1080i vs. 1080p Signal with 505 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Direct (formerly Star Choice)
Old 2008-10-10, 02:50 PM   #1
TheHans
Default 1080i vs. 1080p Signal with 505
I have a two 505s. One is hooked up via a DVI to HDMI cable, the other via a component cable. Both are hooked up to a Sharp 46D64U, which supports 1080p. In both cases, the broadcast signal is coming in at 1080i. I can't find anything on the recievers nor the TV that deals with this specifically. So I'm not sure if it has to do with the TV, the receivers, both or neither one. Is this just the signal itself, meaning that the hardware has nothing to do with it? Or can I set something on the receivers that will get it to send over the signal in 1080p?
The Hans
TheHans is offline
Old 2008-10-10, 02:55 PM   #2
bwaldron
There are no satellite-delivered 1080p signals. You're fine.
bwaldron is offline
Old 2008-10-10, 03:00 PM   #3
TheHans
That explains it then. Thanks!
The Hans
TheHans is offline
Old 2008-10-10, 03:26 PM   #4
For more on the topic, see:
http://www.digitalhome.ca/forum/showthread.php?t=76129 Formats
http://www.digitalhome.ca/forum/showthread.php?t=87543 Upconversion.
57 is offline
Old 2008-10-10, 04:31 PM   #5
TheHans
Originally Posted by 57 View Post
Thanks for directing me to that thread. It was illuminating.
The Hans
TheHans is offline
