Daenyx Power Cable? - Canadian TV, Computing and Home Theatre Forums
Old 2008-08-03, 05:13 PM   #1
Miss_LCB
Question Daenyx Power Cable?
I have a 19" flat panel LCD DAENYX display.
I do not have power cables for it.
I need some.
I can;t find anybody in Ottawa that has heard of this brand or knows any information about where I can purchase power cables for this type of TV.
Can anybody help?
the model number is DN-19
thanks!
Miss_LCB is offline
Old 2008-08-03, 08:03 PM   #2
congo
Miss_LCB,
When you say power cables, do you mean the power cord that connects the display to the power outlet in the wall? If so, you can find one at a computer store. Most flat panel televisions/monitors use a power cord with an end similar to this:
http://www.allproducts.com/manufactu...dung/lt501.jpg
It will plug into a socket on your panel similar to this:
The other end is a normal 3 pronged plug that goes in the wall.
In some cases, the smaller panel like you have may have an external power supply which may be more difficult to find. Again, a computer store might be able to help you there. The power supply may look something like this:
Click link as image is quite large to show here.
http://www.short-circuit.com/images/...adapter-lg.jpg
Hope this helps.
Congo
Panny TC-P60GT50, Bell 9242, Yamaha RX-V730, Paradigm Cinema 70, Harmony One, HTPC
congo is offline
Old 2008-08-04, 10:03 AM   #3
Miss_LCB
Thumbs up
Congo,
Thanks for your help.
I was told at future shop the other day that I need a power box coverter. I have no idea what this means but I think it is like the second image you posted.
I didn't think to call computer stores for power cables for a tv.
Thanks for the suggestion!
Miss_LCB is offline
