Version 181 firmware for ExpressVu 9242 Discussion - Canadian TV, Computing and Home Theatre Forums
Old 2008-07-08, 08:48 AM   #1
hugh
Default Version 181 firmware for ExpressVu 9242 Discussion
Version V181 for the ExpressVu 9242 seems to have arrived yesterday along with a screen saver that gives helpful hints.
Any other reports?
hugh is offline
Old 2008-07-08, 08:55 AM   #2
winnipeg2
1) You can group recordings now
2) Main menu has multimedia option now, for External USB drive, I haven't tested this yet
winnipeg2 is offline
Old 2008-07-08, 08:56 AM   #3
Steve0
I got my 9242 about 3 weeks ago and it came loaded with this firmware. The reciever sometimes shuts off for some reason and it takes some screwing around to bring it back up.
Panisonic TH-46PZ80, Yamaha RX-V550, Expressvu 9242, Xbox 360, Harmony 880
Steve0 is offline
Old 2008-07-08, 10:12 AM   #4
hugh
The multimedia options doesn't seem to do anything. I plugged in an external USB option and tried the external drive option and it said the feature was not supported.
hugh is offline
Old 2008-07-08, 10:30 AM   #5
winnipeg2
Strange it works with my 4GB flash drive but not my 250Gb external Drive.
I had to reboot to get it to see my 4GB drive.
I rebooted with 250GB but it doesn't see it
Old 2008-07-08, 10:34 AM   #6
hugh
Sounds like the Recent 6141 update was similar. If you check out photos, can you see the folders on the flash drive?
hugh is offline
Old 2008-07-08, 10:38 AM   #7
winnipeg2
No I just tried that, I have photos but it doesn't show them
Old 2008-07-08, 10:41 AM   #8
hugh
So how do you know it "sees" the flash drive? Do you get a message or something when you rebooted the 9242?
hugh is offline
Old 2008-07-08, 10:43 AM   #9
winnipeg2
Sorry it does work, I thought I had copied photos the 1st time but didn't
When I got to Menu/Multimedia I see USB device attached, I can then manage the photos and copy the photos to the receiver and view them.
Old 2008-07-08, 10:45 AM   #10
winnipeg2
yes you get message saying multimedia device connected. Once its rebooted you can remove and insert again and it sees it.
Message "multimedia device removed....."
Then "Multimedia device inserted ....." or something like that
Old 2008-07-09, 07:19 PM   #11
Ray08
The folder option is very useful! I like it! But the USB seems to be used only for pictures from a USB stick. The external hard drive option is what we're looking for...
Ray08 is offline
Old 2008-07-09, 07:37 PM   #12
scrooloose
That's what we're waiting for, but I have a feeling that isn't going to come free of charge.
-Mike
Pioneer PRO-110FD | Pioneer VSX-92TXH | BELL 9242 | Panasonic DMP-BD35 | XBOX 360 |WD TV Live Hub
scrooloose is offline
Old 2008-07-10, 11:54 AM   #13
habskilla
v181 has introduced the skip to live bug for me. Happened the first time yesterday watching a non CBCHD channel. Nice. Thought I left that behind with the returned 9200.
habskilla is online now
Old 2008-07-13, 08:00 AM   #14
jimbgoss
Every morning after V181 my 9242 is turned off when I have it set not to. Then attention 833 to do a switch test and after that a error 835 that there is a problem with the satellite signal. After 2 or 3 minutes acquiring signal the TV comes on and is ok untill the next morning. If I just turn off the 9242 with the remote it comes right back but if I unplug it goes through the same thing all over again.
jimbgoss is offline
Old 2008-07-13, 11:18 AM   #15
scrooloose
Do you have two (2) satellite feeds into your 9242, and are they both working properly? The 9242 requires both to function correctly.
-Mike
Tags
9242, expressvu, firmware
