#1156 |
No doubt a challenging area with lots of high-rise buildings, and the home itself only a bungalow.
TV Fool Report With only a very directional high-gain VHF antenna (the Wade-Delhi VIP307SR), an 8dB-gain drop amp, and about 30' of RG6, I was able to receive the following: CIII; Global; RF 6; Paris; 100% CKCO; CTV; RF 13; Baden (Kitchener); 100% CICA; TVO; RF 28; Paris; 70% CFPL; CTV2; RF 10; London; 70% With a UHF antenna, we hope to get CITY TV Woodstock, and maybe some of the stronger Toronto stations.
DMX 68' tower, HyGain HAM 5 rotator, Antennas Direct 91-XG & C5, Channel Master 7777 preamp, Siemens surge protection |
#1157 |
Is that your old one Jase?
How did manage that into an attic?
roof mounted 35ft UHF Antennas Direct XG91, VHF Delhi VIP 302SR, RC 6292, Tii Coaxial Lightning Surge Protection |
#1158 |
Yes, my "old" (new and hardly used whatsoever) VIP307SR.
The antenna comes in three sections and the elements are hinged. It was easy to assemble in the attic and deploy the elements. Though being 16' long, you can't get it close to the peak of the roof. Therefore probably not the best antenna for an attic install--though it does have excellent gain.
#1159 |
I am in the centre of Guelph with using a DB8 Antennas Direct, with a CM7778 amp mounted on my roof (about 30 up). I sit on a hill, and unfortunately the direction the antenna points actually looks towards the slope (meaning I probably have less height than I think).
I am running about 75 feet of coax directly to my TV. I am pointed at about 90 degrees (using magnetic north). Here's my TV fool - http://www.tvfool.com/?option=com_wr...0b867b3d28de77 I currently get: 5 CBC 6-1 Global (sometimes) 11 CHCH (sometimes) 13 CTV (Kitchener) 25 CBC French 31 CTS 41 -1 Global Unfortunately, my TV doesn't give the best information when it comes to signal strength (so i have no percentages to contribute). I thought I would get CITY and OMNI from Toronto, but I have only gotten City three times in the past 6 months. From time to time I also pick up US stations. Do I need to switch to a more directional antenna (Yagi 91X)? I would like to get a few more stations, specifically the Toronto ones. Any thoughts? |
#1160 |
So I'm assuming that the slope is in the actual direction of the CN Tower? In your case that's 81° actual, 91° magnetic? If so, you may be beat. Though you're getting Global from Toronto, so that's a good sign.
The 91XG may be a better option, though the DB8 is an excellent antenna. The 91XG would allow for more mast space, where you could install a small VHF antenna to possibly receive CFPL London, CHCH Hamilton (until it moves to UHF, currently rumoured to occur this summer). Before you change antennas, I would suggest a rotator for fine tuning. There are plenty of transmitters available to you that aren't from Toronto. For example: CITY TV 31 Woodstock, TVO 28 Paris, etc. But you need to rotate the receive these. Though my guess is that a decent rotor will allow you to fine tune more stations.
#1161 |
In the last 2 weeks I have built both a stealth hawk and a super stealth hawk... mounted both up 15ft just for testing and they work great... fantastic work done here!! I am really impressed by both of these and I have had several people ask to borrow them to test them out. But, in an effort to get a bit more out of this design, I have a question that you guys may be able to help me with....
Super Stealth Hawk mounted 15 ft high... about 100ft of coax, running through an 18db Philips Amp (4.99 at princess auto) I get the following channels: 6.1 - Global - CIII - 90-100% 10.1 - CTV2 London -CLPF- 50% 11.1 - CHCH - 30% 13.1 - CTV - CKCO - 80% 28.1 - TVO - CICO - 80% 31.1 - CITY - 70% I consider this great... basically picking up what is available 30-40 miles both directions... Here is the TV fool: http://www.tvfool.com/?option=com_wr...267e0f36c16caf Now, here is the question... When I do a channel scan, I can see the TV slowing to look at certain stations (others from Hamilton and TO)... it takes a minute and then moves on (with out finding anything). The Global tower in basically in my back yard (6.1)... I get great reception and no issues with the 18db amp in place... If I go with more power (channel master CH-7777) I know am going to have issues with global being so close... I noticed that Winegard used to sell amps that could do 17db on VHF but 28db on UHF... would something like this help me or am I just screwed due to location? They are still around to buy, just not being made anymore it would seem; or is there a way to cut the VHF db's and go with a Channel Master CH-7777? Any help would be appreciated!!! Great job here guys... can't say enough about the time an effort put in to design something that works and well!!! BTW... 1/8" x 1/2" alum. flat bar works well for the Super Stealth Hawk... That is what I used for mine (11.99 for 8ft @ Princess Auto) |
#1162 |
Remember, the key is adequate signal-to-noise ratio for successful reception. A preamp does not help with that. In fact, preamps add noise. In your case, you are exchanging some additional noise for avoiding the signal loss in the 100 feet of coax - a fair trade off.
If the tuner is pausing, then you're right at the edge for reception. Any increase in signal-to-noise will help. Typically, the inexpensive preamps can be quite noisy, with noise figures of 7 dB or more. The better models sport much lower noise figures, like the Antennas Direct CPA-19, which has a noise figure of around 2. That's 5 dB to the good for SNR. That particular preamp also is more tolerant of strong signals.
OTA, it's a beauty way to go! |
#1163 |
Location: Dunnville, Ontario on the Grand River, North shore Lake Erie
jamesota,
You are now using an 18db Philips Booster Amp (4.99 at princess auto),.. The lower price stuff usually indicates higher noise factors. That 100ft is potentially a significant line loss for a 10db widebeam antenna, so a preamp may be needed to overcome that line loss in order to get something from Hamilton/Toronto, etc.. A good mast mounted preamp will generate much less noise than a cheap booster amp,, and a mast mounted preamp should completely overcome the 100ft line loss without as much added noise that your cheap booster amp is generating. Your tvfool results do seem to be a bit weak for Ayr reception. Ayr seems to be a bad location for OTA reception. I tried a tvfool report for Ayr Ontario at 30ft and there wasn't much improvement. You could probably use a CM7777 using the UHF only setting. Even though when using the UHF only setting which is supposed to cut VHF signals,.. those very strong local channels 6&13 VHF will probably still come through strong enough. Maybe you could borrow a preamp from someone to do some testing?
3D SSH III with ZZ4 refl. http://imageshack.us/user/jmsdigital |
#1164 | |
I'm down near Exhibition Park and those are the exact same as I am getting. I get City a little more, but not much. Maybe once a month. I have the same antenna, different amp. About 30 ft up myself. Obviously, lower than you. Report back if you're able to pick anything else up. |
#1165 |
So, I read your both posts and got to thinking... put the preamp at the end of a 12ft cable off the antenna; yes, hanging in mid air with extension cord
Yes, Ayr is not ideal placement, but on the bright side, I am on top of the hill on the east side of town. I did another TV Fool @ 20ft and most of the 2 edge from TO turn into 1 edge (I am almost where I need to be): http://www.tvfool.com/?option=com_wr...267ef88ed64e06 I bought the amp because it was 5 bucks a just for testing... yes, not a great choice, but it helped show what was possible if that makes sense? The reason that I was looking at amps like the Winegard AP-8780 because I would like to keep the 50% signal I get on 11.1 (CHCH) and 10.1 (CTV2 from London) that I currently get with 18db amp and put more gain toward UHF that would help with Toronto. I would lose that by only using the UHF on the CH-7777. I noticed that most amps (if not all) with 15-20db VHF and 25-30Udb UHF are not being produced any more (but still available)... which makes me think that I should buy one sooner than later. Is there a reason they are not making these anymore (incompatible with HD OTA??) or just no market for them? It would seem to make the most sense for someone in my position. Thanks again for your help!!! |
#1166 |
Location: North end of Lake Simcoe (Val Harbour on Barnstable Bay)
jamesota... if you are looking for a good low noise pre-amp... a member of this forum... GerryB... designed and builds his own which if he still has any left will sell you one... I got one and it worked better for my location than the CM7777 I started with... I'm currently using the DB8 antenna... this summer I plan on testing some more using 2 matching pairs of antenna and coax leads and preamps... so I'm getting another one of GerryB's preamps.
for a low noise pre-amp you should look into GerryB's piece of art. http://www.digitalhome.ca/forum/show...=142375&page=6 Also you must consider what tuner you are using and how sensitive it is to weak signals and how well it handles overload... From my location I can see the CKVR tower across the lake... basically its a flame thrower with LOS to the tower... but because its off to the side from the aim of my DB8 it does not overload my tuner.. because my rear projection Mitsubishi TV does not have a digital tuner, my tuner is a set top box the ******** DTV-5000. |
#1167 |
Hi all,
Here's where I stand, and what I am planning to do. I have a ClearStream 4 antenna set up in the attic, with a CM7777 preamp. Height off the ground is maybe around 15-20 ft or so, but it is inside the attic, with a 100-ft lengh of coax to the tv location. My first attempts with this got me the following: CBC (29 analog) CKCO (13.1) TVO (28.1) I am now in the process of moving the antenna to the roof, with a mast & rotor. I havent' done this yet, but it is my springtime project. But, I have started some of the 'indoor' work: last weekend, I put in a ground block into the basement, & hooked the ground up to a cold water pipe. Note that for my outdoor installation, the antenna/mast will actually go to a grounding rod that is already outside; the 'indoor' ground block is intended to equalize the outdoor grounding rod with the main ground of the house. Anyway, after adding a proper grounding to the coax shielding, my reception improved, so that with the attic setup (as above), but now grounded coax shield, I am getting: CBC (29 analog) Global (6.1 and 6.2), about 25% CHCH (11.1) most of the time, but signal level is low, get the station about 80% of the time CKCO (13.1) - good signal level TVO 28.1 - good signal level CITY (31.1) most of the time, but signal level is low, get the station about 80% of the time. At this moment, I cannot rotate the antenna in the attic due to lack of space. My next step is to mount the antenna (with rotor) onto a 5-ft mast above the roofline. Fortunately, a previous owner already has a place to mount it, so I'll put it there. (and the ground rod was already in place as well). I'll post results once I have it set up. I am a bit slow at doing home projects, because we have a lot of small kids at home, but I am hopeful at having my new setup up and running by the end of this month. Will post when I have results. Comments are welcome..... Cheers sparky640000 |
#1168 |
Hi all. My name is Matt. This is my first post here.
I have been experimenting with OTA for about 6 months now. I started with a home built antenna made from 14 gauge copper wire, a 2x6 and a $5 ballun from The source. Mounted on a patio table post that was stuck in the end of a J mount from an old Satellite that is attached to the side of my chimney about 25 ft up. Pulled in 4 channels, 13,23,28,36. All but 36 were somewhat intermittent. Then I bought a ******** ANT2084 from Factorydirect on sale for $20. Pulled in the same 4 channels. Last weekend I bought a CM7777, DB8, chimney strap, some good cable connectors and the tools to install them. I started with just installing the CM7777 with the ******** antenna. Right away I pulled in 17 channels. 2 were analog, 3 were lower resolution duplicates. About 12 good quality HD channels. I'm currently pulling in 4-1 5-1 7-1 13-1 17-1 17-2 17-3 19-1 23-1 25-1 28-1 29 31-1 36-1 41-1 41-2 61 This weekend I will setup the DB8 with the chimney mount and a 10ft mast so hopefully I'll reach 30ft from the ground. Anxious to see if I get anymore channels with the DB8. I'll post back with my results after it is done. Thanks to everyone that posted their results in the past. They helped come to my decision on components and so far I'm happy with the results Matt. Last edited by stampeder; 2012-04-12 at 03:36 AM. Reason: location added to title ;) |
#1169 |
Since getting some ganging tips from Roger1818, I have increased my channel count, and improved signal quality, using 4 antennas in my attic! Yes, 4 antennas, I don't want to deal with a rotator. Want the WAF to be as high as possible.
The channels with the "*" next to them are the only ones that are spotty when the weather is not cooperating. My upgrade to a DBGH will help take care of the Buffalo stations. Results VHF input <- Dipole 6 (Global) 100 9 (CFTO) 87 10 (CFPL) 80 11 (CHCH) 87 13 (CKCO) 94 UHF input <- Splitter #1 Input 1 - SBGH pointed to Buffalo 36 (CITS) 89 39 (4) (WIVB) 72 * 38 (7) (WKBW) 77 * 43 (17) (PBS) 65 * 32 (23) (WNLO) 72 UHF input <- Splitter #1 Input 2 <- Splitter #2 Input 1 - 4Bay DIY Clone pointed to Toronto 20 (5) (CBC) 78 28 (TVO) 83 47 (CFMT) 64 * UHF input <- Splitter #1 Input 2 <- Splitter #2 Input 2 - SBGH pointed towards Woodstock/Paris 19 (TVO) 76 31 (CITY) 74 My earlier post a page or 2 back has my TVFool link. |
#1170 |
You've done well Matt.
Are you pointed directly at CN Tower? |
