Burning discs off a 530 - Canadian TV, Computing and Home Theatre Forums
Go Back   Canadian TV, Computing and Home Theatre Forums > Canadian Internet, Phone, TV and Wireless Service Providers > Shaw Direct (formerly Star Choice)
Old 2008-07-10, 10:34 PM   #1
Lester
Default Burning discs off a 530
I have been burning discs from my 530. I use a Samsung DVD recorder. I have had problems finalizing some discs and also experienced some discs with errors problems. I use composite cables connected to the DVD burner. Seems to me this only occurs when I have a DVI/HDMI plugged into the Sony LCD television set. When I disconnect the HDMI cable the recordings seem to work ok. Common sense tells me that it should not affect the recorder because that is not the connection being used. This problem also occured when I had an LG recorder to. Does anyone have any idea if the HDMI?DVI cable is the culprit
Lester
Lester is offline
Old 2008-07-10, 11:41 PM   #2
Although it should not happen, yes, it is the culprit with certain STB/Recorders/programmes. In order to have reliable recording, use the component video cables.
http://www.digitalhome.ca/forum/showthread.php?t=71112
57 is offline
Old 2008-07-11, 01:42 PM   #3
Lester
Thank you so much 57 for enlightening me. I suspected strongly that this was the case but it did not seem to make sense that another connection would affect the recorder.
thanks again
Lester
Lester is offline
