#2086 |
As you using premium routing?
Caller ID delivery isn't guaranteed otherwise. |
#2087 |
Isn't DID by default is premium. Incoming calls are automatically charged as premium.
#2088 | |
#2089 |
Caller ID on DID is working again. Maybe VOIP.ms did something.
#2090 |
I have just set up my PAP2 a couple weeks ago on voip.ms
This thread is extremely long, but i have covered the first 20 pages or so Anyways, i noticed my testing had call take about 30 seconds to get placed, which i take is related to my dial plan. So i have come up with the following, but before i go ahead and put it in, i was hoping for some double checking: I am in 519 are code, and we make call to 502 country code, so: (x11|*xx.|0|519xxxxxxxS0|1[2-9]xx[2-9]xxxxxxS0|011502xxxxxxxxS0|011[2-9]x.) my decoding: x11 - allow 911, 411, etc *xx. - allow feature calling 0 - allow call to operator... does anyone do this anymore? ;-) 519xxxxxxxS0 - 519 area code number dial right away 1[2-9]xx[2-9]xxxxxxS0 - NA long distance 011502xxxxxxxxS0 - intl calls to 502 country dial out (they use 8 digit #s) 011[2-9]x. - any other intl calls allowed Am i leaving anything important out? |
#2091 |
Someone mentioned to me that it is possible to setup your VOIP/ATA account so when you call your VOIP DID from your cellphone, you could have the option to effectively make a call from your cellphone though your VOIP account, which would be a cost saving for long distance calls. Would this be a feature of the VOIP.ms account or the ATA? If this is possible, are there any pointers on how to perform this setup.
#2092 |
RamKat,
That is correct. All you need to do is obtain a SIP client for your smartphone device. Something like SIP Droid for Android or Bria, Media 5, amongst many others for iPhone. Some will also have all the settingsd already there for VOIP.MS, so you just need to enter your username and password. Be sure to create a new Sub-account in your profile for your SIP app connection. Some things to consider: 1. It is recommended to use the G.729 codec for GSM connections. It is an add-on on all apps. 2. Ensure your GSM data plan allows voip. Some prohibit it (mostly in Europe) 2. When using Wi-FI, ensure you are in a quiet environment and the speed is sufficient. This is often a challenge for public/open hotspots. |
#2093 |
I think you want to look at DISA and set up an option to call out and have it come up as an option when your numbers call your DID.
I have it set so if any of our mobile numbers call, the "receptionist" IVR? kicks in and gives us a choice to press a key for DISA and then we can enter a pin and dial out wherever, if my memory is correct. Been a while. |
#2094 |
Thank you wysiwyg, I will certainly give that a try when I finally give in and get a smartphone, at this point I am still way too cheap for that.
gzink, thank you for the DISA keyword, that is just what I needed to get going(I can google therefore I am). After reading a bit about it the other option would be to use callback. I like Mango's idea of an iNUM earlier in this thread. I will certainly try a few options. EDIT I set my account up using the DISA feature and it is working like a charm - thanks again gzink |
#2095 |
Here is another question to the gurus. Sometimes when I answer the caller wants to leave a message for one of the family members. Instead of me taking the note (and forget about it) is it possible to forward the call to our voicemail system?
#2096 | |
Only on inbound calls. Today heard person for a few seconds then cut out. Alot, ALOT of the time I pick up and nothing at all, just a dead connection. Found this out calling the wife and third time she could hear me. Tested by calling from cell to Voip.ms account and confirmed the problem. Currently on Toronto2 as well! |
#2097 | |
Answering calls is the most frustrating though. I'd say this now fails something like 70-80% of the time. |
#2098 |
Some of these one-way audio problems have been noted on the voip.ms homepage. I called in today, and they suggested it was a DID vendor issue.
They seemed to be pretty confident about that... Later that evening I called into Teksavvy and had a similar problem with them not being able to hear me... My DID Vendor is for Orillia, and I understand Teksavvy is based in Chatham. Anyone know how to figure out who the DID vendor's are? (CLECs as i understand?) |
#2099 |
I'm getting 1 way audio on my Toronto and Mississauga DIDs too.
For incoming calls - audio goes into voip.ms; doesn't come back to PSTN. VOIP says it's a DID vendor issue - but don't give any time to clear. ;-( Still broken at 22:15 EST 2011-12-08 |
#2100 | |
FYI, there's a new update on the VOIP.ms page that says the DID problem is now fixed:
| Tags |
| byod, voip.ms |
