For some reason I am loosing high freq on one speaker for 30 sec-1 min and always resolves itself afterwards.
current setup: speakers : B&W 804 preamp : Celest 4001 se amp: Celeste 4070 cd : arcam 62 ATSC tuner : Digital stream 1150 what I noticed : happenes sometimes on startup, but not all the time always resolves itself after a min occurs with the cd, never noticed it from tuner, but can't confirm hypothesis: cd, pre-amp or amp ? any clues ? Thks for helping |
I'd start by reseating all the cables. Perhaps there is a tarnish buildup on a cable on the affected side. Most likely a cable rather than the speaker wire itself. As the heat generated by the affected input expands the metal then proper contact is made resulting in the speaker starting to work properly. My guess anyway.
