#91 |
I took j3d's gapless GH10 and made the driven wires into first generation Koch Curves. (It should be noted for the pedants that the triangles should be equilateral, not right triangles like in the build photo above. Of course, right triangles might actually make for a better antenna...)
(6 AWG elements, 1/4 inch reflectors) Code:
CM test output CE GW 1 7 0.000000 -0.035500 0.000000 0.000000 0.035500 0.000000 0.002058 GW 2 7 0.000000 -0.035500 -0.000000 0.000000 -0.089004 -0.053504 0.002058 GW 3 7 0.000000 -0.089004 -0.053504 0.000000 -0.162093 -0.033920 0.002058 GW 4 7 0.000000 -0.162093 -0.033920 0.000000 -0.142509 -0.107009 0.002058 GW 5 7 0.000000 -0.142509 -0.107009 0.000000 -0.196013 -0.160513 0.002058 GW 6 6 0.000000 -0.196013 -0.160513 0.000000 -0.150287 -0.206239 0.002058 GW 7 6 0.000000 -0.150287 -0.206239 0.000000 -0.167024 -0.268703 0.002058 GW 8 6 0.000000 -0.167024 -0.268703 0.000000 -0.104561 -0.251966 0.002058 GW 9 6 0.000000 -0.104561 -0.251966 0.000000 -0.058835 -0.297692 0.002058 GW 10 5 0.000000 -0.058835 -0.297692 0.000000 -0.100554 -0.339411 0.002058 GW 11 5 0.000000 -0.100554 -0.339411 0.000000 -0.157543 -0.324141 0.002058 GW 12 5 0.000000 -0.157543 -0.324141 0.000000 -0.142273 -0.381131 0.002058 GW 13 5 0.000000 -0.142273 -0.381131 0.000000 -0.183992 -0.422850 0.002058 GW 14 12 0.000000 -0.183992 -0.422850 0.000000 -0.307992 -0.422850 0.002058 GW 15 7 0.000000 -0.035500 0.000000 0.000000 -0.089004 0.053504 0.002058 GW 16 7 0.000000 -0.089004 0.053504 0.000000 -0.162093 0.033920 0.002058 GW 17 7 0.000000 -0.162093 0.033920 0.000000 -0.142509 0.107009 0.002058 GW 18 7 0.000000 -0.142509 0.107009 0.000000 -0.196013 0.160513 0.002058 GW 19 6 0.000000 -0.196013 0.160513 0.000000 -0.150287 0.206239 0.002058 GW 20 6 0.000000 -0.150287 0.206239 0.000000 -0.167024 0.268703 0.002058 GW 21 6 0.000000 -0.167024 0.268703 0.000000 -0.104561 0.251966 0.002058 GW 22 6 0.000000 -0.104561 0.251966 0.000000 -0.058835 0.297692 0.002058 GW 23 5 0.000000 -0.058835 0.297692 0.000000 -0.100554 0.339411 0.002058 GW 24 5 0.000000 -0.100554 0.339411 0.000000 -0.157543 0.324141 0.002058 GW 25 5 0.000000 -0.157543 0.324141 0.000000 -0.142273 0.381131 0.002058 GW 26 5 0.000000 -0.142273 0.381131 0.000000 -0.183992 0.422850 0.002058 GW 27 12 0.000000 -0.183992 0.422850 0.000000 -0.307992 0.422850 0.002058 GW 28 7 0.000000 0.035500 -0.000000 0.000000 0.089004 -0.053504 0.002058 GW 29 7 0.000000 0.089004 -0.053504 0.000000 0.162093 -0.033920 0.002058 GW 30 7 0.000000 0.162093 -0.033920 0.000000 0.142509 -0.107009 0.002058 GW 31 7 0.000000 0.142509 -0.107009 0.000000 0.196013 -0.160513 0.002058 GW 32 6 0.000000 0.196013 -0.160513 0.000000 0.150287 -0.206239 0.002058 GW 33 6 0.000000 0.150287 -0.206239 0.000000 0.167024 -0.268703 0.002058 GW 34 6 0.000000 0.167024 -0.268703 0.000000 0.104561 -0.251966 0.002058 GW 35 6 0.000000 0.104561 -0.251966 0.000000 0.058835 -0.297692 0.002058 GW 36 5 0.000000 0.058835 -0.297692 0.000000 0.100554 -0.339411 0.002058 GW 37 5 0.000000 0.100554 -0.339411 0.000000 0.157543 -0.324141 0.002058 GW 38 5 0.000000 0.157543 -0.324141 0.000000 0.142273 -0.381131 0.002058 GW 39 5 0.000000 0.142273 -0.381131 0.000000 0.183992 -0.422850 0.002058 GW 40 12 0.000000 0.183992 -0.422850 0.000000 0.307992 -0.422850 0.002058 GW 41 7 0.000000 0.035500 0.000000 0.000000 0.089004 0.053504 0.002058 GW 42 7 0.000000 0.089004 0.053504 0.000000 0.162093 0.033920 0.002058 GW 43 7 0.000000 0.162093 0.033920 0.000000 0.142509 0.107009 0.002058 GW 44 7 0.000000 0.142509 0.107009 0.000000 0.196013 0.160513 0.002058 GW 45 6 0.000000 0.196013 0.160513 0.000000 0.150287 0.206239 0.002058 GW 46 6 0.000000 0.150287 0.206239 0.000000 0.167024 0.268703 0.002058 GW 47 6 0.000000 0.167024 0.268703 0.000000 0.104561 0.251966 0.002058 GW 48 6 0.000000 0.104561 0.251966 0.000000 0.058835 0.297692 0.002058 GW 49 5 0.000000 0.058835 0.297692 0.000000 0.100554 0.339411 0.002058 GW 50 5 0.000000 0.100554 0.339411 0.000000 0.157543 0.324141 0.002058 GW 51 5 0.000000 0.157543 0.324141 0.000000 0.142273 0.381131 0.002058 GW 52 5 0.000000 0.142273 0.381131 0.000000 0.183992 0.422850 0.002058 GW 53 12 0.000000 0.183992 0.422850 0.000000 0.307992 0.422850 0.002058 GW 54 29 -0.081000 -0.147000 -0.073000 -0.081000 0.147000 -0.073000 0.003175 GW 55 29 -0.081000 -0.147000 0.073000 -0.081000 0.147000 0.073000 0.003175 GW 56 97 -0.081000 -0.489000 -0.196000 -0.081000 0.489000 -0.196000 0.003175 GW 57 97 -0.081000 -0.489000 0.196000 -0.081000 0.489000 0.196000 0.003175 GW 58 99 -0.081000 -0.496000 -0.307000 -0.081000 0.496000 -0.307000 0.003175 GW 59 99 -0.081000 -0.496000 0.307000 -0.081000 0.496000 0.307000 0.003175 GW 60 76 -0.081000 -0.382000 -0.418000 -0.081000 0.382000 -0.418000 0.003175 GW 61 76 -0.081000 -0.382000 0.418000 -0.081000 0.382000 0.418000 0.003175 GW 62 111 -0.081000 -0.557000 -0.539000 -0.081000 0.557000 -0.539000 0.003175 GW 63 111 -0.081000 -0.557000 0.539000 -0.081000 0.557000 0.539000 0.003175 GW 64 28 -0.081000 -0.143000 -0.681000 -0.081000 0.143000 -0.681000 0.003175 GW 65 28 -0.081000 -0.143000 0.681000 -0.081000 0.143000 0.681000 0.003175 GE 0 LD 5 0 0 0 2.49e+07 EK 0 FR 0 20 0 0 473 12 EX 0 1 4 0 1 GN -1 0 0 0 0.0 0.0 0.0 0.0 0.0 0.0 RP 0 1 61 1001 90 0 3 6 10000 0 EN Code:
#OUT: Forw-gain; Theta= 90; Phi= 0
#Freq [MHz] Tot-gain [dBi]
Fractal Reference
473 14.71 14.38
485 14.76 14.61
497 14.67 14.66
509 14.55 14.62
521 14.44 14.54
533 14.31 14.44
545 14.18 14.39
557 14.27 14.48
569 14.3 14.59
581 13.93 14.68
593 13.07 14.77
605 11.71 14.89
617 9.95 15.03
629 7.93 15.2
641 5.69 15.38
653 3.39 15.56
665 2.14 15.69
677 1.92 15.68
689 1.97 15.45
701 1.93 14.91
#92 |
firimari: "300ohm:" had a thread on fractals, so I knew that the gain curve would shift. Mine is a GH gen2 with 9" legs. I just like the looks. Thank you for the new info.
#93 |
#94 |
I think 300ohm modeled this? If I remember it did not do all that well.
#95 |
Yeah, I modeled about that fractal bowtie. The bowties dont really take to fractalization as well as the GHs do. And like I said before, you lose some gain with fractalization, but you do get smaller size. Its a trade-off.
#96 |
It occurs to me that as you add more and more pieces to the fractal, you eventually approach circular arcs. Here's what I mean. I just did the left-hand side, because it's bleeping hard to do a circular arc freehand with a trackball mouse
OTA brings you crystal-clear, uncompressed HDTV, no simsubbing, and the real SuperBowl commercials. You can't get all that on satellite... OR CABLE. |
#97 | |
#98 |
The results of 4nec2's optimizer on a single-iteration of the Koch Curve for a one-diamond reflector-less GH. High SWR on the lower UHF channels, low gain on the higher ones, But from 518 MHz and higher SWR is under 4, and forward gain is between 8 and 10 for 470-668 MHz. Not bad for almost fitting in a half meter by half meter square.
The goal here is an indoor antenna that will fit behind a picture frame, for a relative that has reasonably decent signal strength. I'll probably try next making it a second iteration Koch Curve on at least the longer leg of the element. Code:
CM Experimental Antenna Design X-008 CM Parameterized Reflectorless Single Diamond Grey Hoverman CM single iteration Koch Curve CM UHF Antenna CM AWG Gauge 12 Copper Wire CE SY gap=0.047743 SY segment_0_length=0.238629 SY segment_1_length=0.115095 SY tail_length=0.156403 SY wire_radius=1.0262e-03 SY sin045=0.707107 SY cos045=0.707107 SY sin075=0.965926 SY cos075=0.258819 SY sin135=0.707107 SY cos135=-0.707107 SY sin345=-0.258819 SY cos345=0.965926 SY s0_y0=gap-cos135*segment_0_length SY s0_z0=0 SY s0_y1=s0_y0+0.333333*cos135*segment_0_length SY s0_z1=s0_z0+0.333333*sin135*segment_0_length SY s0_y2=s0_y1+0.333333*cos075*segment_0_length SY s0_z2=s0_z1+0.333333*sin075*segment_0_length SY s0_y3=s0_y0+0.666667*cos135*segment_0_length SY s0_z3=s0_z0+0.666667*sin135*segment_0_length SY s1_y0=gap SY s1_z0=sin135*segment_0_length SY s1_y1=s1_y0+0.333333*cos045*segment_1_length SY s1_z1=s1_z0+0.333333*sin045*segment_1_length SY s1_y2=s1_y1+0.333333*cos345*segment_1_length SY s1_z2=s1_z1+0.333333*sin345*segment_1_length SY s1_y3=s1_y0+0.666667*cos045*segment_1_length SY s1_z3=s1_z0+0.666667*sin045*segment_1_length SY tail_y0=gap+cos045*segment_1_length SY tail_z0=sin135*segment_0_length+sin045*segment_1_length SY tail_y1=gap+cos045*segment_1_length+tail_length GW 1 17 0 -s0_y0 s0_z0 0 s0_y0 s0_z0 wire_radius GW 2 3 0 s0_y0 s0_z0 0 s0_y1 s0_z1 wire_radius GW 3 3 0 s0_y1 s0_z1 0 s0_y2 s0_z2 wire_radius GW 4 3 0 s0_y2 s0_z2 0 s0_y3 s0_z3 wire_radius GW 5 3 0 s0_y3 s0_z3 0 s1_y0 s1_z0 wire_radius GW 6 3 0 s1_y0 s1_z0 0 s1_y1 s1_z1 wire_radius GW 7 3 0 s1_y1 s1_z1 0 s1_y2 s1_z2 wire_radius GW 8 3 0 s1_y2 s1_z2 0 s1_y3 s1_z3 wire_radius GW 9 3 0 s1_y3 s1_z3 0 tail_y0 tail_z0 wire_radius GW 10 3 0 tail_y0 tail_z0 0 tail_y1 tail_z0 wire_radius GW 11 3 0 -s0_y0 s0_z0 0 -s0_y1 s0_z1 wire_radius GW 12 3 0 -s0_y1 s0_z1 0 -s0_y2 s0_z2 wire_radius GW 13 3 0 -s0_y2 s0_z2 0 -s0_y3 s0_z3 wire_radius GW 14 3 0 -s0_y3 s0_z3 0 -s1_y0 s1_z0 wire_radius GW 15 3 0 -s1_y0 s1_z0 0 -s1_y1 s1_z1 wire_radius GW 16 3 0 -s1_y1 s1_z1 0 -s1_y2 s1_z2 wire_radius GW 17 3 0 -s1_y2 s1_z2 0 -s1_y3 s1_z3 wire_radius GW 18 3 0 -s1_y3 s1_z3 0 -tail_y0 tail_z0 wire_radius GW 19 3 0 -tail_y0 tail_z0 0 -tail_y1 tail_z0 wire_radius GW 20 3 0 s0_y0 -s0_z0 0 s0_y1 -s0_z1 wire_radius GW 21 3 0 s0_y1 -s0_z1 0 s0_y2 -s0_z2 wire_radius GW 22 3 0 s0_y2 -s0_z2 0 s0_y3 -s0_z3 wire_radius GW 23 3 0 s0_y3 -s0_z3 0 s1_y0 -s1_z0 wire_radius GW 24 3 0 s1_y0 -s1_z0 0 s1_y1 -s1_z1 wire_radius GW 25 3 0 s1_y1 -s1_z1 0 s1_y2 -s1_z2 wire_radius GW 26 3 0 s1_y2 -s1_z2 0 s1_y3 -s1_z3 wire_radius GW 27 3 0 s1_y3 -s1_z3 0 tail_y0 -tail_z0 wire_radius GW 28 3 0 tail_y0 -tail_z0 0 tail_y1 -tail_z0 wire_radius GW 29 3 0 -s0_y0 -s0_z0 0 -s0_y1 -s0_z1 wire_radius GW 30 3 0 -s0_y1 -s0_z1 0 -s0_y2 -s0_z2 wire_radius GW 31 3 0 -s0_y2 -s0_z2 0 -s0_y3 -s0_z3 wire_radius GW 32 3 0 -s0_y3 -s0_z3 0 -s1_y0 -s1_z0 wire_radius GW 33 3 0 -s1_y0 -s1_z0 0 -s1_y1 -s1_z1 wire_radius GW 34 3 0 -s1_y1 -s1_z1 0 -s1_y2 -s1_z2 wire_radius GW 35 3 0 -s1_y2 -s1_z2 0 -s1_y3 -s1_z3 wire_radius GW 36 3 0 -s1_y3 -s1_z3 0 -tail_y0 -tail_z0 wire_radius GW 37 3 0 -tail_y0 -tail_z0 0 -tail_y1 -tail_z0 wire_radius GE 0 LD 5 0 0 0 58000000 GN -1 EK EX 0 1 9 0 1.0 FR 0 38 0 0 470 6 RP 0 1 61 1001 90 0 3 6 10000 0 EN |
#99 | |
#100 |
Thanks for the compliment, 300ohm. Last night I was able to get the second iteration modelled, though I had to up the number of symbols that 4nec will evaluate. I could have spent a little more time simplifying my model to do that, but I just upped the max symbols to 128 instead. Anyway, close to the same results, but it looks prettier and is shorter (but not less wide)
Two lengths of 1468 mm long 12 gauge wire form the elements and the middle segment is 433mm long (which will get split in the middle for a 4:1 balun) Hopefully I can find time to build this soon. Code:
CM Experimental Antenna Design X-010 CM Parameterized Reflectorless Single Diamond Grey Hoverman CM Second Iteration Koch Curve CM UHF Antenna CM AWG Gauge 12 Copper Wire CE SY gap=0.047743 SY segment_0_length=0.238629 SY segment_1_length=0.115095 SY tail_length=0.156403 SY wire_radius=1.0262e-03 SY sin015=0.258819 SY cos015=0.965926 SY sin045=0.707107 SY cos045=0.707107 SY sin075=0.965926 SY cos075=0.258819 SY sin135=0.707107 SY cos135=-0.707107 SY sin195=-0.258819 SY cos195=-0.965925 SY sin345=-0.258819 SY cos345=0.965926 SY s0_y00=gap-cos135*segment_0_length SY s0_z00=0 SY s0_y01=s0_y00+0.111111*cos135*segment_0_length SY s0_z01=s0_z00+0.111111*sin135*segment_0_length SY s0_y02=s0_y01+0.111111*cos075*segment_0_length SY s0_z02=s0_z01+0.111111*sin075*segment_0_length SY s0_y03=s0_y00+0.222222*cos135*segment_0_length SY s0_z03=s0_z00+0.222222*sin135*segment_0_length SY s0_y04=s0_y00+0.333333*cos135*segment_0_length SY s0_z04=s0_z00+0.333333*sin135*segment_0_length SY s0_y05=s0_y04+0.111111*cos075*segment_0_length SY s0_z05=s0_z04+0.111111*sin075*segment_0_length SY s0_y06=s0_y05+0.111111*cos015*segment_0_length SY s0_z06=s0_z05+0.111111*sin015*segment_0_length SY s0_y07=s0_y04+0.222222*cos075*segment_0_length SY s0_z07=s0_z04+0.222222*sin075*segment_0_length SY s0_y08=s0_y04+0.333333*cos075*segment_0_length SY s0_z08=s0_z04+0.333333*sin075*segment_0_length SY s0_y09=s0_y08+0.111111*cos195*segment_0_length SY s0_z09=s0_z08+0.111111*sin195*segment_0_length SY s0_y10=s0_y09+0.111111*cos135*segment_0_length SY s0_z10=s0_z09+0.111111*sin135*segment_0_length SY s0_y11=s0_y08+0.222222*cos195*segment_0_length SY s0_z11=s0_z08+0.222222*sin195*segment_0_length SY s0_y12=s0_y00+0.666667*cos135*segment_0_length SY s0_z12=s0_z00+0.666667*sin135*segment_0_length SY s0_y13=s0_y00+0.777778*cos135*segment_0_length SY s0_z13=s0_z00+0.777778*sin135*segment_0_length SY s0_y14=s0_y13+0.111111*cos075*segment_0_length SY s0_z14=s0_z13+0.111111*sin075*segment_0_length SY s0_y15=s0_y00+0.888889*cos135*segment_0_length SY s0_z15=s0_z00+0.888889*sin135*segment_0_length SY s1_y0=gap SY s1_z0=sin135*segment_0_length SY s1_y1=s1_y0+0.333333*cos045*segment_1_length SY s1_z1=s1_z0+0.333333*sin045*segment_1_length SY s1_y2=s1_y1+0.333333*cos345*segment_1_length SY s1_z2=s1_z1+0.333333*sin345*segment_1_length SY s1_y3=s1_y0+0.666667*cos045*segment_1_length SY s1_z3=s1_z0+0.666667*sin045*segment_1_length SY tail_y0=gap+cos045*segment_1_length SY tail_z0=sin135*segment_0_length+sin045*segment_1_length SY tail_y1=gap+cos045*segment_1_length+tail_length GW 1 17 0 -s0_y00 s0_z00 0 s0_y00 s0_z00 wire_radius GW 2 3 0 s0_y00 s0_z00 0 s0_y01 s0_z01 wire_radius GW 3 3 0 s0_y01 s0_z01 0 s0_y02 s0_z02 wire_radius GW 4 3 0 s0_y02 s0_z02 0 s0_y03 s0_z03 wire_radius GW 5 3 0 s0_y03 s0_z03 0 s0_y04 s0_z04 wire_radius GW 6 3 0 s0_y04 s0_z04 0 s0_y05 s0_z05 wire_radius GW 7 3 0 s0_y05 s0_z05 0 s0_y06 s0_z06 wire_radius GW 8 3 0 s0_y06 s0_z06 0 s0_y07 s0_z07 wire_radius GW 9 3 0 s0_y07 s0_z07 0 s0_y08 s0_z08 wire_radius GW 10 3 0 s0_y08 s0_z08 0 s0_y09 s0_z09 wire_radius GW 11 3 0 s0_y09 s0_z09 0 s0_y10 s0_z10 wire_radius GW 12 3 0 s0_y10 s0_z10 0 s0_y11 s0_z11 wire_radius GW 13 3 0 s0_y11 s0_z11 0 s0_y12 s0_z12 wire_radius GW 14 3 0 s0_y12 s0_z12 0 s0_y13 s0_z13 wire_radius GW 15 3 0 s0_y13 s0_z13 0 s0_y14 s0_z14 wire_radius GW 16 3 0 s0_y14 s0_z14 0 s0_y15 s0_z15 wire_radius GW 17 3 0 s0_y15 s0_z15 0 s1_y0 s1_z0 wire_radius GW 18 3 0 s1_y0 s1_z0 0 s1_y1 s1_z1 wire_radius GW 19 3 0 s1_y1 s1_z1 0 s1_y2 s1_z2 wire_radius GW 20 3 0 s1_y2 s1_z2 0 s1_y3 s1_z3 wire_radius GW 21 3 0 s1_y3 s1_z3 0 tail_y0 tail_z0 wire_radius GW 22 3 0 tail_y0 tail_z0 0 tail_y1 tail_z0 wire_radius GW 23 3 0 -s0_y00 s0_z00 0 -s0_y01 s0_z01 wire_radius GW 24 3 0 -s0_y01 s0_z01 0 -s0_y02 s0_z02 wire_radius GW 25 3 0 -s0_y02 s0_z02 0 -s0_y03 s0_z03 wire_radius GW 26 3 0 -s0_y03 s0_z03 0 -s0_y04 s0_z04 wire_radius GW 27 3 0 -s0_y04 s0_z04 0 -s0_y05 s0_z05 wire_radius GW 28 3 0 -s0_y05 s0_z05 0 -s0_y06 s0_z06 wire_radius GW 29 3 0 -s0_y06 s0_z06 0 -s0_y07 s0_z07 wire_radius GW 30 3 0 -s0_y07 s0_z07 0 -s0_y08 s0_z08 wire_radius GW 31 3 0 -s0_y08 s0_z08 0 -s0_y09 s0_z09 wire_radius GW 32 3 0 -s0_y09 s0_z09 0 -s0_y10 s0_z10 wire_radius GW 33 3 0 -s0_y10 s0_z10 0 -s0_y11 s0_z11 wire_radius GW 34 3 0 -s0_y11 s0_z11 0 -s0_y12 s0_z12 wire_radius GW 35 3 0 -s0_y12 s0_z12 0 -s0_y13 s0_z13 wire_radius GW 36 3 0 -s0_y13 s0_z13 0 -s0_y14 s0_z14 wire_radius GW 37 3 0 -s0_y14 s0_z14 0 -s0_y15 s0_z15 wire_radius GW 38 3 0 -s0_y15 s0_z15 0 -s1_y0 s1_z0 wire_radius GW 39 3 0 -s1_y0 s1_z0 0 -s1_y1 s1_z1 wire_radius GW 40 3 0 -s1_y1 s1_z1 0 -s1_y2 s1_z2 wire_radius GW 41 3 0 -s1_y2 s1_z2 0 -s1_y3 s1_z3 wire_radius GW 42 3 0 -s1_y3 s1_z3 0 -tail_y0 tail_z0 wire_radius GW 43 3 0 -tail_y0 tail_z0 0 -tail_y1 tail_z0 wire_radius GW 44 3 0 -s0_y00 -s0_z00 0 -s0_y01 -s0_z01 wire_radius GW 45 3 0 -s0_y01 -s0_z01 0 -s0_y02 -s0_z02 wire_radius GW 46 3 0 -s0_y02 -s0_z02 0 -s0_y03 -s0_z03 wire_radius GW 47 3 0 -s0_y03 -s0_z03 0 -s0_y04 -s0_z04 wire_radius GW 48 3 0 -s0_y04 -s0_z04 0 -s0_y05 -s0_z05 wire_radius GW 49 3 0 -s0_y05 -s0_z05 0 -s0_y06 -s0_z06 wire_radius GW 50 3 0 -s0_y06 -s0_z06 0 -s0_y07 -s0_z07 wire_radius GW 51 3 0 -s0_y07 -s0_z07 0 -s0_y08 -s0_z08 wire_radius GW 52 3 0 -s0_y08 -s0_z08 0 -s0_y09 -s0_z09 wire_radius GW 53 3 0 -s0_y09 -s0_z09 0 -s0_y10 -s0_z10 wire_radius GW 54 3 0 -s0_y10 -s0_z10 0 -s0_y11 -s0_z11 wire_radius GW 55 3 0 -s0_y11 -s0_z11 0 -s0_y12 -s0_z12 wire_radius GW 56 3 0 -s0_y12 -s0_z12 0 -s0_y13 -s0_z13 wire_radius GW 57 3 0 -s0_y13 -s0_z13 0 -s0_y14 -s0_z14 wire_radius GW 58 3 0 -s0_y14 -s0_z14 0 -s0_y15 -s0_z15 wire_radius GW 59 3 0 -s0_y15 -s0_z15 0 -s1_y0 -s1_z0 wire_radius GW 60 3 0 -s1_y0 -s1_z0 0 -s1_y1 -s1_z1 wire_radius GW 61 3 0 -s1_y1 -s1_z1 0 -s1_y2 -s1_z2 wire_radius GW 62 3 0 -s1_y2 -s1_z2 0 -s1_y3 -s1_z3 wire_radius GW 63 3 0 -s1_y3 -s1_z3 0 -tail_y0 -tail_z0 wire_radius GW 64 3 0 -tail_y0 -tail_z0 0 -tail_y1 -tail_z0 wire_radius GW 65 3 0 s0_y00 -s0_z00 0 s0_y01 -s0_z01 wire_radius GW 66 3 0 s0_y01 -s0_z01 0 s0_y02 -s0_z02 wire_radius GW 67 3 0 s0_y02 -s0_z02 0 s0_y03 -s0_z03 wire_radius GW 68 3 0 s0_y03 -s0_z03 0 s0_y04 -s0_z04 wire_radius GW 69 3 0 s0_y04 -s0_z04 0 s0_y05 -s0_z05 wire_radius GW 70 3 0 s0_y05 -s0_z05 0 s0_y06 -s0_z06 wire_radius GW 71 3 0 s0_y06 -s0_z06 0 s0_y07 -s0_z07 wire_radius GW 72 3 0 s0_y07 -s0_z07 0 s0_y08 -s0_z08 wire_radius GW 73 3 0 s0_y08 -s0_z08 0 s0_y09 -s0_z09 wire_radius GW 74 3 0 s0_y09 -s0_z09 0 s0_y10 -s0_z10 wire_radius GW 75 3 0 s0_y10 -s0_z10 0 s0_y11 -s0_z11 wire_radius GW 76 3 0 s0_y11 -s0_z11 0 s0_y12 -s0_z12 wire_radius GW 77 3 0 s0_y12 -s0_z12 0 s0_y13 -s0_z13 wire_radius GW 78 3 0 s0_y13 -s0_z13 0 s0_y14 -s0_z14 wire_radius GW 79 3 0 s0_y14 -s0_z14 0 s0_y15 -s0_z15 wire_radius GW 80 3 0 s0_y15 -s0_z15 0 s1_y0 -s1_z0 wire_radius GW 81 3 0 s1_y0 -s1_z0 0 s1_y1 -s1_z1 wire_radius GW 82 3 0 s1_y1 -s1_z1 0 s1_y2 -s1_z2 wire_radius GW 83 3 0 s1_y2 -s1_z2 0 s1_y3 -s1_z3 wire_radius GW 84 3 0 s1_y3 -s1_z3 0 tail_y0 -tail_z0 wire_radius GW 85 3 0 tail_y0 -tail_z0 0 tail_y1 -tail_z0 wire_radius GE 0 LD 5 0 0 0 58000000 GN -1 EK EX 0 1 9 0 1.0 FR 0 38 0 0 470 6 RP 0 1 61 1001 90 0 3 6 10000 0 EN |
#101 |
Hey! Great forum. Here is my 2cents.
Good news is I live on a hill, not so good is the high rise blocking about 100 degrees of the view south. But yet I receive most of the Toronto and Buffalo DT stations using an indoor fractal antenna. It is constructed with 20ga wire, finishing nails, and hidden inside an old cassette storage box. A 9" cake rack fits inside the box as a reflector or resonator... whatever. The low-noise preamps at Sayal were sold out so I tried a cheap 10db RCA indoor preamp from Home Depot. Perhaps it makes a slight improvement but I am not sure. Slight pixelation occurs sometimes on 44.1 and 29.1 which I believe can be solved by antenna improvements.. 29 only works at a very specific location in the TV room. Hacking is mostly effective but leaves unanswered questions. Does anyone know how to model or engineer a fractal antenna.? |
#102 |
Which fractal antenna design did you use? Most readers do not know what a fractal antenna is, so please give specifics.
#103 | |
#104 | |
Last edited by stampeder; 2009-06-27 at 01:17 AM. Reason: link to a broken web site has been removed |
#105 |
