Toshiba 52HMX85 video inputs - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Consumer Electronics and Home Computing > HDTV: Front and Rear Projection Screens and Televisions
Old 2008-08-19, 10:39 PM   #1
Fisherguy
Default Toshiba 52HMX85 video inputs
I have my Bell PVR conected to my TV with an HDMI cable, is there any way I can connect the "video out" of my Denon receiver to the TV as well so I can see the receiver's "on screen" text when watching my PVR?
I don't see an RCA "video in" jack on the PVR so am I screwed?
Toshiba 55G300U, Denon 2106, 1920; Paradigm Monitor 11's, C370, ADP 370's, PW2200 sub; TELUS SAT, Harmony ONE
Fisherguy is offline
Old 2008-08-20, 06:16 AM   #2
mfabien
Your Denon 2106 has component Video switching. To display the Denon settings on your TV display, connect Component from the PVR to the Denon input and Component output to the TV.
When done, resume use of HDMI.
Samsung LN52B750, SVS PB12-ISD, Harmony One, HD-A1, BDP-1400, Oppo DV-970HD, Zektor HDS4.1
mfabien is offline
Old 2008-08-20, 08:16 AM   #3
Fisherguy
I don't follow, you're saying connect the PVR to the receiver using RCA cords and RCA cords from the receiver to the TV? Then I guess I'd change the TV to watch the 'component IN' to watch the PVR, right?
Aren't I better off using the HDMI connection directly from the PVR to the TV though?
I have the receiver's video out connected to an RCA IN on the TV, but in order to see it I have to change the input from the HDMI IN to the VIDEO IN which means I get a black screen with the receiver signal, what I wanna be able to do is see the receiver's output while watching the PVR.
(I guess I shoulda bought a receiver with HDMI INS and OUTS but they weren't so common back then...
Old 2008-08-20, 09:52 AM   #4
The TV cannot "see" two inputs at the same time. You need to switch to an input on the TV that carries the OSD from the AVR.
57 is offline
Old 2008-08-20, 10:13 AM   #5
Fisherguy
Okay, what's OSD?
Are you saying I'm outa luck?
