Panasonic TH-C50FD18 vs TH-50PZ80 - Canadian TV, Computing and Home Theatre Forums
Old 2008-10-10, 12:48 PM   #1
stoon
Default Panasonic TH-C50FD18 vs TH-50PZ80
I was wondering if anyone out there knows the difference between these plasma's.
It looks as if the C50FD18 is for Costco only.
stoon is offline
Old 2008-10-10, 12:59 PM   #2
CyberStorm
Maybe take a look at these threads and see if it helps you out at all.
http://www.digitalhome.ca/forum/showthread.php?t=91350
http://www.digitalhome.ca/forum/showthread.php?t=89628
CyberStorm is offline
Old 2008-11-12, 11:22 AM   #3
Zyla
The costco model has a PC input, the PZ80 doesn't. Aside from that, the differences are purely cosmetic (ie cabinet is different and not as shiny.)
Zyla is offline
