Hitachi 50V500 - Page 2 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Digital Forum Help and Administration > Archives > 2003
Old 2004-01-22, 11:10 AM   #16
EddieVan
I just purchased one... Total cost, including shipping, setup, GST, was $4900. This also included the Hitachi stand.
I must say I quite like the system. Though the fan is a bit loud when the volume is low. Haven't hooked a PC into the system... yet.
EddieVan is offline
Old 2004-01-22, 12:24 PM   #17
damon9060
I purchased mine for for $3000 USD even (included Hitachi stand and 3yr extended warranty). (But actual price of the set was $2570 USD)
3 Questions:
1) Any recommendations on PCMCIA cards for the Photo Viewer slot in the front? I have SmartMedia for our digital camera but was considering one of the 'universal 4-in-1' types just to be more flexible if I ever get a different digiatl camera.
2) For those connecting their PC to the set via the DVI input, what brand/model video card are you using, or in other words, which ones work well with the set?
3) FAN NOISE - this seems to be a common factor in a lot of message boards regarding these sets. I don't have mine yet, so can't comment, but is it really that loud that it's distracting? Or are some quieter than others? If it is really loud, is it fixable with some adjustments? Just curious.
Thanks.
damon9060 is offline
Old 2004-01-29, 08:49 PM   #18
robinwood
Default pricing
cost 5500.00 including taxes and delivery and basic set up and sony dvpcx985v progressive 400 dvd player/changer
I purchased the ikea stand 129.00 -perfect size! and 4 year extended warranty on both the dvd player and tv just in case!
robinc-pn58c6400 strdb930,sonydvpcx985v ,ps3 ,energy spkrs,,8642 rogers, harmony sst720location miss
robinwood is offline
Old 2004-02-06, 11:43 AM   #19
bolt62
:lol:
new owner joining the ranks, have to wait until next friday for delivery
bolt62 is offline
Old 2004-02-06, 12:20 PM   #20
alphagetti666
damon9060:
1. I only use CF, and I just tried an old adapter I had from an IBM microdrive for the Photo Viewer slot. It worked well. Though I must say I though the scaling of the images was less than stellar, it is convenient.
2. I've not hooked any DVI devices up.... YET!
3. IMHO: It is a little loud. I tend to listen to most shows on a lower volume than most people, and I do notice it. I've not looked into what can be done about it. I'm a little concerned, as on my computers, the fan is the first thing to go! And I'd say this fan is as good and loud as some CPU fans.
alphagetti666 is offline
Old 2005-01-17, 11:03 AM   #21
tommy99
Just how much fan noise is too much for the 50v500? I mean I hear it alright and I do find the constant hum annoying but how do I know if this is what it is suppose to be like or it is a defect.
I just bought this at Christmas and could certainly get it back within the 30 days but I find it's a great TV and have no desire to repack it.
I haven't seen anything in forums indicating owners should call Hitachi to have it replaced because it is a known defect.
Again, if that is the sound of the fan, so be it - obviously the perfect television has yet to be produced. Or, should I be more concerned with the sound?
tommy99 is offline
Old 2005-01-17, 12:24 PM   #22
mike infinity
It sounds about the same as a computer fan. If yours is louder than that then you should get it serviced. From the sound of your post I would guess that yours is probably normal. You get used to it...I don't even notice it anymore.
I have tried several sets at home, all of them had similar fan noise and none of them was much better than the others. The only one I didn't get to try was the Sony GW (which apparently does a little better).
While its not a big problem for me, I believe that manufacturers should step up to the plate and put larger diameter, lower RPM fans into these sets. I, for one, would be happy to spend another $10 to make it a bit more quiet.
At least its not as bad as some of the DLPs with that high pitched whine produced by the colour wheel.
Cheers,
Mike Flynn
mike infinity is offline
Old 2005-01-19, 04:55 PM   #23
casscarr2002
The fan noise on the VS is nonexistent (yes it is on but only if you put your ear up to the back of the set). Only when the TV powers down do you hear it gear up. So hitachi has done something to correct this going forward.
Sony 55XS955, Marantz SR7400, Samsung HDDVD841, Monster HTS3600, Athena ASF1/ASB2/ASC1, 2 X MKV10 subs, Motorola 6208
Cardas/Tributaries/MCTHX1000
casscarr2002 is offline
Old 2005-01-20, 10:00 AM   #24
mike infinity
Unfortunately, they have not corrected things for the 50v710 and 42v515, both of which have seem to use the same fan as the 50v500. The team that designed the ergonomics of the VS series got it right....except for the part where they put the highly reflective glass in front of the screen. Otherwise the v500 is par or better IMO.
I wouldn't spend an extra $1000 for a quieter fan that at most costs manufacturing an extra $10. Hitachi should put this in all their sets and make more substantial improvements across their product range to justify the differences in price.
Cheers,
Mike Flynn
Old 2005-01-20, 10:50 AM   #25
tommy99
I agree with you Mike, I would have expected better from Hitachi with regards to their fans. From what I understand, this company is built on its reputation for using quality parts in their electronics. Having read that the upgraded model from the 50v500 uses a fan, which is such an inexpensive component in the scheme of things that is much quieter, bothers me.
I still spent $4,000 of my hard-earned money on their product.
Does anyone know if replacing the fan is a quick, in-home procedure that might be covered under their warranty? That is, is the better fan the same size, etc as the one in the 50v500?
If customers called Hitachi service and made enough of a stink about this, would this company do the right thing and provide satisfactory customer service?
Well yes, you might get use to the noise and it might just be as loud as a computer fan (which, for the record bothers me as well, but doesn’t come close to what I’ve invested in this television) but knowing that they might have cheaped-out on something that interferes with my home entertainment experience and enjoyment really annoys me.
tommy99 is offline
Old 2005-01-20, 12:12 PM   #26
mike infinity
I'm sure we would get the old 'working according to specs' line from the service department. Remember that Hitachi is not the only company that has this problem. The Panasonic dlps & lcds, LG, and Samsung are among the other members of the 'excessive fan and colour wheel noise' club. I don't know about Sony and toshiba, but I suspect they have similar issues. When the competition does no better, then the manufacturers have us over the proverbial barrel on little details like these.
What I would be willing to do is spend $50 and ask a certified tech to install an upgraded fan and not void the warranty. If my set were past warranty, I might even take a shot at it myself (if the fan was easily accessed).
Cheers,
Mike Flynn
Old 2005-01-20, 03:10 PM   #27
tommy99
I too would certainly make a nominal investment for a quieter fan - please post info if this is a practical endevour.
tommy99 is offline
