#256 |
I went the multiple small drive route at first. I already owned 3 that were seldom used so it seemed to make sense. The experience was far from good. The smaller drives filled up way too easily and switching them was a pain. After having several nuked archives, I opted for a 1TB WD drive and there have been zero problems since. It's never been over 3/4 full and I can always find some stuff to delete once it gets that much programming stored. 1TB drives are cheap enough these days that it just makes sense to go that route.
#257 | |
Bell 6131 (thanks Bell),4100,6141 Sony KP-51WS520 CM 4228 Garmin c340 265WT 1490T 295W 2460LMT PS3 |
#258 |
Update...
After emailing and calling Bell several times with my persistent disconnect problem while playing archived programs from my Lacie 1TB EHD, they shipped me a refurbished 9242 receiver. Last night I archived a few shows over to my EHD, which had to be reformatted since I now was using a different Bell receiver, subsequently deleting all the movies I had previous recorded. Then I played back two programs (1 hour each) in full without any disconnect incidents. I would have preferred a new Bell receiver, but the refurbished unit appears to be in very good condition and I can live with it if it solves the problem and allows me to use the Lacie EHD without disconnecting. So far so good. |
#259 | |
#260 |
The 9242 does not support standby, but you can switch the drives off. I use a docking station, and I turn it off and leave it off unless I am archiving or restoring. Since the EHD is not actively used by the machine, there is no need to leave it on. Each time I turn it on, the 9242 recognizes the new USB device, and the connection is made. This has not caused me any problems in terms of the disconnect/drive associated with other receiver errors.
Pioneer Elite VSX-01TXH, 46"XBR4, PS3, 9242, MacMini |
#261 |
That is correct. Just don't turn it off while archiving.
#262 |
Is anyone successfully using an Iomega Prestige 1TB EHD (34275 version) with the 9242 PVR? What internal HD is inside?
I ordered one from Dell.ca to replace the current Ultra Speed 500GB EHD. It is on sale for $99.99. |
#263 | |
#264 |
It should work,
I have an Iomega 1Tb model GDHDU, got it at FS and it's been working fine for 3 months now. |
#265 |
Hello everyone,
I received a replacement 9242 today from Bell. It's hooked up and functioning. I'd like to connect the EHD full of recordings from my old 9242. It detects but only gives me the option to format. I thought the three strikes rule would allow me to move my EHD between 9242's on the same account? Am I doing something wrong, or is there some way I can use Linux to move the recordings off, format the drive on the new PVR, then use linux again to move the recordings back to the EHD? Thanks for any suggestions! |
#266 |
That's odd, because I just did almost the same thing except that it simply asked if I wanted to manage the recordings on the detected drive. I answered yes and everything was intact and accessible. Mine was to a new 9242 though, not a refurb.
-Mike
Pioneer PRO-110FD | Pioneer VSX-92TXH | BELL 9242 | Panasonic DMP-BD35 | XBOX 360 |WD TV Live Hub |
#267 |
Thanks scrooloose! I just tried the EHD again and all is well.
Perhaps the PVR needed more time to learn it was on the same account, although I had waited for my programming to synch first last time. Now to test if this replacement 9242 can actually use the EHD properly... |
#268 |
Currently I am renting a 9242 and I assume that is what you have. Was the "new" receiver brand new or a refurb?
#269 | |
FYI - copying the files via linux, formatting the drive and copying the files back would not likely work either as the IRD would still be unlikely to recognise the authorization to access the drive. |
| Tags |
| 9242, belltv, ehd, expressvu, firmware, linux |
