Dolby Digital - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2003
Old 2005-01-16, 09:42 PM   #16
dirtyjeffer
if the optical cable works fine on your DVD player, it will be fine for your 5900...there must be a setting that is not correct in your 5900, or it isn't working properly...i have two 5900's and get DD just fine (obviously only on shows that are broadcast in DD, like most movies on TMN).
Panasonic TP42PX60, Yamaha DTS receiver, Mission 73 series speakers, 100% sweetness!
dirtyjeffer is offline
Old 2005-01-17, 12:03 AM   #17
Originally Posted by dirtyjeffer
The .1 in 5.1 is simply an electronic "filter" that sends all lower frequencies to that output on the receiver to allow a subwoofer to handle the low bass frequencies.
hmm, I thought this was actually a 6th discrete signal. I could be wrong in my thinking...
57 is offline
Old 2005-01-17, 12:17 AM   #18
ken0042
Premium Supporter
Sorry, didn't read everything, but JDG- you did set the Bell receiver to output to Dolby Digital, right?
On my 5900 it's Menu- 6 - 8
ken0042 is offline
Old 2005-01-17, 01:23 AM   #19
sthuynh
I get sound with all channels with the optical cable connected to my Denon 3805, PVR 5800. Sound channels will lit up DD and some will not, simply PCM.
sthuynh is offline
Old 2005-01-17, 01:56 AM   #20
dirtyjeffer
that is why it isn't DD 6.0, because there isn't 6 tracks of audio...however, it would basically give you the same effect...low frequencies are not subject to directional detection, so filtering them off to a dedicated subwoofer is fine...since you can't determine where the low frequency sound is coming from, it doesn't matter if it comes from one of your main 5 speakers, or directed to a subwoofer, hence the 5.1.
Old 2005-01-17, 08:32 AM   #21
Falcon
Originally Posted by martynook
I currently have Digital Cable and I was thinking about switching to satellite but I was wondering if Bell ExpressVu has Dolby Digital.
To answer your question in short (after all this disagreement), Yes.
Falcon is offline
Old 2005-01-17, 09:21 AM   #22
KSPSlice
this is correct. directly from the dolby labs web site:
"The sound information contained in each of the six available channels is distinct and independent. These six channels are described as a "5.1-channel" system, because there are five full-bandwidth channels with 3 Hz to 20 kHz frequency range for Front Left and Right, Center, and Surround, plus one "Low Frequency Effects" (LFE) subwoofer channel devoted to frequencies from 3 to 120 Hz."
http://www.dolby.com/consumer/techno...y_digital.html
and for more info on the original question:
http://www.dolby.com/consumer/techno..._overview.html
this link describes all of the different types of dolby technologies available. in particular it describes dolby digital as follows:
"Dolby® Digital - Delivers mono, stereo, or up to 5.1 discrete channels of surround sound: Left, Center, Right, Left Surround, Right Surround, and low-frequency effects (LFE). Global standard for DVD-Audio and DVD-Video. Digital audio standard for North American HDTV, digital cable, and DBS systems. Optional audio format for most digital video broadcast (DVB) applications worldwide."
KSPSlice is online now
Old 2005-01-17, 09:39 AM   #23
Thanks KSPSlice for confirming my suspicions.
57 is offline
Old 2005-01-17, 09:40 AM   #24
ken0042
Premium Supporter
the .1 in 5.1 is simply an electronic "filter" that sends all lower frequencies to that output on the receiver to allow a subwoofer to handle the low bass frequencies.
I have to share the suprise that 57 had on this one. When I was in the electronics business in the late 90's, I had it explained that 5.1 was actually 6 channel, and the ".1" had information hard coded for the subwoofer. The only reason it was called 5.1 rather than 6 channel was so people wouldn't confuse a subwoofer as a speaker; because as you correctly pointed out, low sounds that come from the subwoofer are non-directional. (Or at least not significantly by the human ear.)
I also notice that when I am making a backup copy of a DVD, it refers to the 5.1 track as "AC-3 6 Channel"
Edit: I see my post came through after everybody else's. Sorry if it looks like we're ganging up on you; I think we were just all suprised.
ken0042 is offline
Old 2005-01-17, 10:42 AM   #25
Q
Would also explain why there is 6 output jacks including a subwoofer on some audio equipment,
Q is offline
Old 2005-01-17, 10:46 AM   #26
dirtyjeffer
i stand corrected...being out of the audio/video business for 8 years has taken its toll.
Old 2005-01-17, 12:23 PM   #27
MarcP
That'd be for DTS-ES/Dolby-EX or whatever DSP processing the receiver can do to feed that extra 6th jack on non 6.1 content.
MarcP is online now
Old 2005-01-17, 12:26 PM   #28
MarcP
Let's be clear... Not on the 3100 receiver. You have to get the higher priced PVR or HD receiver.
MarcP is online now
