#1 | |
http://www.timesonline.co.uk/tol/new...cle5024190.ece
I wonder how big the nuclear pile would need to be to power a commercial airliner?
Nuclear generators create heat that run steam turbines so getting that process to be as efficient as a jet engine is likely the major stumbling block. |
I see nuclear coming to the shipping industry, before aviation. All of the technology already exists for military vessels, and access to emergency coolant is immediate.
The aviation industry has to establish a near perfect record of safety before this ever takes off (pun intended). Even if they build an indestructable reactor design, the public will never allow it otherwise. |
Holy radioactive crap, how low some scientists would go just to milk more grants from the "Fight Global Warming" blunder!
Thank God airplains don't crash so there's no danger of radioactive contamination that way. And once in blue moon when they do crash it is possible to target inhabitated place far from this planet. What can go wrong there, eh?
That could result in some spectacular, and very nasty, plane to ground crashes...
Actually, I know that no 'explosion' would result, and radioactive debris would just spread over a large area (which is still a major catastrophie), but tell me that an image of a mushroom cloud didn't flash through your mind for a second when you read that report. Cheers. |
#7 | |
I am sure when lowly Rudolf Diesel made a similar proposal he was met with scoffs and suspicion. In fact his untimely death was considered suspicious by many.
The issue here is not whether there should be a replacement for organic jet fuel - it is a fact that oil will run out and jets will have to use hydrogen or something more advanced. The point is that this scientist knows very well that the public will never accept to fly radioactive dirty bombs - now or ever - but he obviously continues to conduct his funded by the government "research", and the only 2 things he can come up in support for it are the "Save the Planet" chant and "the plane may stay in the sky a few hours longer". Guess who would give him any money if he stuck only with the latter argument.
#9 |
the terroists would love this. now they have an easy available dirty bomb at their disposal.
As for running out of oil, that won't happen in our lifetime |
#10 | |
Location: Vancouver - OTA, Pioneer KURO Elite Signature PRO-141FD, 27" iMac, WDTV Live.
#11 | ||
Unfortunately planes do crash. The key to any nuclear powerplant would be containment in a crash scenario and I'm sure this is one of the key things that they are working on. But compared to hydrogen, nuclear fuel is much more stable. Liquid or gaseous hydrogen (and the accompanying oxygen that would be required) are tremendously volatile and because of the volume required they tend to create very large fireballs. Since any nuclear solution will need to be small, it could presumably be wrapped in enough protective layers to contain the damage from any crash. Remember, there's no more fuel to burn in the crash so it only needs to worry about mechanical damage that causes a breach in containment. Personally I'd be more worried about the high speed turbine blades busting loose. |
#12 | ||
cheers. |
#13 |
Security and containment go hand in hand. If a plan crashes and the nuclear reactor is simply a large metal cylinder that sits there waiting for removal, whats the problem?
If a nuclear powered plane had crashed into the WTC there would have been no fireball from the jet fuel and the buildings would probably not have collapsed. It took more than a few weeks for NYC to recover. |
#14 |
Biofuels will ensure that we never completely "run out" of fuels - they just become more expensive. But not nearly as expensive as developing and maintaining thousands (millions?) of nuclear reactors... I agree that the shipping (and maybe the cruise line) industry would be far better suited by a shift to nuclear because at least the size constraints aren't there, and the technology already exists.
#15 |
But you're talking about today's nuclear reactors.
Without serious research the problems won't get solved and none of us will be able to stuff some garbage into our "Mr. Fusion" and power our flying Deloreans. The first part of the above was serious BTW. |
