voip.ms discussion - Page 53 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > VoIP Providers
Old 2010-03-21, 06:31 PM   #781
Mango
Call Waiting can be configured in your device. Look for "Call Waiting Serv" on the Line tab.
Mango is offline
Old 2010-03-21, 07:37 PM   #782
SheeB
I do have a fax machine I occasionally use, so I am curious at to what optimal settings I would need to put into the PAP2 to ensure the best possibly connection for success? Obviously the other post implies that premium routing would be required, which is no issue for me.
SheeB is offline
Old 2010-03-21, 07:43 PM   #783
Mango
Faxing with VoIP.ms is not guaranteed to be reliable because neither VoIP.ms nor the PAP2T support T.38. For low volume faxing, it might work, as Merve has discovered. Here are some good tips:
http://www.future-nine.com/faq/index...d=5&artlang=en
Note that they suggest disabling ECM. This can sometimes make faxes work with VoIP when they otherwise wouldn't. However, this has the added side effect of the fax machine sometimes reporting successful send when the send was not successful. If you must turn off ECM, then you should call the recipient of the fax to verify that they received it.
m.
Mango is offline
Old 2010-03-22, 09:18 AM   #784
merve04
Yes premium routing makes a world of difference, I have set my ATA to strickly use g711u and my device supports t.38
Panasonic PT-AE4000|Pioneer VSX-1021K|Soundstage STAGE3D4, STAGE3D2C, STAGE3D2, Velodyne VDR-12|Sony BDP-S350|WDTV Live Plus|Telus CIS430|Harmony One
LG 55LE5500|H\K AVR 347|Yamaha NS-8390|Polk Audio PSW-10|Samsung BD-P1600|WDTV Live|Telus CIS330|Harmony 600
LG 42LC7D|ASUS O'Play|Telus CIS330|Harmony 600
LG 32LS3400|Telus CIS330
merve04 is offline
Old 2010-03-22, 04:17 PM   #785
Grand Total
Default DISA feature
Voip.ms have added the DISA feature. It seems to work OK, but does not handle calling a number in my phone book (*75xx).
Grand Total is offline
Old 2010-03-22, 04:20 PM   #786
FunkyTown
You could setup an IVR to answer when you call. Then program short codes to access your numbers or DISA.
FunkyTown is online now
Old 2010-03-22, 08:08 PM   #787
merve04
voip.ms sure likes to add features, but i dont understand the point of disa?!?!?
does anyone think voip.ms will one day have the option for customers to list their name and number in major white pages?
merve04 is offline
Old 2010-03-22, 09:05 PM   #788
Mango
It's useful when you want to call some place but pay VoIP.ms rates. Hotels for example usually charge a lot for international calls. Now, I'll be able to call a VoIP.ms number and pay VoIP.ms rates instead. It will also be useful for people who have cell phones - a (better) alternative to the Callback feature.
Put in a ticket about that...I seem to remember that being possible though I've never actually done it. If you do it, please post back and let us know what was involved
m.
Mango is offline
Old 2010-03-23, 08:28 AM   #789
99semaj
Default Any experience in the flat-rate DID plan?
I currently am on the $1.49/mo and $0.0149 rate for outbound minutes.
It appears I could save a few dollars/mo by switching to $4.95/mo flat-rate with a restriction of two simultaneous calls.
My question is this: Is the two-call restriction for inbound calls only? If I have two inbound calls, could I still place a third/fourth outbound call?
99semaj is offline
Old 2010-03-23, 09:02 AM   #790
Mango
Yes, the restriction is for inbound calls only. It's intended for residential use, where someone might want to be speaking on the phone with one person and using Call Waiting or letting another person leave a voicemail.
Mango is offline
Old 2010-03-23, 02:58 PM   #791
99semaj
OK, thanks, Mango. It looks like I get cut my usage charge in half for just an extra $3.50 per month. Hard to beat that deal!
I don't suppose you have any insight on my URI question from a couples pages back, do you?
99semaj is offline
Old 2010-03-23, 03:07 PM   #792
Mango
How did you create jones@sip.voip.ms and bob.jones@sip.voip.ms? I thought that SIP URIs always started with numbers, with 11 + Accountcode + 3 digits of your choice for a total of 11 digits. No?
m.
Mango is offline
Old 2010-03-23, 04:24 PM   #793
99semaj
Yes, but there is also an option to create URI addresses in the voip.ms portal.
99semaj is offline
Old 2010-03-23, 04:29 PM   #794
Mango
Are you talking about https://www.voip.ms/m/sipuri.php? If so, that won't create a SIP URI. That will allow you to route calls to an existing SIP URI.
To create a SIP URI, you either order it from the Order DIDs page, or use the default SIP URI for a subaccount.
m.
Mango is offline
Old 2010-03-25, 10:44 PM   #795
FunkyTown
Mango,
I often experience echo when on my voip line. Is there any way that you may have found to eliminate that? I've tried several different settings, and nothing seems to work well.
Tags
byod, voip.ms
