How to change IP address ? (Shaw cable) - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Communications > Shaw High Speed Internet and Home Phone
Closed Thread
Old 2008-09-11, 05:28 PM   #1
abceroa
Default How to change IP address ? (Shaw cable)
Hi
I already tried disconnect the modem for 5 minutes and than reconnect , but the IP remain the same
So how should i do it ?
Thanks in advance
abceroa is offline   Quick reply to this message
Old 2008-09-11, 05:44 PM   #2
Richard Travale
Location: Vancouver Island. Shaw cable.Sony 46V2500,DCT6416(w/TB Xpndr), PS3, Denon AVR2807, Paradigm spkrs.
you have to call them and ask them to change it for you. Don't know if they will though unless you have a valid reason.
Richard Travale is offline   Quick reply to this message
Old 2008-09-11, 07:39 PM   #3
abceroa
are you sure this is the only way to do it ?
i never thought it so complicated
this is beacuse the IP is static ?
Old 2008-09-11, 07:42 PM   #4
magnet
IP is DHCP... but with a really long lease time.
When it comes to humility, I am the greatest!
magnet is offline   Quick reply to this message
Old 2008-09-11, 07:53 PM   #5
NeilN
Is there any particular reason why you want to do this?
NeilN is offline   Quick reply to this message
Old 2008-09-11, 09:19 PM   #6
CanuckBlue
Get a router. or if you have a router you can go into the router settings and change the mac address that will change the ip.
happy gaming
CanuckBlue is offline   Quick reply to this message
Old 2008-11-13, 02:40 AM   #7
tux
The IP address that you're assigned, is bound to the MAC address of your network card. There's several ways to change your IP, without contacting your ISP.
1) Disconnect your computer from the modem, wait for your DHCP lease to expire, and then reconnect the computer. This is the least convenient method, since it usually requires waiting several days.
2) Connect a router to your modem (or if you're already using a router, disconnect it)
3) Use a different network card to connect to the modem, or use the USB cable instead of ethernet (driver install required for USB)
4) Change the MAC Address of your network card. You don't need any special software to do this. In Windows XP, you can do this through Device Manager ( usually an advanced setting such as "Network Address"), or in Win 98 you can do it through the Network control panel
After any of these changes, you will most likely need to reset your cable modem, by unplugging the power for 30 seconds, and plugging it back in.
tux is offline   Quick reply to this message
Old 2008-11-13, 08:46 AM   #8
dosborne
issuing the commands:
ipconfig /release
ipconfig /renew
should also work in most DHCP environments unless they cache by MAC address.
dosborne is offline   Quick reply to this message
Old 2008-11-14, 10:38 AM   #9
jshel101
ipconfig /release
ipconfig /renew
This will just renew the IP with the same IP address. I have done this. you would probably have to release it, then wait a few days for the lease to run out, as tux pointed out. Then when you renew it, you should get a new IP address.
jshel101 is offline   Quick reply to this message
Old 2009-03-22, 12:31 PM   #10
Slackin
Tux:
I just have to thank you for that one for so many years i used an old method that only works if the lease is like a day on the ip (my isp recently made there leases 4 days ) but changing the mac address instantly new ip
much props
Slackin is offline   Quick reply to this message
Old 2009-03-22, 12:33 PM   #11
Slackin
And for anyone who wants to know the old method is
1. Click on "Start" in the bottom left hand corner of screen
2. Click on "Run"
3. Type in "command" and hit ok
You should now be at an MSDOS prompt screen.
4. Type "ipconfig /release" just like that, and hit "enter"
5. Type "exit" and leave the prompt
6. Right-click on "Network Places" or "My Network Places" on your desktop.
7. Click on "properties"
You should now be on a screen with something titled "Local Area Connection", or something close to that, and, if you have a network hooked up, all of your other networks.
8. Right click on "Local Area Connection" and click "properties"
9. Double-click on the "Internet Protocol (TCP/IP)" from the list under the "General" tab
10. Click on "Use the following IP address" under the "General" tab
11. Create an IP address (It doesn't matter what it is. I just type 1 and 2 until i fill the area up).
12. Press "Tab" and it should automatically fill in the "Subnet Mask" section with default numbers.
13. Hit the "Ok" button here
14. Hit the "Ok" button again
You should now be back to the "Local Area Connection" screen.
15. Right-click back on "Local Area Connection" and go to properties again.
16. Go back to the "TCP/IP" settings
17. This time, select "Obtain an IP address automatically"
tongue.gif 18. Hit "Ok"
19. Hit "Ok" again
20. You now have a new IP address
i cant guarentee it works...but 90% of the time i used i got a new ip (for DHCP assigned IP's )
Closed Thread
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Forum Sponsor
