I just decided to buy an HDTV from FutureShop. They wanted me to buy those expensive HDMI cables, but I did my homework and bought them from a company in Markham for around $10 each. I'm a StarChoice subscriber so I bought a StarChoice HD receiver. To my surprise when I got it home and tried to connect it, I realized that the StarChoice HD receiver doesn't have an HDMI port. Their tech support insisted that I was just as well off with component video cables and RCA audio cables. Are they telling me the truth or should I consider switching to Rogers or ExpressVu?
Does it have an DVI port? If so you can use a DVI to HDMI cable. You will need to run the audio separately. Component will also work but the cables usually cost more.
I've had my DVR 530 hooked up with both DVI-HDMI and component and there really isn't any difference. For audio, I use analogue (RCA red & white) for sound through the tv, and digital coaxial for sound through my 5.1 set-up.
On a properly calibrated input, the component video connection is usually indistinguishable from HDMI (or DVI) on STBs. See the following thread where this is discussed:
Thanks for the input. I guess I'll stay with StarChoice. I haven't looked into it in detail, but I think they're the cheapest provider of the big 3. I would like to be getting digital sound, but I'll make do with the RCA cables. BTW the component video cables came with the receiver. I didn't have to buy them. Just bought a Sony KDL-46W4100 HDTV. Just came out on the market.
I really can't see much difference on my 55" sony sxrd with videotron cable, but for blu ray I would definately want hdmi for the audio and video....I would say that with hdmi and the videotron box I have, there are other issues that I've experienced that are a pain.... I believe it's a handshaking issue that requires me to reset the box. Overall hdmi should be simpler if you don't experience the problems that I've had; also, I would question why your cable or sat company is giving you a box with old technology.
Related Threads
1.7M posts
114.9K members
Since 2001
A forum community dedicated to Canadian TV, computing and home theatre owners and enthusiasts. Come join the discussion about home audio/video, displays, troubleshooting, styles, projects, DIY’s, product reviews, accessories, classifieds, and more!
