Starmate Replay stuck on splash screen - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Entertainment > SiriusXM Satellite Radio
Old 2008-11-05, 12:01 PM   #1
pestyjoe
Default Starmate Replay stuck on splash screen
Hi,
I did some searching around and couldn't find a solid answer, I have a Starmate Replay that when I power on it goes through the cycle of splash screen. It will go through this cycle whenever I power it on and never leaves that step. Any suggestion or ideas? Is there a way to reset the radio internally?
Thanks,
Joe
pestyjoe is offline
Old 2008-11-05, 01:57 PM   #2
Professor Frink
I had two Starmate's do the same thing - there didn't seem to be a fix, they were just replaced.
Toshiba 40RV525R with HD-A3 HD-DVD, DSR505 and Xbox 360
Sportster 5 and Boombox with Best of XM
Professor Frink is offline
