voip.ms discussion - Page 22 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > VoIP Providers
Old 2009-05-16, 11:08 AM   #316
FunkyTown
Well I have contacted support and they said they haven't changed anything on their end at voip.ms.
I've tried switching servers. I'm on the Toronto one now. Let's see how reliable that one is.
FunkyTown is offline
Old 2009-05-16, 11:27 AM   #317
Mango
Wysiwyg: I heard a rumor that Eastern Canada ports are faster than Western Canada ports. Hopefully this is the case for you. Keep in touch with them and be sure they are aware of this date.
99semaj: There are two ways of communicating via SIP URI. One is internally on your network, between the phones in your house, and the other is externally via a SIP URI that you set up on the VoIP.ms website.
The easiest/cheapest way to receive calls from the Internet via SIP URI is to create an Internal Extension on the Edit Sub Account page. Once you're done, the SIP URI will appear on the Manage Sub Account page.
Does this answer your question? If not, there are many ways to use SIP URIs and if you explain a bit more about what you want to do, I'm sure someone here will be able to help you out.
m.
Mango is online now
Old 2009-05-17, 12:28 AM   #318
99semaj
I guess I just don't understand how the SIP URI's should work.
I thought that I should be able to call internally between my IP phones by using IP addresses. i.e. call directly to an extension using the SIP URI listed in the Manage Sub-Account screen. Doesn't work.
Alternately, I thought I could use the SIP URI's screen to create a SIP address that would ring the entire DID.
Can't get it working, though.
99semaj is online now
Old 2009-05-17, 12:30 AM   #319
Mango
If you want to call internally between your IP phones on your private network, try [VoIP.ms username]@[internal IP address]. This works for Linksys devices; I imagine it would also work with Aastra ones. The advantage to this technique is that there is less latency than if you use the VoIP.ms SIP URIs.
Note that for Linksys devices, you must enable the "Allow IP Dialing" setting. A similar setting may exist on your phones.
Does that help? What you're trying should work, though this may be a better workaround.
m.
Mango is online now
Old 2009-05-20, 09:23 PM   #320
mlord
Default Tones heard at the other end ???
I have had several reports now, both from callers and callees, that they hear "tones" periodically during calls with me (I use voip.ms).
Like, "touch tones", or "call progress tones", while we are speaking, every few minutes.
I don't hear them at this end. So I suspect perhaps our PAP2T is doing it, but I don't know which possible config option might be causing that.
Any ideas?
mlord is offline
Old 2009-05-21, 03:20 PM   #321
abcezas123
Same here. I hear it when I call from my cell into my DID at home. Mix of analog phones connected via a spa3102.
abcezas123 is offline
Old 2009-05-22, 12:11 PM   #322
holymoly
Tones could indicate a call waiting. I get more of a beep. Is that it?
holymoly is offline
Old 2009-05-22, 02:43 PM   #323
mlord
No, the party on the other end does not have that feature. Remember, it's others who hear it, not me the voip.ms user.
I tried it today -- called home from another line. It's kind of a flat tone sound, once in a while during the conversation.
Peculiar.
mlord is offline
Old 2009-05-25, 05:29 PM   #324
profets
thought i'd post an update.. I made a request to port my # from teksavvy to voip.ms on may13. i've had several email updates during the past week and received an FOC for May 25. Just a little while ago the pots line at home stopped working. when i have a minute I gotta setup my pap2t and see how it works.
Less than 2 weeks for the whole port, not bad.
profets is offline
Old 2009-05-25, 05:45 PM   #325
wysiwyg
Thanks for sharing this. I'm still waiting for my FOC date. I need to terminate the line by June 26th, so I just hope it happens before that as I don't know how much time to gve Bell to cancel a line if the port did not occur yet.
It's only been a week since it was submitted to Bell, so it's still good.
Is there a way to tell if Bell received it? Would calling 310BELL help? I know their phone CS is terrible.
wysiwyg is offline
Old 2009-05-25, 08:53 PM   #326
tbusa
I have ported about 10 bell lines and all took around 13-18 days, I didn't get the FOC date until the last day of the all the ports.
They must be bleeding DID's like crazy
tbusa is offline
Old 2009-05-26, 06:29 AM   #327
profets
^lol...
a year ago i was with bell and ported to teksavvy. took a few weeks that time.
profets is offline
Old 2009-05-26, 08:54 AM   #328
apn
@wysiwyg: Per my upstream comments, the port to voip.ms can be frustrating.
Even though you technically don't need to speak to the telco you're leaving, I found it worthwhile because there's still a lot of blind waiting for the LNP request to complete. You're basically in limbo once voip.ms has sent the request to your carrier.
You can call Bell to ask if they've received the port request (I had to do this w/ Rogers), however, just be prepared to be 'talked-to' by the retentions department
In my case, Rogers confirmed they'd not received anything (this after voip.ms said they'd sent it weeks earlier), so I had to kick voip.ms in the pants to re-submit and expedite the request.
Check everything!, as an old Manager once told me, You get what you inspect, not what you expect
PS: After some initial glitches and adjusting my NAT settings, my service has worked flawlessly. My In-Laws just completed a port from Bell last Friday, and another relative is bugging me to help him escape Rogers.
apn is offline
Old 2009-05-26, 09:54 AM   #329
wysiwyg
Thanks everyone. I'm still well within the timeline for a porting request, so if in 1-2 weeks, there's still no action, I might start to call Bell to check. I'm really looking forward to begin using voip.ms as my primary line :-)
APN, how long did your relative's port request take from the time it was submitted to Bell?
wysiwyg is offline
Old 2009-05-26, 10:53 AM   #330
apn
20 days start to finish: requested Saturday May 2nd, ported Friday May 22nd
apn is offline
Tags
byod, voip.ms
