3.5 18 5 0.05095079 GW 196 9 3.5 18 5 5.5 22 5 0.05095079 GW 198 9 5.5 -22 3 3.5 -18 3 0.05095079 GW 199 9 3.5 -18 3 1.5 -14 3 0.05095079 GW 200 9 1.5 -14 3 0.5 -10 3 0.05095079 GW 201 9 0.5 -10 3 0 -6 3 0.05095079 GW 202 9 0 -6 3 0 -2 3 0.05095079 GW 204 9 0 2 3 0 6 3 0.05095079 GW 205 9 0 6 3 0.5 10 3 0.05095079 GW 206 9 0.5 10 3 1.5 14 3 0.05095079 GW 207 9 1.5 14 3 3.5 18 3 0.05095079 GW 208 9 3.5 18 3 5.5 22 3 0.05095079 GW 210 9 5.5 -22 1 3.5 -18 1 0.05095079 GW 211 9 3.5 -18 1 1.5 -14 1 0.05095079 GW 212 9 1.5 -14 1 0.5 -10 1 0.05095079 GW 213 9 0.5 -10 1 0 -6 1 0.05095079 GW 214 9 0 -6 1 0 -2 1 0.05095079 GW 216 9 0 2 1 0 6 1 0.05095079 GW 217 9 0 6 1 0.5 10 1 0.05095079 GW 218 9 0.5 10 1 1.5 14 1 0.05095079 GW 219 9 1.5 14 1 3.5 18 1 0.05095079 GW 220 9 3.5 18 1 5.5 22 1 0.05095079 GW 222 9 5.5 -22 -1 3.5 -18 -1 0.05095079 GW 223 9 3.5 -18 -1 1.5 -14 -1 0.05095079 GW 224 9 1.5 -14 -1 0.5 -10 -1 0.05095079 GW 225 9 0.5 -10 -1 0 -6 -1 0.05095079 GW 226 9 0 -6 -1 0 -2 -1 0.05095079 GW 228 9 0 2 -1 0 6 -1 0.05095079 GW 229 9 0 6 -1 0.5 10 -1 0.05095079 GW 230 9 0.5 10 -1 1.5 14 -1 0.05095079 GW 231 9 1.5 14 -1 3.5 18 -1 0.05095079 GW 232 9 3.5 18 -1 5.5 22 -1 0.05095079 GW 234 9 5.5 -22 -3 3.5 -18 -3 0.05095079 GW 235 9 3.5 -18 -3 1.5 -14 -3 0.05095079 GW 236 9 1.5 -14 -3 0.5 -10 -3 0.05095079 GW 237 9 0.5 -10 -3 0 -6 -3 0.05095079 GW 238 9 0 -6 -3 0 -2 -3 0.05095079 GW 240 9 0 2 -3 0 6 -3 0.05095079 GW 241 9 0 6 -3 0.5 10 -3 0.05095079 GW 242 9 0.5 10 -3 1.5 14 -3 0.05095079 GW 243 9 1.5 14 -3 3.5 18 -3 0.05095079 GW 244 9 3.5 18 -3 5.5 22 -3 0.05095079 GW 246 9 5.5 -22 -5 3.5 -18 -5 0.05095079 GW 247 9 3.5 -18 -5 1.5 -14 -5 0.05095079 GW 248 9 1.5 -14 -5 0.5 -10 -5 0.05095079 GW 249 9 0.5 -10 -5 0 -6 -5 0.05095079 GW 250 9 0 -6 -5 0 -2 -5 0.05095079 GW 252 9 0 2 -5 0 6 -5 0.05095079 GW 253 9 0 6 -5 0.5 10 -5 0.05095079 GW 254 9 0.5 10 -5 1.5 14 -5 0.05095079 GW 255 9 1.5 14 -5 3.5 18 -5 0.05095079 GW 256 9 3.5 18 -5 5.5 22 -5 0.05095079 GW 258 9 5.5 -22 -7 3.5 -18 -7 0.05095079 GW 259 9 3.5 -18 -7 1.5 -14 -7 0.05095079 GW 260 9 1.5 -14 -7 0.5 -10 -7 0.05095079 GW 261 9 0.5 -10 -7 0 -6 -7 0.05095079 GW 262 9 0 -6 -7 0 -2 -7 0.05095079 GW 264 9 0 2 -7 0 6 -7 0.05095079 GW 265 9 0 6 -7 0.5 10 -7 0.05095079 GW 266 9 0.5 10 -7 1.5 14 -7 0.05095079 GW 267 9 1.5 14 -7 3.5 18 -7 0.05095079 GW 268 9 3.5 18 -7 5.5 22 -7 0.05095079 GW 270 9 5.5 -22 -9 3.5 -18 -9 0.05095079 GW 271 9 3.5 -18 -9 1.5 -14 -9 0.05095079 GW 272 9 1.5 -14 -9 0.5 -10 -9 0.05095079 GW 273 9 0.5 -10 -9 0 -6 -9 0.05095079 GW 274 9 0 -6 -9 0 -2 -9 0.05095079 GW 276 9 0 2 -9 0 6 -9 0.05095079 GW 277 9 0 6 -9 0.5 10 -9 0.05095079 GW 278 9 0.5 10 -9 1.5 14 -9 0.05095079 GW 279 9 1.5 14 -9 3.5 18 -9 0.05095079 GW 280 9 3.5 18 -9 5.5 22 -9 0.05095079 GW 282 9 5.5 -22 -11 3.5 -18 -11 0.05095079 GW 283 9 3.5 -18 -11 1.5 -14 -11 0.05095079 GW 284 9 1.5 -14 -11 0.5 -10 -11 0.05095079 GW 285 9 0.5 -10 -11 0 -6 -11 0.05095079 GW 286 9 0 -6 -11 0 -2 -11 0.05095079 GW 288 9 0 2 -11 0 6 -11 0.05095079 GW 289 9 0 6 -11 0.5 10 -11 0.05095079 GW 290 9 0.5 10 -11 1.5 14 -11 0.05095079 GW 291 9 1.5 14 -11 3.5 18 -11 0.05095079 GW 292 9 3.5 18 -11 5.5 22 -11 0.05095079 GW 294 9 5.5 -22 -13 3.5 -18 -13 0.05095079 GW 295 9 3.5 -18 -13 1.5 -14 -13 0.05095079 GW 296 9 1.5 -14 -13 0.5 -10 -13 0.05095079 GW 297 9 0.5 -10 -13 0 -6 -13 0.05095079 GW 298 9 0 -6 -13 0 -2 -13 0.05095079 GW 300 9 0 2 -13 0 6 -13 0.05095079 GW 301 9 0 6 -13 0.5 10 -13 0.05095079 GW 302 9 0.5 10 -13 1.5 14 -13 0.05095079 GW 303 9 1.5 14 -13 3.5 18 -13 0.05095079 GW 304 9 3.5 18 -13 5.5 22 -13 0.05095079 GW 306 9 5.5 -22 -15 3.5 -18 -15 0.05095079 GW 307 9 3.5 -18 -15 1.5 -14 -15 0.05095079 GW 308 9 1.5 -14 -15 0.5 -10 -15 0.05095079 GW 309 9 0.5 -10 -15 0 -6 -15 0.05095079 GW 310 9 0 -6 -15 0 -2 -15 0.05095079 GW 312 9 0 2 -15 0 6 -15 0.05095079 GW 313 9 0 6 -15 0.5 10 -15 0.05095079 GW 314 9 0.5 10 -15 1.5 14 -15 0.05095079 GW 315 9 1.5 14 -15 3.5 18 -15 0.05095079 GW 316 9 3.5 18 -15 5.5 22 -15 0.05095079 GW 318 9 5.5 -22 -17 3.5 -18 -17 0.05095079 GW 319 9 3.5 -18 -17 1.5 -14 -17 0.05095079 GW 320 9 1.5 -14 -17 0.5 -10 -17 0.05095079 GW 321 9 0.5 -10 -17 0 -6 -17 0.05095079 GW 322 9 0 -6 -17 0 -2 -17 0.05095079 GW 324 9 0 2 -17 0 6 -17 0.05095079 GW 325 9 0 6 -17 0.5 10 -17 0.05095079 GW 327 9 1.5 14 -17 3.5 18 -17 0.05095079 GW 328 9 3.5 18 -17 5.5 22 -17 0.05095079 GW 330 9 5.5 -22 -19 3.5 -18 -19 0.05095079 GW 331 9 3.5 -18 -19 1.5 -14 -19 0.05095079 GW 332 9 1.5 -14 -19 0.5 -10 -19 0.05095079 GW 333 9 0.5 -10 -19 0 -6 -19 0.05095079 GW 334 9 0 -6 -19 0 -2 -19 0.05095079 GW 336 9 0 2 -19 0 6 -19 0.05095079 GW 337 9 0 6 -19 0.5 10 -19 0.05095079 GW 338 9 0.5 10 -19 1.5 14 -19 0.05095079 GW 339 9 1.5 14 -19 3.5 18 -19 0.05095079 GW 340 9 3.5 18 -19 5.5 22 -19 0.05095079 GW 342 9 5.5 -22 -21 3.5 -18 -21 0.05095079 GW 343 9 3.5 -18 -21 1.5 -14 -21 0.05095079 GW 344 9 1.5 -14 -21 0.5 -10 -21 0.05095079 GW 345 9 0.5 -10 -21 0 -6 -21 0.05095079 GW 346 9 0 -6 -21 0 -2 -21 0.05095079 GW 348 9 0 2 -21 0 6 -21 0.05095079 GW 349 9 0 6 -21 0.5 10 -21 0.05095079 GW 350 9 0.5 10 -21 1.5 14 -21 0.05095079 GW 351 9 1.5 14 -21 3.5 18 -21 0.05095079 GW 352 9 3.5 18 -21 5.5 22 -21 0.05095079 GW 354 9 5.5 -22 -23 3.5 -18 -23 0.05095079 GW 355 9 3.5 -18 -23 1.5 -14 -23 0.05095079 GW 356 9 1.5 -14 -23 0.5 -10 -23 0.05095079 GW 357 9 0.5 -10 -23 0 -6 -23 0.05095079 GW 358 9 0 -6 -23 0 -2 -23 0.05095079 GW 360 9 0 2 -23 0 6 -23 0.05095079 GW 361 9 0 6 -23 0.5 10 -23 0.05095079 GW 362 9 0.5 10 -23 1.5 14 -23 0.05095079 GW 363 9 1.5 14 -23 3.5 18 -23 0.05095079 GW 364 9 3.5 18 -23 5.5 22 -23 0.05095079 GW 366 9 5.5 -22 -25 3.5 -18 -25 0.05095079 GW 367 9 3.5 -18 -25 1.5 -14 -25 0.05095079 GW 368 9 1.5 -14 -25 0.5 -10 -25 0.05095079 GW 369 9 0.5 -10 -25 0 -6 -25 0.05095079 GW 370 9 0 -6 -25 0 -2 -25 0.05095079 GW 372 9 0 2 -25 0 6 -25 0.05095079 GW 373 9 0 6 -25 0.5 10 -25 0.05095079 GW 374 9 0.5 10 -25 1.5 14 -25 0.05095079 GW 375 9 1.5 14 -25 3.5 18 -25 0.05095079 GW 376 9 3.5 18 -25 5.5 22 -25 0.05095079 GW 378 9 5.5 -22 -27 3.5 -18 -27 0.05095079 GW 379 9 3.5 -18 -27 1.5 -14 -27 0.05095079 GW 380 9 1.5 -14 -27 0.5 -10 -27 0.05095079 GW 381 9 0.5 -10 -27 0 -6 -27 0.05095079 GW 382 9 0 -6 -27 0 -2 -27 0.05095079 GW 384 9 0 2 -27 0 6 -27 0.05095079 GW 385 9 0 6 -27 0.5 10 -27 0.05095079 GW 386 9 0.5 10 -27 1.5 14 -27 0.05095079 GW 387 9 1.5 14 -27 3.5 18 -27 0.05095079 GW 388 9 3.5 18 -27 5.5 22 -27 0.05095079 GW 390 9 5.5 -22 -29 3.5 -18 -29 0.05095079 GW 391 9 3.5 -18 -29 1.5 -14 -29 0.05095079 GW 392 9 1.5 -14 -29 0.5 -10 -29 0.05095079 GW 393 9 0.5 -10 -29 0 -6 -29 0.05095079 GW 394 9 0 -6 -29 0 -2 -29 0.05095079 GW 396 9 0 2 -29 0 6 -29 0.05095079 GW 397 9 0 6 -29 0.5 10 -29 0.05095079 GW 398 9 0.5 10 -29 1.5 14 -29 0.05095079 GW 444 5 5.5 -22 -27 5.5 -22 -29 0.05095079 GW 508 5 1.5 -14 -27 1.5 -14 -29 0.05095079 GW 540 5 0.5 -10 -27 0.5 -10 -29 0.05095079 GW 543 5 0 -6 31 0 -6 29 0.05095079 GW 544 5 0 -6 29 0 -6 27 0.05095079 GW 545 5 0 -6 27 0 -6 25 0.05095079 GW 546 5 0 -6 25 0 -6 23 0.05095079 GW 547 5 0 -6 23 0 -6 21 0.05095079 GW 548 5 0 -6 21 0 -6 19 0.05095079 GW 549 5 0 -6 19 0 -6 17 0.05095079 GW 550 5 0 -6 17 0 -6 15 0.05095079 GW 551 5 0 -6 15 0 -6 13 0.05095079 GW 552 5 0 -6 13 0 -6 11 0.05095079 GW 553 5 0 -6 11 0 -6 9 0.05095079 GW 554 5 0 -6 9 0 -6 7 0.05095079 GW 555 5 0 -6 7 0 -6 5 0.05095079 GW 556 5 0 -6 5 0 -6 3 0.05095079 GW 557 5 0 -6 3 0 -6 1 0.05095079 GW 558 5 0 -6 1 0 -6 -1 0.05095079 GW 559 5 0 -6 -1 0 -6 -3 0.05095079 GW 560 5 0 -6 -3 0 -6 -5 0.05095079 GW 561 5 0 -6 -5 0 -6 -7 0.05095079 GW 562 5 0 -6 -7 0 -6 -9 0.05095079 GW 563 5 0 -6 -9 0 -6 -11 0.05095079 GW 564 5 0 -6 -11 0 -6 -13 0.05095079 GW 565 5 0 -6 -13 0 -6 -15 0.05095079 GW 566 5 0 -6 -15 0 -6 -17 0.05095079 GW 567 5 0 -6 -17 0 -6 -19 0.05095079 GW 568 5 0 -6 -19 0 -6 -21 0.05095079 GW 569 5 0 -6 -21 0 -6 -23 0.05095079 GW 570 5 0 -6 -23 0 -6 -25 0.05095079 GW 571 5 0 -6 -25 0 -6 -27 0.05095079 GW 572 5 0 -6 -27 0 -6 -29 0.05095079 GW 575 5 0 -2 31 0 -2 29 0.05095079 GW 576 5 0 -2 29 0 -2 27 0.05095079 GW 577 5 0 -2 27 0 -2 25 0.05095079 GW 578 5 0 -2 25 0 -2 23 0.05095079 GW 579 5 0 -2 23 0 -2 21 0.05095079 GW 580 5 0 -2 21 0 -2 19 0.05095079 GW 581 5 0 -2 19 0 -2 17 0.05095079 GW 582 5 0 -2 17 0 -2 15 0.05095079 GW 583 5 0 -2 15 0 -2 13 0.05095079 GW 584 5 0 -2 13 0 -2 11 0.05095079 GW 585 5 0 -2 11 0 -2 9 0.05095079 GW 586 5 0 -2 9 0 -2 7 0.05095079 GW 587 5 0 -2 7 0 -2 5 0.05095079 GW 588 5 0 -2 5 0 -2 3 0.05095079 GW 589 5 0 -2 3 0 -2 1 0.05095079 GW 590 5 0 -2 1 0 -2 -1 0.05095079 GW 591 5 0 -2 -1 0 -2 -3 0.05095079 GW 592 5 0 -2 -3 0 -2 -5 0.05095079 GW 593 5 0 -2 -5 0 -2 -7 0.05095079 GW 594 5 0 -2 -7 0 -2 -9 0.05095079 GW 595 5 0 -2 -9 0 -2 -11 0.05095079 GW 596 5 0 -2 -11 0 -2 -13 0.05095079 GW 597 5 0 -2 -13 0 -2 -15 0.05095079 GW 598 5 0 -2 -15 0 -2 -17 0.05095079 GW 599 5 0 -2 -17 0 -2 -19 0.05095079 GW 600 5 0 -2 -19 0 -2 -21 0.05095079
My builds/plans (not the latest models) are located here. Last edited by 300ohm; 2008-08-14 at 01:35 AM. |
#37 |
The Curved Mesh Plan Top View:
![]() And a picture of the semi-finished frame minus the mesh and elements: ![]() This will give you an idea of what the finished antenna will look like. The vee bent cross bars serve a couple of purposes. They serve to stiffen the whole structure and will be used to wire tie the stub ends of the 10 gauge copper elements Ill be using. Ill post detailed plans, parts list, cutting lists, and construction how-tos in the following days. Its actually easier than it looks and like my SBGH version 1 plans, its adjustable/upgradable to the DBGH version. The most expensive parts of it are the 4ft by 5ft piece of 2" X 4" mesh and the elements. Ill probably do it in installments, so stay tuned to this thread for more episodes of "This Old Antenna", heh.
My builds/plans (not the latest models) are located here. Last edited by 300ohm; 2008-08-14 at 02:06 AM. |
#38 |
Heh, each line is like an 80 column key-punched Fortran card, can you imagine if you dropped a stack like this, heh. And heres from Tag 601 to the end, hopefully I got it all :
GW 601 5 0 -2 -21 0 -2 -23 0.05095079 GW 602 5 0 -2 -23 0 -2 -25 0.05095079 GW 603 5 0 -2 -25 0 -2 -27 0.05095079 GW 604 5 0 -2 -27 0 -2 -29 0.05095079 GW 607 5 0 2 31 0 2 29 0.05095079 GW 608 5 0 2 29 0 2 27 0.05095079 GW 609 5 0 2 27 0 2 25 0.05095079 GW 610 5 0 2 25 0 2 23 0.05095079 GW 611 5 0 2 23 0 2 21 0.05095079 GW 612 5 0 2 21 0 2 19 0.05095079 GW 613 5 0 2 19 0 2 17 0.05095079 GW 614 5 0 2 17 0 2 15 0.05095079 GW 615 5 0 2 15 0 2 13 0.05095079 GW 616 5 0 2 13 0 2 11 0.05095079 GW 617 5 0 2 11 0 2 9 0.05095079 GW 618 5 0 2 9 0 2 7 0.05095079 GW 619 5 0 2 7 0 2 5 0.05095079 GW 620 5 0 2 5 0 2 3 0.05095079 GW 621 5 0 2 3 0 2 1 0.05095079 GW 622 5 0 2 1 0 2 -1 0.05095079 GW 623 5 0 2 -1 0 2 -3 0.05095079 GW 624 5 0 2 -3 0 2 -5 0.05095079 GW 625 5 0 2 -5 0 2 -7 0.05095079 GW 626 5 0 2 -7 0 2 -9 0.05095079 GW 627 5 0 2 -9 0 2 -11 0.05095079 GW 628 5 0 2 -11 0 2 -13 0.05095079 GW 629 5 0 2 -13 0 2 -15 0.05095079 GW 630 5 0 2 -15 0 2 -17 0.05095079 GW 631 5 0 2 -17 0 2 -19 0.05095079 GW 632 5 0 2 -19 0 2 -21 0.05095079 GW 633 5 0 2 -21 0 2 -23 0.05095079 GW 634 5 0 2 -23 0 2 -25 0.05095079 GW 635 5 0 2 -25 0 2 -27 0.05095079 GW 636 5 0 2 -27 0 2 -29 0.05095079 GW 639 5 0 6 31 0 6 29 0.05095079 GW 640 5 0 6 29 0 6 27 0.05095079 GW 641 5 0 6 27 0 6 25 0.05095079 GW 642 5 0 6 25 0 6 23 0.05095079 GW 643 5 0 6 23 0 6 21 0.05095079 GW 644 5 0 6 21 0 6 19 0.05095079 GW 645 5 0 6 19 0 6 17 0.05095079 GW 646 5 0 6 17 0 6 15 0.05095079 GW 647 5 0 6 15 0 6 13 0.05095079 GW 648 5 0 6 13 0 6 11 0.05095079 GW 649 5 0 6 11 0 6 9 0.05095079 GW 650 5 0 6 9 0 6 7 0.05095079 GW 651 5 0 6 7 0 6 5 0.05095079 GW 652 5 0 6 5 0 6 3 0.05095079 GW 653 5 0 6 3 0 6 1 0.05095079 GW 654 5 0 6 1 0 6 -1 0.05095079 GW 655 5 0 6 -1 0 6 -3 0.05095079 GW 656 5 0 6 -3 0 6 -5 0.05095079 GW 657 5 0 6 -5 0 6 -7 0.05095079 GW 658 5 0 6 -7 0 6 -9 0.05095079 GW 659 5 0 6 -9 0 6 -11 0.05095079 GW 660 5 0 6 -11 0 6 -13 0.05095079 GW 661 5 0 6 -13 0 6 -15 0.05095079 GW 662 5 0 6 -15 0 6 -17 0.05095079 GW 663 5 0 6 -17 0 6 -19 0.05095079 GW 664 5 0 6 -19 0 6 -21 0.05095079 GW 665 5 0 6 -21 0 6 -23 0.05095079 GW 666 5 0 6 -23 0 6 -25 0.05095079 GW 667 5 0 6 -25 0 6 -27 0.05095079 GW 668 5 0 6 -27 0 6 -29 0.05095079 GW 671 5 0.5 10 31 0.5 10 29 0.05095079 GW 672 5 0.5 10 29 0.5 10 27 0.05095079 GW 673 5 0.5 10 27 0.5 10 25 0.05095079 GW 674 5 0.5 10 25 0.5 10 23 0.05095079 GW 675 5 0.5 10 23 0.5 10 21 0.05095079 GW 676 5 0.5 10 21 0.5 10 19 0.05095079 GW 677 5 0.5 10 19 0.5 10 17 0.05095079 GW 678 5 0.5 10 17 0.5 10 15 0.05095079 GW 679 5 0.5 10 15 0.5 10 13 0.05095079 GW 680 5 0.5 10 13 0.5 10 11 0.05095079 GW 681 5 0.5 10 11 0.5 10 9 0.05095079 GW 682 5 0.5 10 9 0.5 10 7 0.05095079 GW 683 5 0.5 10 7 0.5 10 5 0.05095079 GW 684 5 0.5 10 5 0.5 10 3 0.05095079 GW 685 5 0.5 10 3 0.5 10 1 0.05095079 GW 686 5 0.5 10 1 0.5 10 -1 0.05095079 GW 687 5 0.5 10 -1 0.5 10 -3 0.05095079 GW 688 5 0.5 10 -3 0.5 10 -5 0.05095079 GW 689 5 0.5 10 -5 0.5 10 -7 0.05095079 GW 690 5 0.5 10 -7 0.5 10 -9 0.05095079 GW 691 5 0.5 10 -9 0.5 10 -11 0.05095079 GW 692 5 0.5 10 -11 0.5 10 -13 0.05095079 GW 693 5 0.5 10 -13 0.5 10 -15 0.05095079 GW 694 5 0.5 10 -15 0.5 10 -17 0.05095079 GW 695 5 0.5 10 -17 0.5 10 -19 0.05095079 GW 696 5 0.5 10 -19 0.5 10 -21 0.05095079 GW 697 5 0.5 10 -21 0.5 10 -23 0.05095079 GW 698 5 0.5 10 -23 0.5 10 -25 0.05095079 GW 699 5 0.5 10 -25 0.5 10 -27 0.05095079 GW 700 5 0.5 10 -27 0.5 10 -29 0.05095079 GW 703 5 1.5 14 31 1.5 14 29 0.05095079 GW 704 5 1.5 14 29 1.5 14 27 0.05095079 GW 705 5 1.5 14 27 1.5 14 25 0.05095079 GW 706 5 1.5 14 25 1.5 14 23 0.05095079 GW 707 5 1.5 14 23 1.5 14 21 0.05095079 GW 708 5 1.5 14 21 1.5 14 19 0.05095079 GW 709 5 1.5 14 19 1.5 14 17 0.05095079 GW 710 5 1.5 14 17 1.5 14 15 0.05095079 GW 711 5 1.5 14 15 1.5 14 13 0.05095079 GW 712 5 1.5 14 13 1.5 14 11 0.05095079 GW 713 5 1.5 14 11 1.5 14 9 0.05095079 GW 714 5 1.5 14 9 1.5 14 7 0.05095079 GW 715 5 1.5 14 7 1.5 14 5 0.05095079 GW 716 5 1.5 14 5 1.5 14 3 0.05095079 GW 717 5 1.5 14 3 1.5 14 1 0.05095079 GW 718 5 1.5 14 1 1.5 14 -1 0.05095079 GW 719 5 1.5 14 -1 1.5 14 -3 0.05095079 GW 720 5 1.5 14 -3 1.5 14 -5 0.05095079 GW 721 5 1.5 14 -5 1.5 14 -7 0.05095079 GW 722 5 1.5 14 -7 1.5 14 -9 0.05095079 GW 723 5 1.5 14 -9 1.5 14 -11 0.05095079 GW 724 5 1.5 14 -11 1.5 14 -13 0.05095079 GW 725 5 1.5 14 -13 1.5 14 -15 0.05095079 GW 726 5 1.5 14 -15 1.5 14 -17 0.05095079 GW 727 5 1.5 14 -17 1.5 14 -19 0.05095079 GW 728 5 1.5 14 -19 1.5 14 -21 0.05095079 GW 729 5 1.5 14 -21 1.5 14 -23 0.05095079 GW 730 5 1.5 14 -23 1.5 14 -25 0.05095079 GW 731 5 1.5 14 -25 1.5 14 -27 0.05095079 GW 732 5 1.5 14 -27 1.5 14 -29 0.05095079 GW 735 5 3.5 18 31 3.5 18 29 0.05095079 GW 736 5 3.5 18 29 3.5 18 27 0.05095079 GW 737 5 3.5 18 27 3.5 18 25 0.05095079 GW 738 5 3.5 18 25 3.5 18 23 0.05095079 GW 739 5 3.5 18 23 3.5 18 21 0.05095079 GW 740 5 3.5 18 21 3.5 18 19 0.05095079 GW 741 5 3.5 18 19 3.5 18 17 0.05095079 GW 742 5 3.5 18 17 3.5 18 15 0.05095079 GW 743 5 3.5 18 15 3.5 18 13 0.05095079 GW 744 5 3.5 18 13 3.5 18 11 0.05095079 GW 745 5 3.5 18 11 3.5 18 9 0.05095079 GW 746 5 3.5 18 9 3.5 18 7 0.05095079 GW 747 5 3.5 18 7 3.5 18 5 0.05095079 GW 748 5 3.5 18 5 3.5 18 3 0.05095079 GW 749 5 3.5 18 3 3.5 18 1 0.05095079 GW 750 5 3.5 18 1 3.5 18 -1 0.05095079 GW 751 5 3.5 18 -1 3.5 18 -3 0.05095079 GW 752 5 3.5 18 -3 3.5 18 -5 0.05095079 GW 753 5 3.5 18 -5 3.5 18 -7 0.05095079 GW 754 5 3.5 18 -7 3.5 18 -9 0.05095079 GW 755 5 3.5 18 -9 3.5 18 -11 0.05095079 GW 756 5 3.5 18 -11 3.5 18 -13 0.05095079 GW 757 5 3.5 18 -13 3.5 18 -15 0.05095079 GW 758 5 3.5 18 -15 3.5 18 -17 0.05095079 GW 759 5 3.5 18 -17 3.5 18 -19 0.05095079 GW 760 5 3.5 18 -19 3.5 18 -21 0.05095079 GW 761 5 3.5 18 -21 3.5 18 -23 0.05095079 GW 762 5 3.5 18 -23 3.5 18 -25 0.05095079 GW 763 5 3.5 18 -25 3.5 18 -27 0.05095079 GW 764 5 3.5 18 -27 3.5 18 -29 0.05095079 GW 767 5 5.5 22 31 5.5 22 29 0.05095079 GW 768 5 5.5 22 29 5.5 22 27 0.05095079 GW 769 5 5.5 22 27 5.5 22 25 0.05095079 GW 770 5 5.5 22 25 5.5 22 23 0.05095079 GW 771 5 5.5 22 23 5.5 22 21 0.05095079 GW 772 5 5.5 22 21 5.5 22 19 0.05095079 GW 773 5 5.5 22 19 5.5 22 17 0.05095079 GW 774 5 5.5 22 17 5.5 22 15 0.05095079 GW 775 5 5.5 22 15 5.5 22 13 0.05095079 GW 776 5 5.5 22 13 5.5 22 11 0.05095079 GW 777 5 5.5 22 11 5.5 22 9 0.05095079 GW 778 5 5.5 22 9 5.5 22 7 0.05095079 GW 779 5 5.5 22 7 5.5 22 5 0.05095079 GW 780 5 5.5 22 5 5.5 22 3 0.05095079 GW 781 5 5.5 22 3 5.5 22 1 0.05095079 GW 782 5 5.5 22 1 5.5 22 -1 0.05095079 GW 783 5 5.5 22 -1 5.5 22 -3 0.05095079 GW 784 5 5.5 22 -3 5.5 22 -5 0.05095079 GW 785 5 5.5 22 -5 5.5 22 -7 0.05095079 GW 786 5 5.5 22 -7 5.5 22 -9 0.05095079 GW 787 5 5.5 22 -9 5.5 22 -11 0.05095079 GW 788 5 5.5 22 -11 5.5 22 -13 0.05095079 GW 789 5 5.5 22 -13 5.5 22 -15 0.05095079 GW 790 5 5.5 22 -15 5.5 22 -17 0.05095079 GW 791 5 5.5 22 -17 5.5 22 -19 0.05095079 GW 792 5 5.5 22 -19 5.5 22 -21 0.05095079 GW 793 5 5.5 22 -21 5.5 22 -23 0.05095079 GW 794 5 5.5 22 -23 5.5 22 -25 0.05095079 GW 795 5 5.5 22 -25 5.5 22 -27 0.05095079 GW 796 5 5.5 22 -27 5.5 22 -29 0.05095079 GW 829 3 0 -2 31 0 -0.5 31 0.05095079 GW 830 3 0 2 31 0 0.5 31 0.05095079 GW 831 3 0 -2 29 0 -0.5 29 0.05095079 GW 832 3 0 2 29 0 0.5 29 0.05095079 GW 833 3 0 -2 27 0 -0.5 27 0.05095079 GW 834 3 0 2 27 0 0.5 27 0.05095079 GW 835 3 0 -2 25 0 -0.5 25 0.05095079 GW 836 3 0 2 25 0 0.5 25 0.05095079 GW 837 3 0 -2 23 0 -0.5 23 0.05095079 GW 838 3 0 2 23 0 0.5 23 0.05095079 GW 839 3 0 -2 21 0 -0.5 21 0.05095079 GW 840 3 0 2 21 0 0.5 21 0.05095079 GW 841 3 0 -2 19 0 -0.5 19 0.05095079 GW 842 3 0 2 19 0 0.5 19 0.05095079 GW 843 3 0 -2 17 0 -0.5 17 0.05095079 GW 844 3 0 2 17 0 0.5 17 0.05095079 GW 845 3 0 -2 15 0 -0.5 15 0.05095079 GW 846 3 0 2 15 0 0.5 15 0.05095079 GW 847 3 0 -2 13 0 -0.5 13 0.05095079 GW 848 3 0 2 13 0 0.5 13 0.05095079 GW 849 3 0 -2 11 0 -0.5 11 0.05095079 GW 850 3 0 2 11 0 0.5 11 0.05095079 GW 851 3 0 -2 9 0 -0.5 9 0.05095079 GW 852 3 0 2 9 0 0.5 9 0.05095079 GW 853 3 0 -2 7 0 -0.5 7 0.05095079 GW 854 3 0 2 7 0 0.5 7 0.05095079 GW 855 3 0 2 5 0 0.5 5 0.05095079 GW 856 3 0 -2 5 0 -0.5 5 0.05095079 GW 857 3 0 -2 3 0 -0.5 3 0.05095079 GW 858 3 0 2 3 0 0.5 3 0.05095079 GW 859 3 0 -2 -1 0 -0.5 -1 0.05095079 GW 860 3 0 2 -1 0 0.5 -1 0.05095079 GW 861 3 0 2 -3 0 0.5 -3 0.05095079 GW 862 3 0 -2 -3 0 -0.5 -3 0.05095079 GW 863 3 0 -2 -5 0 -0.5 -5 0.05095079 GW 864 3 0 2 -5 0 0.5 -5 0.05095079 GW 865 3 0 2 -7 0 0.5 -7 0.05095079 GW 866 3 0 -2 -7 0 -0.5 -7 0.05095079 GW 867 3 0 -2 -9 0 -0.5 -9 0.05095079 GW 868 3 0 2 -9 0 0.5 -9 0.05095079 GW 869 3 0 2 -11 0 0.5 -11 0.05095079 GW 870 3 0 -2 -11 0 -0.5 -11 0.05095079 GW 871 3 0 -2 -13 0 -0.5 -13 0.05095079 GW 872 3 0 2 -13 0 0.5 -13 0.05095079 GW 873 3 0 -2 -15 0 -0.5 -15 0.05095079 GW 874 3 0 2 -15 0 0.5 -15 0.05095079 GW 875 3 0 -2 -17 0 -0.5 -17 0.05095079 GW 876 3 0 2 -17 0 0.5 -17 0.05095079 GW 877 3 0 2 -19 0 0.5 -19 0.05095079 GW 878 3 0 -2 -19 0 -0.5 -19 0.05095079 GW 879 3 0 2 -21 0 0.5 -21 0.05095079 GW 880 3 0 -2 -21 0 -0.5 -21 0.05095079 GW 881 3 0 -2 -23 0 -0.5 -23 0.05095079 GW 882 3 0 2 -23 0 0.5 -23 0.05095079 GW 883 3 0 -2 -25 0 -0.5 -25 0.05095079 GW 884 3 0 2 -25 0 0.5 -25 0.05095079 GW 885 3 0 2 -27 0 0.5 -27 0.05095079 GW 886 3 0 -2 -27 0 -0.5 -27 0.05095079 GW 887 3 0 -2 -29 0 -0.5 -29 0.05095079 GW 888 3 0 2 -29 0 0.5 -29 0.05095079 GW 890 3 0 2 1 0 0.5 1 0.05095079 GW 40 9 3.5 18 31 5.5 22 31 0.05095079 GW 400 9 3.5 18 -29 5.5 22 -29 0.05095079 GW 326 9 0.5 10 -17 1.5 14 -17 0.05095079 GW 892 5 3.5 -18 -27 3.5 -18 -29 0.05095079 GW 893 9 0 -6 13 0.5 -10 13 0.05095079 GW 895 9 0 -6 15 0.5 -10 15 0.05095079 GW 897 9 0 -6 17 0.5 -10 17 0.05095079 GW 899 9 0.5 -10 13 1.5 -14 13 0.05095079 GW 902 9 1.5 -14 15 0.5 -10 15 0.05095079 GW 903 9 0.5 -10 17 1.5 -14 17 0.05095079 GW 905 9 0 -6 19 0.5 -10 19 0.05095079 GW 907 9 0.5 -10 19 1.5 -14 19 0.05095079 GW 909 9 0 -6 21 0.5 -10 21 0.05095079 GW 910 9 0 -6 23 0.5 -10 23 0.05095079 GW 911 9 0 -6 25 0.5 -10 25 0.05095079 GW 913 9 0 -6 27 0.5 -10 27 0.05095079 GW 918 9 1.5 -14 19 3.5 -18 19 0.05095079 GW 919 9 1.5 -14 17 3.5 -18 17 0.05095079 GW 920 9 1.5 -14 15 3.5 -18 15 0.05095079 GW 921 9 1.5 -14 13 3.5 -18 13 0.05095079 GW 926 9 3.5 -18 13 5.5 -22 13 0.05095079 GW 927 9 3.5 -18 15 5.5 -22 15 0.05095079 GW 928 9 3.5 -18 17 5.5 -22 17 0.05095079 GW 929 9 3.5 -18 19 5.5 -22 19 0.05095079 GW 934 9 0.5 -10 21 1.5 -14 21 0.05095079 GW 935 9 0.5 -10 23 1.5 -14 23 0.05095079 GW 936 9 0.5 -10 25 1.5 -14 25 0.05095079 GW 937 9 0.5 -10 27 1.5 -14 27 0.05095079 GW 942 9 1.5 -14 21 3.5 -18 21 0.05095079 GW 943 9 1.5 -14 23 3.5 -18 23 0.05095079 GW 944 9 1.5 -14 25 3.5 -18 25 0.05095079 GW 945 9 1.5 -14 27 3.5 -18 27 0.05095079 GW 950 9 3.5 -18 21 5.5 -22 21 0.05095079 GW 951 9 3.5 -18 23 5.5 -22 23 0.05095079 GW 952 9 3.5 -18 25 5.5 -22 25 0.05095079 GW 953 9 3.5 -18 27 5.5 -22 27 0.05095079 GW 958 9 0 -6 29 0.5 -10 29 0.05095079 GW 959 9 0 -6 31 0.5 -10 31 0.05095079 GW 962 9 0.5 -10 29 1.5 -14 29 0.05095079 GW 963 9 0.5 -10 31 1.5 -14 31 0.05095079 GW 966 9 1.5 -14 29 3.5 -18 29 0.05095079 GW 967 9 1.5 -14 31 3.5 -18 31 0.05095079 GW 970 9 3.5 -18 31 5.5 -22 31 0.05095079 GW 971 9 3.5 -18 29 5.5 -22 29 0.05095079 GW 972 5 5.5 -22 31 5.5 -22 29 0.05095079 GW 973 5 5.5 -22 29 5.5 -22 27 0.05095079 GW 974 5 5.5 -22 27 5.5 -22 25 0.05095079 GW 975 5 5.5 -22 25 5.5 -22 23 0.05095079 GW 976 5 5.5 -22 23 5.5 -22 21 0.05095079 GW 977 5 5.5 -22 21 5.5 -22 19 0.05095079 GW 978 5 5.5 -22 19 5.5 -22 17 0.05095079 GW 979 5 5.5 -22 17 5.5 -22 15 0.05095079 GW 980 5 5.5 -22 15 5.5 -22 13 0.05095079 GW 981 5 5.5 -22 13 5.5 -22 11 0.05095079 GW 982 5 5.5 -22 11 5.5 -22 9 0.05095079 GW 983 5 5.5 -22 9 5.5 -22 7 0.05095079 GW 984 5 5.5 -22 7 5.5 -22 5 0.05095079 GW 985 5 5.5 -22 5 5.5 -22 3 0.05095079 GW 986 5 5.5 -22 3 5.5 -22 1 0.05095079 GW 987 5 5.5 -22 1 5.5 -22 -1 0.05095079 GW 988 5 5.5 -22 -1 5.5 -22 -3 0.05095079 GW 989 5 5.5 -22 -3 5.5 -22 -5 0.05095079 GW 990 5 5.5 -22 -5 5.5 -22 -7 0.05095079 GW 991 5 5.5 -22 -7 5.5 -22 -9 0.05095079 GW 992 5 5.5 -22 -9 5.5 -22 -11 0.05095079 GW 993 5 5.5 -22 -11 5.5 -22 -13 0.05095079 GW 994 5 5.5 -22 -13 5.5 -22 -15 0.05095079 GW 995 5 5.5 -22 -15 5.5 -22 -17 0.05095079 GW 996 5 5.5 -22 -17 5.5 -22 -19 0.05095079 GW 997 5 5.5 -22 -19 5.5 -22 -21 0.05095079 GW 998 5 5.5 -22 -21 5.5 -22 -23 0.05095079 GW 999 5 5.5 -22 -23 5.5 -22 -25 0.05095079 GW 1000 5 5.5 -22 -25 5.5 -22 -27 0.05095079 GW 1001 5 3.5 -18 -27 3.5 -18 -25 0.05095079 GW 1002 5 3.5 -18 -25 3.5 -18 -23 0.05095079 GW 1003 5 3.5 -18 -23 3.5 -18 -21 0.05095079 GW 1004 5 3.5 -18 -21 3.5 -18 -19 0.05095079 GW 1005 5 3.5 -18 -19 3.5 -18 -17 0.05095079 GW 1006 5 3.5 -18 -17 3.5 -18 -15 0.05095079 GW 1007 5 3.5 -18 -15 3.5 -18 -13 0.05095079 GW 1008 5 3.5 -18 -13 3.5 -18 -11 0.05095079 GW 1009 5 3.5 -18 -11 3.5 -18 -9 0.05095079 GW 1010 5 3.5 -18 -9 3.5 -18 -7 0.05095079 GW 1011 5 3.5 -18 -7 3.5 -18 -5 0.05095079 GW 1012 5 3.5 -18 -5 3.5 -18 -3 0.05095079 GW 1013 5 3.5 -18 -3 3.5 -18 -1 0.05095079 GW 1014 5 3.5 -18 -1 3.5 -18 1 0.05095079 GW 1015 5 3.5 -18 1 3.5 -18 3 0.05095079 GW 1016 5 3.5 -18 3 3.5 -18 5 0.05095079 GW 1017 5 3.5 -18 5 3.5 -18 7 0.05095079 GW 1018 5 3.5 -18 7 3.5 -18 9 0.05095079 GW 1019 5 3.5 -18 9 3.5 -18 11 0.05095079 GW 1020 5 3.5 -18 11 3.5 -18 13 0.05095079 GW 1021 5 3.5 -18 13 3.5 -18 15 0.05095079 GW 1022 5 3.5 -18 15 3.5 -18 17 0.05095079 GW 1023 5 3.5 -18 17 3.5 -18 19 0.05095079 GW 1024 5 3.5 -18 19 3.5 -18 21 0.05095079 GW 1025 5 3.5 -18 21 3.5 -18 23 0.05095079 GW 1026 5 3.5 -18 23 3.5 -18 25 0.05095079 GW 1027 5 3.5 -18 25 3.5 -18 27 0.05095079 GW 1028 5 3.5 -18 27 3.5 -18 29 0.05095079 GW 1029 5 3.5 -18 29 3.5 -18 31 0.05095079 GW 1030 5 1.5 -14 -27 1.5 -14 -25 0.05095079 GW 1031 5 1.5 -14 -25 1.5 -14 -23 0.05095079 GW 1032 5 1.5 -14 -23 1.5 -14 -21 0.05095079 GW 1033 5 1.5 -14 -21 1.5 -14 -19 0.05095079 GW 1034 5 1.5 -14 -19 1.5 -14 -17 0.05095079 GW 1035 5 1.5 -14 -17 1.5 -14 -15 0.05095079 GW 1036 5 1.5 -14 -15 1.5 -14 -13 0.05095079 GW 1037 5 1.5 -14 -13 1.5 -14 -11 0.05095079 GW 1038 5 1.5 -14 -11 1.5 -14 -9 0.05095079 GW 1039 5 1.5 -14 -9 1.5 -14 -7 0.05095079 GW 1040 5 1.5 -14 -7 1.5 -14 -5 0.05095079 GW 1041 5 1.5 -14 -5 1.5 -14 -3 0.05095079 GW 1042 5 1.5 -14 -3 1.5 -14 -1 0.05095079 GW 1043 5 1.5 -14 -1 1.5 -14 1 0.05095079 GW 1044 5 1.5 -14 1 1.5 -14 3 0.05095079 GW 1045 5 1.5 -14 3 1.5 -14 5 0.05095079 GW 1046 5 1.5 -14 5 1.5 -14 7 0.05095079 GW 1047 5 1.5 -14 7 1.5 -14 9 0.05095079 GW 1048 5 1.5 -14 9 1.5 -14 11 0.05095079 GW 1049 5 1.5 -14 11 1.5 -14 13 0.05095079 GW 1050 5 1.5 -14 13 1.5 -14 15 0.05095079 GW 1051 5 1.5 -14 15 1.5 -14 17 0.05095079 GW 1052 5 1.5 -14 17 1.5 -14 19 0.05095079 GW 1053 5 1.5 -14 19 1.5 -14 21 0.05095079 GW 1054 5 1.5 -14 21 1.5 -14 23 0.05095079 GW 1055 5 1.5 -14 23 1.5 -14 25 0.05095079 GW 1056 5 1.5 -14 25 1.5 -14 27 0.05095079 GW 1057 5 1.5 -14 27 1.5 -14 29 0.05095079 GW 1058 5 1.5 -14 29 1.5 -14 31 0.05095079 GW 1059 5 0.5 -10 -27 0.5 -10 -25 0.05095079 GW 1060 5 0.5 -10 -25 0.5 -10 -23 0.05095079 GW 1061 5 0.5 -10 -23 0.5 -10 -21 0.05095079 GW 1062 5 0.5 -10 -21 0.5 -10 -19 0.05095079 GW 1063 5 0.5 -10 -19 0.5 -10 -17 0.05095079 GW 1064 5 0.5 -10 -17 0.5 -10 -15 0.05095079 GW 1065 5 0.5 -10 -15 0.5 -10 -13 0.05095079 GW 1066 5 0.5 -10 -13 0.5 -10 -11 0.05095079 GW 1067 5 0.5 -10 -11 0.5 -10 -9 0.05095079 GW 1068 5 0.5 -10 -9 0.5 -10 -7 0.05095079 GW 1069 5 0.5 -10 -7 0.5 -10 -5 0.05095079 GW 1070 5 0.5 -10 -5 0.5 -10 -3 0.05095079 GW 1071 5 0.5 -10 -3 0.5 -10 -1 0.05095079 GW 1072 5 0.5 -10 -1 0.5 -10 1 0.05095079 GW 1073 5 0.5 -10 1 0.5 -10 3 0.05095079 GW 1074 5 0.5 -10 3 0.5 -10 5 0.05095079 GW 1075 5 0.5 -10 5 0.5 -10 7 0.05095079 GW 1076 5 0.5 -10 7 0.5 -10 9 0.05095079 GW 1077 5 0.5 -10 9 0.5 -10 11 0.05095079 GW 1078 5 0.5 -10 11 0.5 -10 13 0.05095079 GW 1079 5 0.5 -10 13 0.5 -10 15 0.05095079 GW 1080 5 0.5 -10 15 0.5 -10 17 0.05095079 GW 1081 5 0.5 -10 17 0.5 -10 19 0.05095079 GW 1082 5 0.5 -10 19 0.5 -10 21 0.05095079 GW 1083 5 0.5 -10 21 0.5 -10 23 0.05095079 GW 1084 5 0.5 -10 23 0.5 -10 25 0.05095079 GW 1085 5 0.5 -10 25 0.5 -10 27 0.05095079 GW 1086 5 0.5 -10 27 0.5 -10 29 0.05095079 GW 1087 5 0.5 -10 29 0.5 -10 31 0.05095079 GW 1088 9 1.5 14 -29 3.5 18 -29 0.05095079 GW 1089 3 0 -2 1 0 -0.5 1 0.05095079 GS 0 0 0.0254 ' All in in. GE 0 EK LD 5 0 0 0 58000000 0 EX 0 1 5 0 1 0 GN -1 FR 0 39 0 0 470 6 RP 0 1 10 1510 90. 0. 0. 20. 0. 0.
#39 |
And the radiation pattern for the SBGH GH10 2" X 4" mesh curved reflector at 602Mhz peak net gain :
#40 |
I have been lurking here for a while watching the progress of this antenna. When I made the move to digital television I researched antennas knowing that one of my channels was 14 and I found out that most (if not all) commercial antennas available had good gain in the upper channels, but not so great in the lower. I settled on a CM 4228 and have been reasonably happy with it. I wondered at the time why nobody had an antenna geared toward the frequencies coming instead of pushing the same old thing. Today I see the design I have been waiting for. It may take me awhile to build it, but build it I will because it looks perfect for what I want to cover. Getting it to the top of my 55 foot tower won't be fun as I'm getting a little long in age. Having redone the guide wires this spring tells me I'm still able to climb though. Great job guys, on all the work put into this. It may not be perfect yet, but it's got to be very close. I'll definitely keep track of this thread!!
#41 |
I posted the complete 4nec2 design info for 2nd Generation GH, so readers of this forum could "test-drive" the modeling product and perhaps make further improvements using the freeware 4nec2 program, so I'm really pleased that 300ohm has made detailed investigations of a mesh screen reflector design and has just posted his results.
Excellent work 300ohm !!! Those results are quite impressive, and your pvc frame design is really neat. I'm sure all of us are eagerly awaiting your detailed build plans and reception results. For the benefit of folks that may wish to dabble in 4nec2 with 300ohm's nec file, here a quick "how-to" - 1. Copy and paste 300ohm's two part nec file posts into "notepad" and save as 300ohm_curved_screen.nec. (You should get a file with 749 wires and 5087 segments.) - 2. Under "Settings tab" of the 4nec2 main window, you will have to increase the "NEC engine min-nr segments" to something like 5200, and you must have 'nec2dXS8K0' in your 4nec2 exe folder to provide a max segment core of 8000. Be warned that for 5087 segments, execution time is very, very,...very long even with a dual-core >2GHz CPU. We all owe a lot to 300 ohm for his curved screen efforts and perhaps he might post details of his CPU and typical run-times for his curved mesh screen nec file. 300Ohm: Job well done .....thanks |
#42 | ||
I have the Intel E2180 dual core processor (stock 2.0 ghz) overclocked to 2.8ghz (it will do 3.4-3.5ghz on an overclocking mobo), 2 gigs of Adata ddr2-800 ram, and an Asrock 4CoreDual-SATA2 motherboard. I upgraded last November and it was a cheap upgrade, as I wanted to keep my GeForce 6800 AGP video card which still serves my needs fine, yet I can transistion to PCI-E video in the future. The processor goes for about $70 now, the motherboard for around $60 and two gigs of ddr2 ram is less than $40. I already had a high end 535watt Fortron power supply, which I consider the heart of any good stable system. If building your own computer, do not cheap out on the psu, get a quality unit with enough wattage. The 4nec2X program uses both of the cpu cores while processing. Im curious as to whether all four cores are used in a quad core system. Its simple to tell, just open up Task Manager while the program is processing and click on the Performance tab and look at CPU Usage History. For a single core processor youll only have one history screen that moves up and down. For a dual core, 2 screens. For a quad core 4 screens. These will tell you the processor usage on each core. Speaking of long processing times, some reasonable guestimation of the DBGH version 2 spacing needs to be made before making these long runs. The old rules of thumb for ganging two vertical antennas were based on some even wavelength or fraction of a wavelength. And with the DBGH version 1 colinear rod model, Ive found that some peak gain tuning can be done by spacing the feedpoints about 2 times the wavelength of the desired frequency. However the current thinking on vertical antenna ganging for the most gain seems to be spacing the two antennas apart so that their aperature areas just touch but dont overlap. Calculating the aperature area is easy with the formula Aperature Area = (Gain in dbi * ((wavelength)^2))/(4 * Pi) What is not known is the perimeter or shape of aperature area for the SBGH. For a Yagi, the shape is roughly elliptical, but I doubt thats true for the SBGH. Any ideas ?
My builds/plans (not the latest models) are located here. Last edited by 300ohm; 2008-08-14 at 10:55 PM. |
#43 |
300ohm,
All of your past work on the gen1 SBGH has been quite professional looking and seemingly long-lasting. But I am VERY impressed with your sbgh10 mesh screen design. |
#44 | |
The co-linear 10 rod model : ![]() And the curved mesh model : ![]() Yeah, it looks like it. Hmm, since my highest channel Ill have after Feb is 42 (638-644mhz) in the direction I plan to use this antenna, that will do me very nicely indeed. If you want even more high frequency gain, then use 1 inch by 2 inch mesh. I guestimate based on mclapps experiments that may give you only about .15dbi more at channel 17, about .4dbi more at channel 42, but .7dbi more at channel 51. Of course, 1 inch by 2 inch mesh is costlier, harder to find locally, and has more wind load. Modeling with 1 inch by 2 inch mesh would about triple the 10,000 second processing time, heh.
My builds/plans (not the latest models) are located here. Last edited by 300ohm; 2008-08-15 at 01:49 AM. |
#45 |
Here are the Net Gain results for the SBGH version 1, 2" by 4" mesh per my plans. The previous graphs are Raw Gain.
Mhz Net Gain ------->in dBi ---- -------- 470 12.25 476 12.58 482 12.86 488 13.09 494 13.29 500 13.45 506 13.61 512 13.75 518 13.88 524 13.97 530 14.03 536 14.07 542 14.09 548 14.04 554 14.01 560 14.05 566 14.11 572 14.18 578 14.27 584 14.35 590 14.43 596 14.47 602 14.50 608 14.50 614 14.45 620 14.42 626 14.59 632 14.84 638 15.00 644 15.10 650 15.17 656 15.23 662 15.27 668 15.31 674 15.29 680 15.24 686 15.13 692 14.93 698 14.64
My builds/plans (not the latest models) are located here. Last edited by 300ohm; 2008-08-15 at 02:56 AM. |
