To Rent or Buy HDTV Cable Box? - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Rogers Communications > Rogers Cable TV
Old 2008-07-25, 01:34 PM   #1
Algonquin
Default To Rent or Buy HDTV Cable Box?
Background: Currently I have the Standard Def. Rogers digital cable box connected to my new HD LCD TV.
I would like to get the HDTV Cable box, but I would like to know which is the better route: renting one from Rogers or purchasing one from Future Shop or another retailer.
What is holding me back from purchasing one, is that I am unclear of what happens if I need to return it. In under the one year that I have had the regular cable box I have had to return it to Rogers for a different one because it stopped working one day after a power outage. I presume it got fried - despite being plugged into a surge protector.
So if something similar happens to the HD cable box, can I just exchange it at a Rogers store as well or do I have to take it back to FS? Also, would I have to worry about purchasing an extended warranty?
Thanks for your help.
Algonquin is offline
Old 2008-07-25, 02:34 PM   #2
docted1
I may be wrong but I believe the buy or rent has been discussed many times. Try a search in DHC. Good luck.
docted1 is offline
Old 2008-07-28, 06:16 PM   #3
jlet
Examples:
http://www.digitalhome.ca/forum/show...highlight=rent
SA8300HD; Panasonic TH-50PZ850; Sony STR-DA5ES; Tannoy: Arden, S8C, S8LR; SVS 16-46PC+; Oppo 971; Harmony 659/680
jlet is offline
